0 Replies Latest reply on Jan 31, 2012 11:59 AM by stuckness879879
    "The installation of This application is damaged...." everytime I build with adt using ant...
    stuckness879879
      So basically I can build the entire application with ant just fine except up to the point of packaging. I can't get consistent air builds with the ant script. If I just export to release in flashbuilder after running the script up to point to where I need to package...it works just fine though
      A snippet of the install logs...
      2012-01-31:13:11:05] Application Installer begin with version 3.1.0.4880 on Windows 7 x86
      [2012-01-31:13:11:05] Commandline is: C:\Source\ESManager\ESManager.air
      [2012-01-31:13:11:05] Installed runtime (3.1.0.4880) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2012-01-31:13:11:05] Unpackaging file:///C:/Source/ESManager/ESManager.air to C:\Users\stuckness\AppData\Local\Temp\fla82FA.tmp
      [2012-01-31:13:11:10] Application signature verified
      [2012-01-31:13:11:10] Unpackaging/validation complete
      [2012-01-31:13:11:10] Installed app (ESMain.dev.E2264762215296142788B65F717A5C51E123BA2D.1) located at C:\Program Files (x86)\ESManager_Development\ESManager_Development.exe
      [2012-01-31:13:11:11] Converting unpackaged application to a native installation package in C:\Users\stuckness\AppData\Local\Temp\fla99F4.tmp
      [2012-01-31:13:11:12] Native installation package creation succeeded
      [2012-01-31:13:11:12] Starting app update of C:\Program Files (x86). Updating from ESMain.dev.E2264762215296142788B65F717A5C51E123BA2D.1 version 1.1.74 to ESMain.dev.E2264762215296142788B65F717A5C51E123BA2D.1 version 1.1.75 using the source file at file:///C:/Source/ESManager/ESManager.air
      [2012-01-31:13:11:12] Installing msi at C:\Users\stuckness\AppData\Local\Temp\fla99F4.tmp\setup.msi with guid {27604778-1928-6588-1CA0-A0895A94C4D6}
      [2012-01-31:13:11:18] Launching subprocess with commandline C:\Program Files (x86)\ESManager_Development\ESManager_Development.exe
      [2012-01-31:13:11:18] Application Installer end with exit code 0
      I keep wondering if there is something wrong with this, but always builds just fine...it's just a problem when I run the air package...and it runs just fine if I don't run this section and just export to release in flashbuilder, but I'm trying to automate the process...
      <target name="package" depends=""
              description="Packages the build SWF file from a temp directory.">
              <exec executable="${FLEX_HOME}/bin/adt.bat" failonerror="true">
                  <arg line="-package"/>
                  <arg line="-tsa none" />
                  <arg line="-storetype pkcs12"/>
                  <arg line="-keystore C:\Source\ESHIPPING.p12"/>
                  <arg line="-storepass PASSWORD_HERE/>
                  <arg line="C:\Source\ESManager\ESManager.air"/>
                  <arg line="C:\ColdFusion8\wwwroot\ESManager-debug\ESManager-app.xml"/>
                  <arg line="-C C:\ColdFusion8\wwwroot\ESManager-debug \swfs" />
                  <arg line="-C C:\ColdFusion8\wwwroot\ESManager-debug \data" />
                  <arg line="-C C:\ColdFusion8\wwwroot\ESManager-debug \esicons" />
                  <arg line="-C C:\ColdFusion8\wwwroot\ESManager-debug \autoupdate" />
                  <arg line="-C C:\ColdFusion8\wwwroot\ESManager-debug ESManager.swf" />
              </exec>
          </target>
