2 Replies Latest reply on Jan 31, 2012 5:34 PM by James_233
    InDesign CS5 (Mac) document is on strike (hangs for .idml, creating ToC)...
    James_233 Level 1
      1. Document A: Tried to create a Table of Contents to replace the one I already have. INDD beachball.
      2. Force quit INDD and restarted. On TOC re-creation with new style, same result. Force quit again.
      3. Restarted Mac
      4. Same result as 1. Set up a new style TOC, with and without PDF hyperlinks. Same result.
      5. Reset INDD preferences. Reopened Document A, tried to create ToC. Same result.
      6. Document B: Tried to create a TOC in another document. No problems, so must be document, rather than INDD as a whole.
      7. Document A: Reopened original buggy document, tried to create IDML, but it froze at 57%. Force quit again...
      What can I do to get a non-buggy, working document A? It has variables and cross-references but so does Document B.
        • 1. Re: InDesign CS5 (Mac) document is on strike (hangs for .idml, creating ToC)...
          Open as Copy sometimes works. If not, are you able and willing to share this document with others to take a closer look at? You can either use a public link (e.g., DropBox or yousendit), or feel free to P.M. me for contact details.
          • 2. Re: InDesign CS5 (Mac) document is on strike (hangs for .idml, creating ToC)...
            James_233 Level 1
            Thank you Jongware for your suggestion.
            Open as Copy did not work so I decided to go back to the previous version (I always make a new document when the client sends the next set of changes) and re-did around 5 hours of work, but now I have an up to date version that does not keep crashing and with all the cross-references working really well. Thought this would be better than sending it over to you because I guess no one would be able to fix what was causing the document to crash at the 57% point of idml creation or when clicking on the make ToC button.
            I guess at the 57% point INDD is working on the table of contents or cross-references or those dratted variables which cause any document to crash if text containing them is selected. That is a bug which I wish Adobe would fix pronto. Only happens on Macs not the PC version of CS5 apparently.
