2 Replies Latest reply on Feb 3, 2012 12:55 PM by JEB5000
    How does Match Color work?
    JEB5000
      How does match color work?
      Do you have to make a selection?
      Does it work with particular layers?
      Since it is there I (***)ume it does something.
      Have tried it a number of times and see little or no change.
      Would like to say I like Touch. Wish it could handle raw and larger picture sizes to make it more usefull.
        • 1. Re: Match Color
          greule Adobe Employee
          With help of Match Color you can adjust color themes across layers.
          When you have for example 2 different layers, then you can select the top one and adjust the kind of color theme via Match Color to the one below.
          Hope that helps.
          • 2. Re: Match Color
            JEB5000 Level 1
            Thank you for the answer. Since there are no masking layers I allways make a copy of a layer first and end up working on the top layer. End up trying to match the layer below which is not the correct layer. Both layers are the same so I don't see any color change. Have changed my workflow and now color match works as expected.
            This helped, thank you.
