1. Re: Border HELP!
[Jongware] Jan 31, 2012 10:45 AM (in response to Tom519)Draw a single line version and use offset path.
-- or --
Draw two rectangles inside each other, draw two circles inside each other, select one of each and use the pathfinder.
... Does Illustrator have double-line styles, 2012 Anno Dominus?
3. Re: Border HELP!
Tom519 Jan 31, 2012 11:02 AM (in response to Tom519)Thanks guys! @ Larry, how do i get the white cap inbetween? When I add another stroke it just puts it ontop? thanks
4. Re: Border HELP!
Larry G. Schneider Jan 31, 2012 11:31 AM (in response to Tom519)Look at the appearance panel in my image. Use the bottom stroke as the daker color, mine is 4 points. Make the added stroke which is on top the white or paper color and make it 2 points. You can use the small squares in the Appearance panel to control the size and color of the added stroke. It will view as two dark lines separated by white; curves should match exactly.
5. Re: Border HELP!
Kurt Gold Jan 31, 2012 1:17 PM (in response to [Jongware])... Does Illustrator have double-line styles, 2012 Anno Dominus?
There have been brushes – and therefore double-line styles – for almost two decades.
Do you mean something different? Such as InDesign's pretty limited way to handle that?
6. Re: Border HELP!
Steve Fairbairn Jan 31, 2012 3:40 PM (in response to [Jongware])2012 Anno Dominus?
2012 Anno Domini.
Please allow me to correct your Latin :-)
Domini is the genetive (ownership) case of dominus = Year of the Lord.
7. Re: Border HELP!
[Jongware] Jan 31, 2012 3:44 PM (in response to Kurt Gold)Ah, brushes. Nope -- InDesign is pretty limited indeed (not that I use anything more complicated than a dashed line, every now & then).
I *was* thinking of how I'd do this in InDesign and came up with this: draw rectangle, cut off the four corners with a circle using the path finder, apply double line style. With a bit of help of Smart Guides to position the circles, one minute work.
8. Re: Border HELP!
Monika Gause Jan 31, 2012 4:04 PM (in response to [Jongware])In InDesign you would have a corner style to create those corners ...
9. Re: Border HELP!
Wade_Zimmerman Jan 31, 2012 4:35 PM (in response to Tom519)You could go tot he Brushes Panel and open the Brush lIbraries and look for Borders>Lines
the have these
lslect the one I have seleced and you get this
Slect the one under neath you get this the brushes are good if you are going to do this over and over if you want to be able to change the color of the bruss double click in the brush pane and change the color theod to tinti
