2 Replies Latest reply on Feb 1, 2012 2:46 PM by JJMack
    Stroking a shape...
    graph22 Level 1
      Hope you're well.
      In the attached pic, you'll see I've drawn a white box on this page. I did not add the dark stroke you see (it happened automatically), although I'd like there to be one.
      I used the shape tool to draw it.
      I want to put a stroke on it but when the layer is selected the stroke option in the edit menu is not available. What do I do?
      Also, why does the box disappear when I click off the layer? Because there is only a white fill and no actual outline?
      Thanks very much for your help.
        • 1. Re: Stroking a shape...
          acresofgreen Level 4
          Try this:
          • Create a new blank layer and select it
          • Select the shape tool and select the right-hand icon in the tool options bar (Fill pixels)
          • Draw your shape with the shape tool on thís new layer
          The Edit - Stroke option should be available
          Message was edited by: acresofgreen I think you were creating a shape layer.  When you do that and click away from the layer you won't see the outline any more.  Unfortunately you didn't include your layers panel in your screenshot.
          • 2. Re: Stroking a shape...
            The shape tools can create shape layers, WorkPaths and Fill the shape on the current layer with Pixels controlled by three icons in the tool option bar.  I would use the Work path option to do what you asked.
            Select the shape tool you want to use and click the path option in the option bar here I selected the custom shape tool and a custom yankee shape.
            next I Held down the shift key to constrain the shape and draged out the shape.
            Selected the brush tool clicked on the blue swatch and set brush to be soft 5 pixels round.
            Clicked on Brush Stroke Path Icon To stroke current layer which could be a new empty layer
            Draged work Path to trash
