2 Replies Latest reply on Feb 3, 2012 6:17 AM by JADarnell
    Downsampling to 150
    JADarnell
      Hello all:
         I've built a small plugin that creates PDFs out of InDesign documents.  I set the following export options just prior to generating the PDF (sorry about the table format--the forum editor is doing that--not me):
      InterfacePtr<IPDFExportPrefs> CmdExportPrefs(PrintOnePDFCommand, UseDefaultIID());
      CmdExportPrefs -> SetAddStructure(kFalse);      //  Tagged PDF
      CmdExportPrefs -> SetIncludeSlug(  kTrue);
      CmdExportPrefs -> SetUseDocumentBleed(kFalse);
      CmdExportPrefs -> SetPDFExMarkLineWeight(  .25);
      CmdExportPrefs -> SetPDFExPrinterMarksOffset(   21);//  .29 inches roughly equals 21
      CmdExportPrefs -> SetPDFExSubsetFontsThreshold(100);//  100% of subsetted fonts are embedded
      CmdExportPrefs -> SetPDFExBleedTop(          9);
      CmdExportPrefs -> SetPDFExBleedBottom(       9);
      CmdExportPrefs -> SetPDFExBleedInside(       9);
      CmdExportPrefs -> SetPDFExBleedOutside(      9);
      CmdExportPrefs -> SetPDFExAcrobatCompatibilityLevel(             IPDFExportPrefs::kPDFVersion16);
      CmdExportPrefs -> SetPDFExBleed(                                IPDFExportPrefs::kExportBleedON);
      CmdExportPrefs -> SetPDFExColorBars(                       IPDFExportPrefs::kExportColorBarsOFF);
      CmdExportPrefs -> SetPDFExCompressColorImages(IPDFExportPrefs::kExportCompressImagesAutoLZWJPEGHigh);   //  Quality?
      CmdExportPrefs -> SetPDFExCompressGrayImages( IPDFExportPrefs::kExportCompressImagesAutoLZWJPEGHigh);   //  Quality?
      CmdExportPrefs -> SetPDFExColorSpace(             IPDFExportPrefs::kExportPDFColorSpacePassthru);
      CmdExportPrefs -> SetPDFExCompressLineArtAndText(  IPDFExportPrefs::kExportCompressLineArtAndTextON);
      CmdExportPrefs -> SetPDFExCompressMonoImages( IPDFExportPrefs::kExportCompressImagesCCITTGroup4);   //  Quality?
      CmdExportPrefs -> SetPDFExCropMarks(                        IPDFExportPrefs::kExportCropMarksON);
      CmdExportPrefs -> SetPDFExDisallowImageCrop(       IPDFExportPrefs::kExportDisallowImageCropOFF);   //  Crop image to frame
      CmdExportPrefs -> SetPDFExIncludeICCProfiles(     IPDFExportPrefs::kExportIncludeICCProfilesOFF);
      CmdExportPrefs -> SetPDFExPageInfo(                          IPDFExportPrefs::kExportPageInfoON);
      CmdExportPrefs -> SetPDFExReaderSpreads(               IPDFExportPrefs::kExportReaderSpreadsOFF);
      CmdExportPrefs -> SetPDFExRegistrationMarks(       IPDFExportPrefs::kExportRegistrationMarksOFF);
      CmdExportPrefs -> SetPDFExThumbnails(                     IPDFExportPrefs::kExportThumbnailsOFF);
      CmdExportPrefs -> SetPDFExLinearized(                     IPDFExportPrefs::kExportLinearizedOFF);
      // process kSetPDFExportPrefsCmdBoss to change current settings
      InterfacePtr<ICommand> SetPDFExportPrefsCmd(CmdUtils::CreateCommand(kSetPDFExportPrefsCmdBoss));
      if (SetPDFExportPrefsCmd == nil)
      ASSERT_FAIL("Failed to get setPDFExportPrefsCmd");
      break;
      InterfacePtr<IPDFExportPrefs> pdfExportPrefs(SetPDFExportPrefsCmd, UseDefaultIID());
      if (pdfExportPrefs == nil)
      ASSERT_FAIL("Failed to get IPDFExportPrefs/pdfExportPrefs");
      break;
      pdfExportPrefs -> CopyPrefs(CmdExportPrefs);
      CmdUtils::ProcessCommand(SetPDFExportPrefsCmd);
      With this set of options, some of our images are getting downsampled to 150 dpi when they otherwise have decent resolution.
      I removed all the compression lines, for example:
      CmdExportPrefs -> SetCompressColorAbove(   300);//Color:  300JPEG
      CmdExportPrefs -> SetCompressGrayAbove(    300);//Grayscale 300JPEG
      CmdExportPrefs -> SetCompressMonochromeAbove( 1200);//  1 bit 1200 CCITT
      Suddenly all of our images were downsampled to 150 dpi.  What's making that happen?  How can I stop it?
      TIA!
      John
        • 1. Re: Downsampling to 150
          Norio Kawamura Level 4
          Do you try the Image sampling options of IPDFExportPrefs?
          SetPDFExSampleColorImages, SetPDFExSampleGrayImages, SetPDFExSampleMonoImages,
          SetPDFExSampleColorImagesXRes. etc.
          • 2. Re: Downsampling to 150
            JADarnell Level 1
            Not originally, but later on as I studied IPDFExports.h and found them.  Interestingly enough they did little.
            What finally seemed to fix the problem was a combination of the code you suggest and setting the compression member functions to high.  Here’s the code:
                  CmdExportPrefs -> SetPDFExSampleColorImages(IPDFExportPrefs::kExportSampleImagesByBicubicDownsampling);
                  CmdExportPrefs -> SetPDFExSampleColorImagesXRes((int32) 300);
                  CmdExportPrefs -> SetPDFExSampleColorImagesYRes((int32) 300);
                  CmdExportPrefs -> SetPDFExSampleGrayImages(IPDFExportPrefs::kExportSampleImagesByBicubicDownsampling);
                  CmdExportPrefs -> SetPDFExSampleGrayImagesXRes((int32)  300);
                  CmdExportPrefs -> SetPDFExSampleGrayImagesYRes((int32)  300);
                  CmdExportPrefs -> SetPDFExSampleMonoImages(IPDFExportPrefs::kExportSampleImagesByBicubicDownsampling);
                  CmdExportPrefs -> SetPDFExSampleMonoImagesXRes((int32) 1200);
                  CmdExportPrefs -> SetPDFExSampleMonoImagesYRes((int32) 1200);
                  CmdExportPrefs -> SetCompressColorAbove(       300);    //Color:  300JPEG
                  CmdExportPrefs -> SetCompressGrayAbove(        300);    //Grayscale 300JPEG
                  CmdExportPrefs -> SetCompressMonochromeAbove( 1200);    //  1 bit 1200 CCITT
            Thanks for the information, Norio.
            R,
            John
