5 Replies Latest reply on May 12, 2016 10:59 PM by CoverBuilder
    Code in jsx script to set Object Editing value
    jwilheim
      The software company where I work runs a .jsx script to set all Preferences in InDesign.
      InDesign CS 5.5 has an option under General for Object Editing named Prevent Selection of Locked Objects.
      We need to have this turned off every time a user creates a new document.
      Can some provide the code to this that we can add to our existing script? Thank you.
        • 1. Re: Code in jsx script to set Object Editing value
          absqua Level 4
          That's an application preference, not a document preference, so I don't understand why you would need to set it every time someone makes a new document.
          app.generalPreferences.preventSelectingLockedItems = false;
          is what you want. We can't tell you where to put it in your existing script unless you provide it.
          Jeff
          • 2. Re: Code in jsx script to set Object Editing value
            jwilheim Level 1
            Thanks for the quick response. Here is our current Java script, in full. Thought it references CS2 in a comment at the top, we have run it successfully with CS2, CS4, CS5 and CS5.5
            //ApplicationTextDefaults
            //An InDesign CS2 JavaScript
            //Sets the application text defaults, which will become the text defaults for all
            //new documents. Existing documents will remain unchanged.
            with(app.textDefaults){
                alignToBaseline = false;        // align to baseline grid
                try {
            //        appliedFont = app.fonts.item("Times New Roman");
                    appliedFont = app.fonts.item("Helvetica");
                catch (e) {}
                try {
                    fontStyle = "Medium";
                catch (e) {}
                autoleading = 100;
                balanceRaggedLines = false;
                baselineShift = 0;
                capitalization = Capitalization.normal;
                composer = "Adobe Paragraph Composer";
                desiredGlyphScaling = 100;
                desiredLetterSpacing = 0;
                desiredWordSpacing = 100;
                dropCapCharacters = 0;
                if (dropCapCharacters != 0) {
                    dropCapLines = 3;
                    //Assumes that the application has a default character style named "myDropCap"
                    //dropCapStyle = app.characterStyles.item("myDropCap");
                fillColor = app.colors.item("Black");
                fillTint = 100;
                firstLineIndent = "0pt";
            //    firstLineIndent = "14pt";
                gridAlignFirstLineOnly = false;
                horizontalScale = 100;
                hyphenateAfterFirst = 3;
                hyphenateBeforeLast = 4;
                hyphenateCapitalizedWords = false;
                hyphenateLadderLimit = 1;
                hyphenateWordsLongerThan = 5;
                hyphenation = true;
                hyphenationZone = "3p";
                hyphenWeight = 9;
                justification = Justification.leftAlign;
                keepAllLinesTogether = false;
                keepLinesTogether = true;
                keepFirstLines = 2;
                keepLastLines = 2;
                keepWithNext = 0;
                kerningMethod = "Optical";
                kerningValue = 0;
                leading = 6.3;
            //    leading = 14;
                leftIndent = 0;
                ligatures = true;
                maximumGlyphScaling = 100;
                maximumLetterSpacing = 0;
                maximumWordSpacing = 160;
                minimumGlyphScaling = 100;
                minimumLetterSpacing = 0;
                minimumWordSpacing = 80;
                noBreak = false;
                otfContextualAlternate = true;
                otfDiscretionaryLigature = true;
                otfFigureStyle = OTFFigureStyle.proportionalOldstyle;
                otfFraction = true;
                otfHistorical = true;
                otfOrdinal = false;
                otfSlashedZero = true;
                otfSwash = false;
                otfTitling = false;
                overprintFill = false;
                overprintStroke = false;
                pointSize = 6.3;
            //    pointSize = 11;
                position = Position.normal;
                rightIndent = 0;
                ruleAbove = false;
                if(ruleAbove == true){
                    ruleAboveColor = app.colors.item("Black");
                    ruleAboveGapColor = app.swatches.item("None");
                    ruleAboveGapOverprint = false;
                    ruleAboveGapTint = 100;
                    ruleAboveLeftIndent = 0;
                    ruleAboveLineWeight = .25;
                    ruleAboveOffset = 14;
                    ruleAboveOverprint = false;
                    ruleAboveRightIndent = 0;
                    ruleAboveTint = 100;
                    ruleAboveType = app.strokeStyles.item("Solid");
                    ruleAboveWidth = RuleWidth.columnWidth;
                ruleBelow = false;
                if(ruleBelow == true){
                    ruleBelowColor = app.colors.item("Black");
                    ruleBelowGapColor = app.swatches.item("None");
                    ruleBelowGapOverprint = false;
                    ruleBelowGapTint = 100;
                    ruleBelowLeftIndent = 0;
                    ruleBelowLineWeight = .25;
                    ruleBelowOffset = 0;
                    ruleBelowOverprint = false;
                    ruleBelowRightIndent = 0;
                    ruleBelowTint = 100;
                    ruleBelowType = app.strokeStyles.item("Solid");
                    ruleBelowWidth = RuleWidth.columnWidth;
                singleWordJustification = SingleWordJustification.leftAlign;
                skew = 0;
                spaceAfter = 0;
                spaceBefore = 0;
                startParagraph = StartParagraph.anywhere;
                strikeThru = false;
                if(strikeThru == true){
                    strikeThroughColor = app.colors.item("Black");
                    strikeThroughGapColor = app.swatches.item("None");
                    strikeThroughGapOverprint = false;
                    strikeThroughGapTint = 100;
                    strikeThroughOffset = 3;
                    strikeThroughOverprint = false;
                    strikeThroughTint = 100;
                    strikeThroughType = app.strokeStyles.item("Solid");
                    strikeThroughWeight = .25;
                strokeColor = app.swatches.item("None");
                strokeTint = 100;
                strokeWeight = 0;
                tracking = 0;
                underline = false;
                if(underline == true){
                    underlineColor = app.colors.item("Black");
                    underlineGapColor = app.swatches.item("None");
                    underlineGapOverprint = false;
                    underlineGapTint = 100;
                    underlineOffset = 3;
                    underlineOverprint = false;
                    underlineTint = 100;
                    underlineType = app.strokeStyles.item("Solid");
                    underlineWeight = .25
                verticalScale = 100;
            //Units & Increments preference panel
            //Must do this to make sure our units that we set are in points. The vert and horiz
            //units that get set default to the current measurement unit. We set it to points
            //so we can be sure of the value. We'll reset it later to the desired setting.
