26 Replies Latest reply on Feb 2, 2012 5:09 AM by Jeff_Coatsworth
    RoboHelp 9 crashes during the publish of a project
    EricButer
      Greetings friends,
      I am in a serious bind. I have a project that was created in Robohelp 9. I started encountering crashes on the evening of Jan 30th when attempting to publish the project.
      I have been working in this same project without issue for 3 months without issue. I suspect the issue is related to some topics that were updated or created on that day.
      Here is what I have tried:
      1. I am able to successfully publish other projects
      2. I was able publish the project in question earlier in the day. From modified times, I can deduce the batch of topics that may be involved.
      The problem is there are 32 topics.
      3. I have evaluated each of the 32 topics, seeing an earlier thread that referenced potential issues with tables. I did find 2 topics where the table looked a bit odd. I edited the properties on the tables and saved the topics. The issue persisted.
      4. For grins, I checked the properties on the tables in each topic to be sure they matched the format in known-good topics.
      5. I have tried renaming the project's .cpd file - based on other posts- the same issue occurs.
      6. The project is pretty good size, so recreating it is NOT an option.
      So I am stuck!
      I have some questions to try to resolve this:
      1. I noted in another thread that a user with a similar issue was able to publish via command line. Any suggestions on the string to use?
      2. Is there a way to test this project by removing the suspect topics, then readding them one-at-a-time - aside from manually re-creating the topic in RH, then copy/paste from the original?
      Any suggestions on how to achieve this goal?
      3. Are there any debugging/compiling tools available to help troubleshoot this type of error? This seems like a fairly common error where topic formatting can cause trouble. It would SEEM logical that a tool would exist.
      I thank you all in advance for your consideration on this!
      Thanks again.
      Eric Buterbaugh
      Newforma, Inc.
