11 Replies Latest reply on Mar 12, 2012 10:40 PM by John Hawkinson
    Indesign quit or Out of memory when exporting or printing pdf.
    matthewvh
      Hi i have a mac Pro, 2x 2.26 GHZ Quad Core Intel- Xeon with 6GB 1066 MHz DDR3 running 10.6.8 and Adobe Design Premium.
      when using Indesign and printing pdfs or exporting to pdf Indesign comes up with an "out of memory" or quits unexpectedly, please can someone explain why this would happen?
      i have tested the ram/ reformated and reinstalled OSX 10.6.8 and Adobe but still this issue arises.
        • 1. Re: Indesign quit or Out of memory when exporting or printing pdf.
          lilia@ Level 2
          have you tried trashing your preferences?
          • 2. Re: Indesign quit or Out of memory when exporting or printing pdf.
            matthewvh Level 1
            I have trashed all preferences, and as a 2nd last resort i tried reinstalling just Adobe indesign and not the whole suite with no luck!!!
            • 3. Re: Indesign quit or Out of memory when exporting or printing pdf.
              Michael Gianino Level 4
              You could try cleaning out your font cache.
              • 4. Re: Indesign quit or Out of memory when exporting or printing pdf.
                Out of Memory messages when processing PDF are not all that uncommon, unfortunately. I vaguely remember John having had something to say about it (besides considering it a bug) -- he's our resident Mac OS developer expert -- but for the life of me I can't remember what. You could try increasing the memory allocation or virtual memory for ID (sorry to be so vague, I'm a windows guy), but ultimately the usual advice when this happens is to see if the file will export in pieces, and if the entire thing will export that way, jsut combine them in Acrobat. If you find a particular page that won't export, even by itself, there's somthing onthat page that is causing the problem, so you need to remove objects until you isolate which one it is.
                • 5. Re: Indesign quit or Out of memory when exporting or printing pdf.
                  John Hawkinson Level 5
                  I probably said that it was a bug and not actually an out-of-memory condition.
                  In today's modern systems, it's really hard for software to make memory demands that are not easily achievable.
                  I think the key here is:
                  Matthew, please upload the crash report from the "unexpected quit" to http://pastebin.com/ and post a link here for us to look at.
                  Something's clearly wrong. Presumably with one of your PDF files or perhaps your InDesign document. What patch level of InDesign are you using? Have you exported your document to IDML and re-opened it?
                  • 6. Re: Indesign quit or Out of memory when exporting or printing pdf.
                    Marijan Tompa [tomaxxi] Level 4
                    matthewvh wrote:
                    ...when using Indesign and printing pdfs or exporting to pdf...
                    So, you are exporting/printing placed PDF-s from InDesign? From my experience, these crashes are caused by images/elements with extreme resolution inside those PDF-s. Best example is drop shadow which was scaled down, or big bitmap logo also scaled down extremely. These images/bitmaps usually are over 1000ppi, depending on original scale, and some of them are even higher. I had same experience few times and found few drop shadows inside PDF in over 5000ppi. After I resampled them to 300-600ppi, export/print went without any problem.
                    Hope that helps.
                    Marijan (tomaxxi)
                    http://tomaxxi.com
                    • 7. Re: Indesign quit or Out of memory when exporting or printing pdf.
                      matthewvh Level 1
                      Hello John,
                      I am creating an Indesign File with various art work, Images and Vector graphics and text then exporting to PDF and or Print the PDFS.
                      I can not use Pastbin but here are the errors from Console that i could find:
                      I am using The latest patch update Indesign 6.0.6 i thought the update would fix the issue but it has not.
                      Please could someone help me urgently!!!
