3 Replies Latest reply: Feb 6, 2012 1:06 PM by MartyGoldberg RSS
    Flash CS5.5 iOS export error from Java VM
    MartyGoldberg Community Member
      Running 64-bit Windows 7, Flash Pro CS5.5, and Air 3.1
      Getting the following errors when trying to compile to iOS for testing, hoping someone can help:
      # A fatal error has been detected by the Java Runtime Environment:
      #  Internal Error (0xe06d7363), pid=11372, tid=9324
      # JRE version: 6.0_18-b07
      # Java VM: Java HotSpot(TM) Client VM (16.0-b13 mixed mode windows-x86 )
      # Problematic frame:
      # C  [KERNELBASE.dll+0xb9bc]
      # If you would like to submit a bug report, please visit:
      #   http://java.sun.com/webapps/bugreport/crash.jsp
      # The crash happened outside the Java Virtual Machine in native code.
      # See problematic frame for where to report the bug.
      ---------------  T H R E A D  ---------------
      Current thread (0x0054a000):  JavaThread "main" [_thread_in_native, id=9324, stack(0x00210000,0x00260000)]
      siginfo: ExceptionCode=0xe06d7363, ExceptionInformation=0x19930520 0x0025f428 0x4a716374
      Registers:
      EAX=0x0025f390, EBX=0x4b737b00, ECX=0x00000003, EDX=0x00000000
      ESP=0x0025f390, EBP=0x0025f3e0, ESI=0x4a7e55fc, EDI=0x001245f8
      EIP=0x74f8b9bc, EFLAGS=0x00000216
      Top of Stack: (sp=0x0025f390)
      0x0025f390:   e06d7363 00000001 00000000 74f8b9bc
      0x0025f3a0:   00000003 19930520 0025f428 4a716374
      0x0025f3b0:   4ab4ba2c 4ab4ba2c 001245f8 4b737b00
      0x0025f3c0:   4a7e55fc 0025f3d0 4a5ebc10 4a7e5a30
      0x0025f3d0:   0025f410 4a5e45d2 00000008 4a5e2a9e
      0x0025f3e0:   0025f418 4a5e24c9 e06d7363 00000001
      0x0025f3f0:   00000003 0025f40c e06d7363 00000001
      0x0025f400:   00000000 00000000 00000003 19930520
      Instructions: (pc=0x74f8b9bc)
      0x74f8b9ac:   0c eb 03 89 45 c0 8d 45 b0 50 ff 15 5c 11 f8 74
      0x74f8b9bc:   c9 c2 10 00 cc cc cc cc cc 8b ff 55 8b ec 56 8b
      Stack: [0x00210000,0x00260000],  sp=0x0025f390,  free space=13c0025ed38k
      Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
      C  [llvm.dll+0x4424c9]
      C  [llvm.dll+0x441a65]
      C  [llvm.dll+0x1d12a9]
      C  [llvm.dll+0x32bbae]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      J  llvm.llvmJNI.FunctionPassManager_run(JLllvm/FunctionPassManager;JLllvm/Function;)Z
      J  llvm.FunctionPassManager.run(Lllvm/Function;)Z
      j  com.adobe.air.ipa.AOTCompiler.compileBitcode()V+392
      j  com.adobe.air.ipa.AOTCompiler.GenerateMacBinary()V+76
      j  com.adobe.air.ipa.IPAOutputStream.compileRootSwf()Ljava/io/File;+240
      j  com.adobe.air.ipa.IPAOutputStream.finalizeSig()V+76
      j  com.adobe.air.ApplicationPackager.createPackage()V+279
      j  com.adobe.air.ipa.IPAPackager.createPackage()V+68
      j  com.adobe.air.ADT.parseArgsAndGo()V+63
      j  com.adobe.air.ADT.run([Ljava/lang/String;)I+18
      j  com.adobe.air.ADT.main([Ljava/lang/String;)V+10
      v  ~StubRoutines::call_stub
      ---------------  P R O C E S S  ---------------
      Java Threads: ( => current thread )
        0x00503400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1100, stack(0x48b60000,0x48bb0000)]
        0x004fd000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=9360, stack(0x48ad0000,0x48b20000)]
        0x004fbc00 JavaThread "Attach Listener" daemon [_thread_blocked, id=10244, stack(0x48a40000,0x48a90000)]
        0x004f9000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=11156, stack(0x489b0000,0x48a00000)]
