2 Replies Latest reply: Feb 4, 2012 2:13 PM by BradKaye RSS
    Feature Request: Export catalog for 2nd editor/machine
    BradKaye Community Member
      Since there isn't a shared network environment for LR, to involve multiple editors or multiple locations for the same editor on large projects, I often need to export a subset of a catalog so someone else can work on it, or I can work on it off my laptop somewhere other than the studio, using only the proxy 1:1 previews to make my decisions from and then re-assimilate those edit changes to the master catalog of that job, usually back on my primary workstation.  This process also allows me to start processing out parts of the job while other parts are being edited on other machines, or letting my primary workstation process while I use a 2nd workstation to continue editing at speed on.
      I can make this happen, but it's all on me to remember which portions of the catalog have been exported, where their destination was/is, remember not to make any changes to that portion of the library while the subsection has been exported, and an over-lengthy and complicated merging of exported and internal catalogs.
      It would be incredibly useful if LR could show the status (checked out for primary edit, checked out for client approval, etc.) of any exported catalog by mousing over that visibly different section and build in a preference for those varied conditions to potentially limit any changes to that subset of images while the export is still 'checked-out.'  A true merge would be nice to allow possible overlaps of work on the same images, but a managed lock-out would be sufficient to start with.
      As it is, the re-assimilation process for me involves removing images from the master catalog leaving the raw files in place, and re-importing the exported catalog which also necessitates the needless redundancy of bringing the 1:1 previews back in as well.  At the scale I'm doing this it's overly time consuming, compared to the speed of just bringing in the library itself.  The process also puts me in the place of deleting images from a catalog while they're essentially still in use, which is scary from a file management standpoint, usually with me having 4 and 5 copies of that library lingering around until all the manual merging actions are finished.