                      Feb  5 00:30:00 hifi02s-Mac-Pro newsyslog[2888]: logfile turned over
                      Feb  5 00:52:42 hifi02s-Mac-Pro ntpd[26]: time reset +0.186240 s
                      Feb  5 01:45:57 hifi02s-Mac-Pro loginwindow[37]: loginwindow SleepWakeCallback WILL sleep
                      Feb  5 10:43:20 hifi02s-Mac-Pro loginwindow[37]: loginwindow SleepWakeCallback will power on, Currenttime:2/5/2012 10:43:20.010 AM - Waketime:2/5/2012 10:43:18.840 AM = Deltatime:1.169763982
                      Feb  5 10:43:27 hifi02s-Mac-Pro configd[13]: Sleep: Success - AC - Idle Sleep
                      Feb  5 10:43:27 hifi02s-Mac-Pro configd[13]: Wake: Success - AC - EHC1
                      Feb  5 10:43:27 hifi02s-Mac-Pro configd[13]: Hibernate Statistics
                      Feb  5 10:43:27 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 10:43:27: --- last message repeated 1 time ---
                      Feb  5 10:43:27 hifi02s-Mac-Pro defaults[3429]: \nThe domain/default pair of (com.apple.kexts.32bitonly, lastRan) does not exist
                      Feb  5 10:43:30 hifi02s-Mac-Pro mDNSResponder[36]: RegisterInterface: Frequent transitions for interface en0 (FE80:0000:0000:0000:0225:00FF:FEF3:7959)
                      Feb  5 10:43:30 hifi02s-Mac-Pro syslog[3471]: com.acard.driver.ACard6280ATA    1.0.5    ACard6280ATA    /System/Library/Extensions/ACard6280ATA.kext    ACARD AEC-6280M ATA Driver 1.0.5    no    yes
                      Feb  5 10:43:30 hifi02s-Mac-Pro syslog[3472]: com.acard.driver.ACard62xxM    2.0.6    ACard62xxM    /System/Library/Extensions/ACard62xxM.kext    ACARD AEC-62XX Driver V2.0.6    no    yes
                      Feb  5 10:43:30 hifi02s-Mac-Pro syslog[3473]: com.acard.driver.ACard67162    2.0.3    ACard67162    /System/Library/Extensions/ACard67162.kext    2.0.3    no    yes
                      Feb  5 10:43:30 hifi02s-Mac-Pro syslog[3474]: com.acard.driver.ACard671xSCSI    2.0.1    ACard671xSCSI    /System/Library/Extensions/ACard671xSCSI.kext    2.0.1    no    yes
                      Feb  5 10:43:30 hifi02s-Mac-Pro syslog[3475]: com.acard.driver.ACard6885M    2.0.6    ACard6885M    /System/Library/Extensions/ACard6885M.kext    ACARD AEC-6885/95/96 Driver V2.0.6    no    yes
                      Feb  5 10:43:30 hifi02s-Mac-Pro syslog[3476]: com.acard.driver.ACard68xxM    2.0.5    ACard68xxM    /System/Library/Extensions/ACard68xxM.kext    ACARD AEC-68XX Driver V 2.0.5    no    yes
                      Feb  5 10:43:30 hifi02s-Mac-Pro syslog[3477]: com.jmicron.JMicronATA    1.0.0    JMicron JMB ATA Driver    /System/Library/Extensions/JMicronATA.kext    1.0.0, Copyright JMicron Technology    no    yes
                      Feb  5 10:43:46 hifi02s-Mac-Pro ntpd[26]: time reset +0.703301 s
                      Feb  5 10:43:51 hifi02s-Mac-Pro loginwindow[37]: no spins reported for this wake
                      Feb  5 11:35:37 hifi02s-Mac-Pro SecurityAgent[3823]: system.privilege.admin|2012-02-05 11:35:37 +0200
                      Feb  5 11:35:44 hifi02s-Mac-Pro authexec[3828]: executing /Applications/Utilities/Adobe Utilities.localized/Adobe Updater6/Adobe Updater.app/Contents/Resources/AdobeUpdaterInstallMgr
                      Feb  5 11:36:00 hifi02s-Mac-Pro hdiejectd[3837]: running
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 38
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      Feb  5 11:36:03 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:36:04 hifi02s-Mac-Pro defaults[3861]: \nThe domain/default pair of (/Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/RegExList, 1) does not exist
                      Feb  5 11:36:04 hifi02s-Mac-Pro authexec[3862]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:36:05 hifi02s-Mac-Pro authexec[3926]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:36:13 hifi02s-Mac-Pro hdiejectd[3837]: quitCheck: calling exit(0)
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Adobe SelfHealing
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  Error:  shmFSCopyObjectFailed in line 949 of file /Volumes/Bu
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ildDisk_mbs73/Acro_root_nsd/Common/SelfHealin
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: gSDK/Source/src/MoverCFMP.cp.
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Acrobat SelfHea
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ling Error:  Copy failed for:
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Contents/MacOS/SelfHealFi
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: les/Library/Automator/Save As Adobe PDF.a
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ction
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ling Error:  shmFSCopyObjectFailed in line 94
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: 9 of file /Volumes/BuildDisk_mbs73/Acr
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: o_root_nsd/Common/SelfHealingSDK/Source/sr
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: c/MoverCFMP.cp.