            with(app.viewPreferences){
                horizontalMeasurementUnits = MeasurementUnits.points;    // Ruler Units, horizontal
                verticalMeasurementUnits = MeasurementUnits.points;        // Ruler Units, vertical
            //General preference panel
            with(app.generalPreferences){
                pageNumbering = PageNumberingOptions.section;    // Page Numbering, View
                toolTips = ToolTipOptions.normal;                    // Tool Tips
            //    toolsPalette = ToolsPaletteOptions.doubleColumn;    // Floating Tool Palette
                completeFontDownloadGlyphLimit = 2000;                // Always Subset Fonts...
            //Type preference panel
            with (app.textEditingPreferences){
                tripleClickSelectsLine = true;    // Triple Click to Select a Line
                smartCutAndPaste = true;        // Adjust Spacing Automatically when Cutting and Pasting Words
                dragAndDropTextInLayout = false;    // Enable in Layout View
                allowDragAndDropTextInStory = true;    // Enable in Story Editor
            with(app.textPreferences){
                typographersQuotes = true;            // Use Typographer's Quotes
                useOpticalSize = true;                // Automatically Use Correct Optical Size
                scalingAdjustsText = true;            // Adjust Text Attributes when Scaling
                useParagraphLeading = false;    // Apply Leading to Entire Paragraphs
                linkTextFilesWhenImporting = false;    // Create Links when Placing Text and Spreadsheet Files
            // Missing following (Font Preview Size, Past All Information/Text Only)
            //Advanced Type preference panel
                superscriptSize = 58.3;                // Superscript, size
                superscriptPosition = 33.3;            // Superscript, position
                subscriptSize = 58.3;                // Subscript, size
                subscriptPosition = 33.3;            // Subscript, position
                smallCap = 70;                        // Smallcap
            with(app.imePreferences){
                inlineInput = false;                // Use Inline Input for Non-Latin Text
            //Composition preference panel
                highlightKeeps = false;                    // Keep Violations
                highlightHjViolations = false;            // H&J Violations
                highlightCustomSpacing = false;            // Custom Tracking/Kerning
                highlightSubstitutedFonts = true;    // Substituted Fonts
                highlightSubstitutedGlyphs = false;    // Substituted Glyphs
                justifyTextWraps = false;                // Justify Text Next to an Object
                abutTextToTextWrap = true;                // Skip by Leading
                zOrderTextWrap = false;                    // Text Wrap Only Affects Text Beneath
                rulerOrigin = RulerOrigin.spreadOrigin;                    // Ruler Units, origin
            //    These are set at the end of the script after all the changes have been made
            //    horizontalMeasurementUnits = MeasurementUnits.points;    // Ruler Units, horizontal
            //    verticalMeasurementUnits = MeasurementUnits.inches;        // Ruler Units, vertical
                pointsPerInch = 72;                    // Point/Pica Size, Points/Inch
                cursorKeyIncrement = 1;                // Keyboard Increment, Cursor Key
                baselineShiftKeyIncrement = 2;    // Keyboard Increment, Baseline Shift
                leadingKeyIncrement = 2;        // Keyboard Increment, Size/Leading
                kerningKeyIncrement = 20;            // Keyboard Increment, Kerning
            //Grids preference panel
            with(app.gridPreferences){
                baselineColor = UIColors.lightBlue;    // Baseline Grid, Color
                baselineStart = 48;                        // Baseline Grid, Start
                baselineDivision = 6;                    // Baseline Grid, Increment Every
                baselineViewThreshold = 50;                // Baseline Grid, View Threshold
                baselineGridRelativeOption = BaselineGridRelativeOption.topOfPageOfBaselineGridRelativeOption;    // Baseline Grid, Relative To
                gridColor = UIColors.lightGray;            // Document Grid, Color
                horizontalGridlineDivision = 12;    // Document Grid, Horizontal, Gridline Every
                horizontalGridSubdivision = 12;            // Document Grid, Horizontal, Subdivisions
                verticalGridlineDivision = 12;            // Document Gird, Vertical, Gridline Every
                verticalGridSubdivision = 12;            // Document Grid, Vertical, Subdivisions
                gridsInBack = true;                        // Grids in Back
                documentGridSnapto = false;                // snap to grid or not
                documentGridShown = false;                // show document grid
            //Guides & Pasteboard preference panel
            with(app.documentPreferences){
                marginGuideColor = UIColors.violet;                // Color, Margins