        0x004c7c00 JavaThread "Finalizer" daemon [_thread_blocked, id=12124, stack(0x48920000,0x48970000)]
        0x004c6400 JavaThread "Reference Handler" daemon [_thread_blocked, id=12204, stack(0x48890000,0x488e0000)]
      =>0x0054a000 JavaThread "main" [_thread_in_native, id=9324, stack(0x00210000,0x00260000)]
      Other Threads:
        0x004c3000 VMThread [stack: 0x48800000,0x48850000] [id=10528]
        0x0050dc00 WatcherThread [stack: 0x48bf0000,0x48c40000] [id=11800]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 126912K, used 53338K [0x04430000, 0x0cde0000, 0x19980000)
        eden space 112832K,  45% used [0x04430000, 0x076b1680, 0x0b260000)
        from space 14080K,  11% used [0x0c020000, 0x0c1b5410, 0x0cde0000)
        to   space 14080K,   0% used [0x0b260000, 0x0b260000, 0x0c020000)
      tenured generation   total 281952K, used 228188K [0x19980000, 0x2acd8000, 0x44430000)
         the space 281952K,  80% used [0x19980000, 0x278573f8, 0x27857400, 0x2acd8000)
      compacting perm gen  total 12288K, used 10313K [0x44430000, 0x45030000, 0x48430000)
         the space 12288K,  83% used [0x44430000, 0x44e42468, 0x44e42600, 0x45030000)
      No shared spaces configured.
      Dynamic libraries:
      0x00400000 - 0x00424000           C:\ProgramData\Adobe\CS5\jre\bin\java.exe
      0x772d0000 - 0x77450000           C:\Windows\SysWOW64\ntdll.dll
      0x75dc0000 - 0x75ed0000           C:\Windows\syswow64\kernel32.dll
      0x74f80000 - 0x74fc6000           C:\Windows\syswow64\KERNELBASE.dll
      0x76530000 - 0x765d0000           C:\Windows\syswow64\ADVAPI32.dll
      0x76330000 - 0x763dc000           C:\Windows\syswow64\msvcrt.dll
      0x763e0000 - 0x763f9000           C:\Windows\SysWOW64\sechost.dll
      0x76220000 - 0x76310000           C:\Windows\syswow64\RPCRT4.dll
      0x749b0000 - 0x74a10000           C:\Windows\syswow64\SspiCli.dll
      0x749a0000 - 0x749ac000           C:\Windows\syswow64\CRYPTBASE.dll
      0x7c340000 - 0x7c396000           C:\ProgramData\Adobe\CS5\jre\bin\msvcr71.dll
      0x6d800000 - 0x6da97000           C:\ProgramData\Adobe\CS5\jre\bin\client\jvm.dll
      0x74db0000 - 0x74eb0000           C:\Windows\syswow64\USER32.dll
      0x76610000 - 0x766a0000           C:\Windows\syswow64\GDI32.dll
      0x74d10000 - 0x74d1a000           C:\Windows\syswow64\LPK.dll
      0x74eb0000 - 0x74f4d000           C:\Windows\syswow64\USP10.dll
      0x72e90000 - 0x72ec2000           C:\Windows\system32\WINMM.dll
      0x75d60000 - 0x75dc0000           C:\Windows\system32\IMM32.DLL
      0x75ff0000 - 0x760bc000           C:\Windows\syswow64\MSCTF.dll
      0x71840000 - 0x7188c000           C:\Windows\system32\apphelp.dll
      0x6d7b0000 - 0x6d7bc000           C:\ProgramData\Adobe\CS5\jre\bin\verify.dll
      0x6d330000 - 0x6d34f000           C:\ProgramData\Adobe\CS5\jre\bin\java.dll
      0x6d290000 - 0x6d298000           C:\ProgramData\Adobe\CS5\jre\bin\hpi.dll
      0x76520000 - 0x76525000           C:\Windows\syswow64\PSAPI.DLL
      0x6d7f0000 - 0x6d7ff000           C:\ProgramData\Adobe\CS5\jre\bin\zip.dll
      0x6d560000 - 0x6d569000           C:\ProgramData\Adobe\CS5\jre\bin\management.dll
      0x6d610000 - 0x6d623000           C:\ProgramData\Adobe\CS5\jre\bin\net.dll
      0x761e0000 - 0x76215000           C:\Windows\syswow64\WS2_32.dll
      0x772a0000 - 0x772a6000           C:\Windows\syswow64\NSI.dll
      0x72b00000 - 0x72b3c000           C:\Windows\system32\mswsock.dll
      0x694f0000 - 0x694f6000           C:\Windows\System32\wship6.dll
