1 Reply Latest reply on Feb 3, 2012 3:45 AM by try67
    Taking data from one program to fill in pdf form
    gus_19
      I'm pretty new to this and I am not even sure this would be possible. I've created a fillable .pdf form and I was wondering if there is a way to transfer information from one software program into it's correct fields on the fillable form. For example, the person's contact information is seen on the screen from on program, but not in any structure to just copy and paste, and I would like to somehow very quickly autopopulate/transfer it to the form?
        • 1. Re: Taking data from one program to fill in pdf form
          There's no way to do that with JS. What you can do is export the data to a
          plain-text file and then use JS to import that file and populate the
          fields. If you're not using Acrobat X it would also be possible to do it in
          a smoother way using a local DB, but that is also much more complex to
          implement.
          For a more automated solution you will need to use a plugin or stand-alone
          application. You can ask at the Acrobat SDK forum about those.