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Acrobat SelfHealing Error:
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:   Copy failed for:
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: cOS/SelfHealFiles/Library/Autom
                      Feb  5 11:36:21 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ator/Save As Adobe PDF.action
                      Feb  5 11:36:21 hifi02s-Mac-Pro authexec[4464]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Adobe SelfHealing Error:  shmFSCopyObjectFailed in line 949 of file /
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Volumes/BuildDisk_mbs73/Acro_root_nsd/Common/SelfHealingSDK/Source/src/MoverCFMP.cp.
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Acrobat SelfHealing Error:  Copy failed for:
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Contents/MacOS/
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: SelfHealFiles/Library/Automator/Save As Adobe PDF.action
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObjectFailed in line 949 of file /Vo
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: lumes/BuildDisk_mbs73/Acro_root_ns
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: d/Common/SelfHealingSDK/Source/src/M
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: overCFMP.cp.
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  SelfHealing Error:  Copy failed for:
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Contents/MacOS/SelfHealFi
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: les/Library/Automator/Save As A
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: dobe PDF.action
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: aling Error:  shmFSCopyObjectFailed in line 949 of
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  file /Volumes/BuildDisk_mbs73/Acro
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: _root_nsd/Common/SelfHealingSDK/Sour
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ce/src/MoverCFMP.cp.
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  Copy failed for:
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: s/MacOS/SelfHealFiles/Libra
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ry/Automator/Save As Adobe PD
                      Feb  5 11:37:30 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: F.action
                      Feb  5 11:37:30 hifi02s-Mac-Pro hdiejectd[6190]: running
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 69 folders were found
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 37
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:32 hifi02s-Mac-Pro defaults[6213]: \nThe domain/default pair of (/Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/RegExList, 1) does not exist
                      Feb  5 11:37:32 hifi02s-Mac-Pro authexec[6214]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:37:32 hifi02s-Mac-Pro authexec[6227]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Adobe SelfHealing Error:  shmFSCopyObjectFailed in lin
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: e 949 of file /Volumes/BuildDisk_mbs73/Acro_root_nsd/Common/SelfHealingSDK/Source/src/MoverCFMP.cp.
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Acrobat SelfHealing Error:  Copy failed for:
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Contents/MacOS/SelfHealFiles/Library/Au
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: tomator/Save As Adobe PDF.action
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ealing Error:  shmFSCopyObjectFailed
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  in line 949 of file /Volumes/BuildDisk_mbs73/Acro_ro
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ot_nsd/Common/SelfHealingSDK/Source
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: /src/MoverCFMP.cp.
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: robat SelfHealing Error:  Copy failed f
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: or:
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Files/Library/Automator/Sav
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: e As Adobe PDF.action
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ealing Error:  shmFSCopyObjectFailed in line 949
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  of file /Volumes/BuildDisk_mbs73/A
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: cro_root_nsd/Common/SelfHealingSDK/Source/src/MoverCFM
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: P.cp.
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Healing Error:  Copy failed for:
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: s/Library/Automator/Save As
                      Feb  5 11:37:34 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Adobe PDF.action
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  FSGetCatalogInfoBulk: 3
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 69 folders were found
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: : 2
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 37
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:35 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/Ma
                      Feb  5 11:37:36 hifi02s-Mac-Pro defaults[6286]: \nThe domain/default pair of (/Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/RegExList, 1) does not exist
                      Feb  5 11:37:36 hifi02s-Mac-Pro authexec[6287]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:37:36 hifi02s-Mac-Pro authexec[6300]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Adobe SelfHeali
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ng Error:  shmFSCopyObjectFailed in line 949 of file /Volumes/Bui
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ldDisk_mbs73/Acro_root_nsd/Common/
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: SelfHealingSDK/Source/src/MoverCFMP.cp.
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Acrobat
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: SelfHealing Error:  Copy failed for:
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: C
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ontents/MacOS/SelfHealFiles/Library/Automato
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: r/Save As Adobe PDF.action
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ealing Error:  shmFSCopyObjectFailed in line 949 of
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  file /Volumes/BuildDisk_mbs73/Acro
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: _root_nsd/Common/SelfHealingSDK/So
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: urce/src/MoverCFMP.cp.
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Acrobat SelfHealing Error:  Copy failed fo
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: r:
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Contents/MacOS/SelfHealFiles/Libra
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ry/Automator/Save As Adobe PDF.action
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: aling Error:  shmFSCopyObjectFailed in li
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ne 949 of file /Volumes/BuildDisk_mbs73/A
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: cro_root_nsd/Common/SelfHealingSDK/Source/src/Move
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: rCFMP.cp.