                columnGuideColor = UIColors.magenta;            // Color, Columns
            with(app.pasteboardPreferences){
                bleedGuideColor = UIColors.fiesta;                // Color, Bleed
                slugGuideColor = UIColors.gridBlue;                // Color, Slug
                previewBackgroundColor = UIColors.lightGray;    // Color, Preview Background
                minimumSpaceAboveAndBelow = 72;                    // Minimum Vertical Offset
                guideSnaptoZone = 4;                            // Snap to Zone
            with(app.guidePreferences){
                guidesInBack = false;                            // Guides in Back
            //Dictionary preference panel
            with(app.dictionaryPreferences){
                composition = ComposeUsing.both;    // Hyphenatin Exceptions, Compose Using
                mergeUserDictionary = false;    // Merge User Dictionary into Document
                recomposeWhenChanged = true;    // Recompose All Stories When Modified
            // Missing (Lang, Hyph, Spelling, Double Quotes, Single Quotes)
            //Spelling preference panel
            with(app.spellPreferences){
                checkMisspelledWords = true;                    // Find, Misspelled Words
                checkRepeatedWords = true;                        // Find, Repeated Words
                checkCapitalizedWords = true;                    // Find, Uncapitalized Words
                checkCapitalizedSentences = true;                // Find, Uncapitalized Sentences
                dynamicSpellCheck = true;                        // Enable Dynamic Spelling
                misspelledWordColor = UIColors.red;                // Color, Misspelled Words
                repeatedWordColor = UIColors.green;                // Color, Repeated Words
                uncapitalizedWordColor = UIColors.green;    // Color, Uncapitalized Words
                uncapitalizedSentenceColor = UIColors.green;    // Color, Uncapitalized Sentences
            //Autocorrect preference panel
            with(app.autoCorrectPreferences){
                autoCorrect = true;                            // Enable Autocorrect
                autoCorrectCapitalizationErrors = false;    // Autocorrect Capitalization
            // Missing (Language, Misspelled word pairs)
            //Display Performance preference panel
            with(app.displayPerformancePreferences){
                defaultDisplaySettings = ViewDisplaySettings.typical;    // Preserve Object-Level
                persistLocalSettings = false;
            // Missing (antialiasiing, greek below
            //Story Editor Display preference panel
            with(app.galleyPreferences){
                textColor = InCopyUIColors.black;                // Text Color
                backgroundColor = InCopyUIColors.white;            // Background
                smoothText = true;                                // Enable Anti-Aliasing
                antiAliasType = AntiAliasType.grayAntialiasing;    // Type
                cursorType = CursorTypes.standardCursor;    // Cursor Type
                blinkCursor = true;                                // Blink
            // Missing (Font, Size, Line Spacing & Theme)
            //File Handling preference panel
                includePreview = true;                        // Always Save Preview Images with Doc
                previewSize = PreviewSizeOptions.medium;    // Preview Size
            with(app.clipboardPreferences){
                preferPDFWhenPasting = false;                // Prefer PDF When Pasting
                copyPDFToClipboard = true;                    // Copy PDF to Clipboard
                preservePdfClipboardAtQuit = false;            // Preserve PDF Data at Quit
            // Missing (Enable Version Cue)
            //    Optical margin (hanging punctuation, outside margins)
            with(app.storyPreferences){
                opticalMarginAlignment = false;
                opticalMarginSize = 12;                // pts
            //Wrap Up (do at end of script)
                horizontalMeasurementUnits = MeasurementUnits.picas;    // Ruler Units, horizontal
            • 3. Re: Code in jsx script to set Object Editing value
              absqua Level 4
              Whew! You guys are serious about your preferences. You should insert the new one in the with block that starts at line 154:
              • 4. Re: Code in jsx script to set Object Editing value
                jwilheim Level 1
                Thanks for all your help. Our company writes software in Java that integrates with InDesign (or QuarkXPress) for selling and making the content of newspaper advertising -- everything from a single-line, text-only ad in the classifieds to double-truck, full-page ads for car dealers. We lock down the preferences for maximum efficiency with what our users do.
                • 5. Re: Code in jsx script to set Object Editing value
                  CoverBuilder Level 1
                  If
                  Then
                      hyphenateWordsLongerThan = 5; // Will/Shoule be 7 right?
