1. Re: Playback/Scrubbing barely works
Stan Jones Jan 31, 2012 5:07 PM (in response to SupersoulVP)Test a new project, if okay, it does not rule out the lengthof your project, but if not okay, it suggests either a corrupt project or that length does not matter. I'm not on my regular ocmputer, and do not have th wlink. There is a troubleshooting knowledge base file for Mac; not sure if it was for Encore corrupt project, or setup generally.
2. Re: Playback/Scrubbing barely works
SupersoulVP Feb 1, 2012 2:18 PM (in response to Stan Jones)Hey Stan. I have tried starting several new projects from scratch, with only marginal improvements. It's amazing how often that does help though.
The problem may be due to the duration of the video file. I brought in a 5 minute clip, a 21 minute clip, along with the 82. All files are blu-ray compliant within Encore. It seemed to get progressively worse dragging the CTI around the 3 different duration timelines and marking chapter points, even when cleaning the media cache in-between.
5 min: no problems dragging around and stepping frame by frame with the arrow keys.
21 min: small delays waiting for monitor tab's viewer to update but still able to step frame by frame. Short delays between pressing * for a new chapter point, and when it actually shows up.
82 min: starts out only slightly worse than 21 min timeline, but quickly becomes unusable. Long delays between moving CTI and getting an updated picture. Intermittent ability to step between frames.
I tried a new project in basically an identical suite, and got only slightly better results. No disc simulation has been able to skip ahead more than 2 chapters, or been able to play anthing after the opening of the disc.