      0x69400000 - 0x69410000           C:\Windows\system32\NLAapi.dll
      0x661f0000 - 0x66200000           C:\Windows\system32\napinsp.dll
      0x661d0000 - 0x661e2000           C:\Windows\system32\pnrpnsp.dll
      0x719b0000 - 0x719f4000           C:\Windows\system32\DNSAPI.dll
      0x661c0000 - 0x661c8000           C:\Windows\System32\winrnr.dll
      0x661b0000 - 0x661bd000           C:\Windows\system32\wshbth.dll
      0x694c0000 - 0x694e1000           C:\Program Files (x86)\Bonjour\mdnsNSP.dll
      0x72bd0000 - 0x72bec000           C:\Windows\system32\Iphlpapi.DLL
      0x72bc0000 - 0x72bc7000           C:\Windows\system32\WINNSI.DLL
      0x72af0000 - 0x72af5000           C:\Windows\System32\wshtcpip.dll
      0x71510000 - 0x71516000           C:\Windows\system32\rasadhlp.dll
      0x69470000 - 0x694a8000           C:\Windows\System32\fwpuclnt.dll
      0x725e0000 - 0x725f6000           C:\Windows\system32\CRYPTSP.dll
      0x72200000 - 0x7223b000           C:\Windows\system32\rsaenh.dll
      0x72ba0000 - 0x72bb7000           C:\Windows\system32\USERENV.dll
      0x72c30000 - 0x72c3b000           C:\Windows\system32\profapi.dll
      0x6d000000 - 0x6d14a000           C:\ProgramData\Adobe\CS5\jre\bin\awt.dll
      0x70f00000 - 0x70f51000           C:\Windows\system32\WINSPOOL.DRV
      0x74a10000 - 0x74b6c000           C:\Windows\syswow64\ole32.dll
      0x72890000 - 0x72a2e000           C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17 514_none_41e6975e2bd6f2b2\COMCTL32.dll
      0x75d00000 - 0x75d57000           C:\Windows\syswow64\SHLWAPI.dll
      0x4a1a0000 - 0x4a821000           C:\Program Files (x86)\Adobe\Adobe Flash CS5.5\AIR2.6\lib\aot\lib\llvm.dll
      0x57e90000 - 0x57f7b000           C:\Windows\system32\dbghelp.dll
      VM Arguments:
      jvm_args: -Xms256m -Xmx1024m
      java_command: C:\Program Files (x86)\Adobe\Adobe Flash CS5.5\AIR2.6\lib\adt.jar -package -target ipa-test -provisioning-profile C:/Users/wgungfu/Downloads/flowvoice.mobileprovision -storetype PKCS12 -keystore C:/Users/wgungfu/Downloads/Certificates.p12 -storepass x198mv F:/Business Networking Site/Answering Machine/voicemailios.ipa F:/Business Networking Site/Answering Machine/voicemailios-app.xml -C F:/Business Networking Site/Answering Machine/ voicemailios.swf AppIconsForPublish/voicemailicon512x512.png AppIconsForPublish/voicemailicon57x57.png AppIconsForPublish/voicemailicon114x114.png AppIconsForPublish/voicemailicon29x29.png
      Launcher Type: SUN_STANDARD
      Environment Variables:
      JAVA_HOME=C:\ProgramData\Adobe\CS5\jre
      CLASSPATH=.;C:\Program Files (x86)\QuickTime\QTSystem\QTJava.zip
      PATH=C:\ProgramData\Adobe\CS5\jre\bin;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\W indowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Lucidlogix Technologies\VIRTU;C:\Program Files (x86)\QuickTime\QTSystem\
      USERNAME=wgungfu
      OS=Windows_NT
      PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
      ---------------  S Y S T E M  ---------------
      OS: Windows 7 Build 7601 Service Pack 1
      CPU:total 4 (8 cores per cpu, 2 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
      Memory: 4k page, physical 8291324k(3413628k free), swap 16580800k(10179340k free)
      vm_info: Java HotSpot(TM) Client VM (16.0-b13) for windows-x86 JRE (1.6.0_18-b07), built on Dec 17 2009 13:35:55 by "java_re" with MS VC++ 7.1 (VS2003)
      time: Wed Feb 01 22:11:35 2012
      elapsed time: 580 seconds
