3 Replies Latest reply on Feb 3, 2012 9:18 PM by kglad
    Timeout / stop(); not functioning properly on timeline
    xcmuddman Level 1
      Its been a while! I am back at it again trying to "program" a small demo for a digital gauge for work.
      I have some sections that look for a (delayedAction) button press of >1 second or else it goes to a warning keyframe on the timeline. Once at the warning frame it stays for a couple seconds (slideIntervalNum) and then continues playing to the next frame which contains a variable telling it return to the initial frame it was at.
      IF the user taps the button for <1 while at the warning frame they back up another section in the timeline. This is all what i planned for but....
      my problem is that when the user consecutively hits the button for less than 1 sec and quickly moves back towards the beginning of the animation / timeline at some point something happens that makes it so that it does not want to obey the stop(); command at all!  It will keep playing forwards frame by frame when no action is taken. And even if a button press of >1 sec is executed to stop and go to the next frame it still wont obey the stop(); command!!!
      any suggestions??
      some of my code that i am using:
      //AT STARTUP:
      stop();
      var timeOut:Number;
      var currentFrame:String;
      thisFrame="enter_warning_init";
      function showNextSlide()
          clearInterval(slideIntervalNum);
          _root.play();
      slideIntervalNum = setInterval(showNextSlide, 100);
      //BUTTON Requiring >1 Press
      btn_mode.onPress = function()
          timeOut = setTimeout(delayedAction, 1000);
          btn_mode.onRelease = function()
              clearTimeout(timeOut);
              delete btn_mode.onRelease;
              gotoAndPlay("enter_warning_init");
      //BASIC CODE IN GENERIC WARNING SCREENS:
      stop();
      slideIntervalNum = setInterval(showNextSlide, 1000);
      var timeOut:Number;
              AudibleBeep1 = new Sound(this);
              AudibleBeep1.attachSound(btnPressBeep);
              AudibleBeep1.start(0, 1);
              gotoAndPlay("initialization_yes");
              function delayedAction()
              gotoAndStop(thisFrame);
      //please help!!! thank you!
        • 1. Re: Timeout / stop(); not functioning properly on timeline
          you should clear every interval before setting it to prevent run-away intervals that can't be controlled:
          //AT STARTUP:
          stop();
          var slideIntervalNum:Number;
          var timeOut:Number;
              _root.play();
          //BASIC CODE IN GENERIC WARNING SCREENS:  <- this must be in a different scope than the above code or you have problems.
          stop();
          var timeOut:Number;
          • 2. Re: Timeout / stop(); not functioning properly on timeline
            xcmuddman Level 1
            Thanks KGLAD. I missed you!!!
