This content has been marked as final.
Show 1 reply
1. Re: Merge TOC
Peter Grainge Feb 1, 2012 3:11 AM (in response to The Real Mike73)You haven't said whether this is desktop or browser based AIR help but it doesn't matter too much as that is the way all merged help works.
You get the parent TOC first then the TOC for each child, or whatever order you set them up in the parent.
You can see that at file:///Z:/00_RH_TEST_PROJECTS/RH9_Projects/rh9_browser_air_merge/generate/index.htm
The way that I originally posted for merging help does allow nesting but it is not a method that I recommend now.
http://www.grainge.org/pages/authoring/merging_webhelp/merging_method_original.htm
