0 Replies Latest reply on Jan 31, 2012 2:16 PM by Doron Katz
    Getting ant build error "Unable to locate specified base class 'mx.core.Application' for component c
    Doron Katz
      Hi guys,
      I am trying to build using ant a Flex 3.5 app, and I keep on getting the error:
      Unable to locate specified base class 'mx.core.Application' for component class 'main'.
      my build.xml file looks something like:
      <project name="ASC App" default="compile flex project">
         <!-- load previously defined configuration properties file -->
         <property file="build.properties" />
         <!-- points to our flexTasks.jar we copied to the libs folder to distribute with the project -->
         <taskdef resource="flexTasks.tasks" classpath="${basedir}/libs/flexTasks.jar"/>
         <!-- delete and create the DEPLOY dir again -->
         <target name="init">
            <delete dir="${DEPLOY_DIR}" />
            <mkdir dir="${DEPLOY_DIR}" />
         </target>
         <!-- Build and output the Main.swf-->
         <target name="compile flex project" depends="init">
            <mxmlc file="src/main.mxml" output="${DEPLOY_DIR}/main.swf">
               <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml"/>
               <source-path path-element="${FLEX_HOME}/frameworks"/>
               <source-path path-element="${APP_COMMON}"/>
               <source-path path-element="${FLEX_COMMON}"/>
                           <library-path dir="${LIBS_DIR}/AlivePDF/" append="true"/>
                           <library-path dir="${LIBS_DIR}" append="true"/>
               <compiler.debug>false</compiler.debug>
            </mxmlc>
         </target>
      </project>
      and my build.properties:
      # Application name
      APP_NAME=AS App
      # SWF file
      APP=main
      # Common library
      APP_COMMON=../ASC_common
      FLEX_COMMON=../common
      ALIVE_PDF=../libraries/AlivePDF/SWC/AlivePDF
      # change this to your Flex SDK directory path
      FLEX_HOME=/SDKs/flex_sdk_3_4
      # this points to your project's src directory
      SRC_DIR =${basedir}/src
      # points to the project's libs directory
      LIBS_DIR =${basedir}/libs
      # this is the folder we want to publish the swf to
      DEPLOY_DIR = ${basedir}/DEPLOY
      Your help would be very much appreciated!