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ling Error:  Copy failed for:
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: tents/MacOS/SelfHealFiles/Library/Automat
                      Feb  5 11:37:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: or/Save As Adobe PDF.action
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: inMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 69 folders were found
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/MacOS
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 37
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      Feb  5 11:37:47 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:37:47 hifi02s-Mac-Pro defaults[6566]: \nThe domain/default pair of (/Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/RegExList, 1) does not exist
                      Feb  5 11:37:47 hifi02s-Mac-Pro authexec[6567]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:37:47 hifi02s-Mac-Pro authexec[6580]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Adobe SelfHealing Error:  shmFSCopyObjectFailed in lin
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: e 949 of file /Volumes/BuildDisk_mbs73/Acro_root_nsd/Common/SelfHealingSDK/Source/src/MoverCFMP.cp.
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Acrobat SelfHealing Error:  Copy failed for:
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Contents/MacOS/SelfHealFiles/Library/Automator/Save As Ado
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: be PDF.action
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: fHealing Error:  shmFSCopyObjectFaile
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: d in line 949 of file /Volumes/BuildDi
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: sk_mbs73/Acro_root_nsd/Common/SelfHeal
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ingSDK/Source/src/MoverCFMP.cp.
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: failed for:
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: brary/Automator/Save As Adobe PDF.act
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ion
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: lfHealing Error:  shmFSCopyObjectFai
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: led in line 949 of file /Volumes/B
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: uildDisk_mbs73/Acro_root_nsd/Comm
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: on/SelfHealingSDK/Source/src/Mov
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: erCFMP.cp.
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: elfHealing Error:  Copy failed for
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: :
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ibrary/Automator/Save As Adobe
                      Feb  5 11:37:49 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: PDF.action
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: p/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd913_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 69 folders were found
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions/A
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A/Frameworks
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A/Frameworks/adobe_caps.framework
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps.framework
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A/Frameworks/adobe_caps.framework/Versions
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps.framework/Version s
                      Feb  5 11:37:53 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A/Frameworks/adobe_caps.framework/Versions/A
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: bat9pro-EFG/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions /A/Frameworks/adobe_caps.framework/Versions/A
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A/Frameworks/adobe_caps.framework/Versions/A/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps.framework/Version s/A/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A/Frameworks/adobe_caps.framework/Versions/A/Resources/English.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps.framework/Version s/A/Resources/English.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/AdobeSelfHealing.fra mework/Versions/A/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/InstallerResults.fra mework
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/InstallerResults.framework
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/InstallerResults.fra mework/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/InstallerResults.framework/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/InstallerResults.fra mework/Versions
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/InstallerResults.fra mework/Versions/A
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/InstallerResults.fra mework/Versions/A/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/InstallerResults.fra mework/Versions/Current
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/InstallerResults.framework/Versions/Current
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Frameworks/InstallerResults.fra mework/Versions/Current/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/MacOS
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/MacOS
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 38
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/cs.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/cs.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/cs.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/da.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/da.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/da.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/de.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/de.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/de.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/English.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/English.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/English.lproj/MainMen u.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/es.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/es.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/es.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/eulas
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/eulas
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/eulas/html
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/eulas/html
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/eulas/html/en_US
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/eulas/html/en_US
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/fi.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/fi.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/fi.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/fr.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/fr.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/fr.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/hu.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/hu.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/hu.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/it.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/it.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/it.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ja.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ja.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ja.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ko.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ko.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ko.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/nl.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/nl.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/nl.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/no.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/no.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/no.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/pl.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/pl.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/pl.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/pt.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/pt.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/pt.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ro.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ro.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ro.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ru.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ru.lproj
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/ru.lproj/MainMenu.nib
                      Feb  5 11:37:55 hifi02s-Mac-Pro authexec[6632]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/InstallUpdates.sh
                      Feb  5 11:37:56 hifi02s-Mac-Pro authexec[6645]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/InstallUpdates.sh
                      Feb  5 11:38:05 hifi02s-Mac-Pro hdiejectd[6190]: quitCheck: calling exit(0)
                      Feb  5 11:38:06 hifi02s-Mac-Pro authexec[6820]: executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/InstallUpdates.sh
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Entering PostApp
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Parsed params
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: /remv /restartFile
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Parsed cmd line
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Deleting RV file
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Launching urls in restart file
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: Destroying
                      Feb  5 11:38:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: strings
                      Feb  5 11:38:47 hifi02s-Mac-Pro hdiejectd[7868]: running
                      Feb  5 11:38:50 hifi02s-Mac-Pro authexec[7881]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:38:58 hifi02s-Mac-Pro hdiejectd[7868]: quitCheck: calling exit(0)
                      Feb  5 11:39:03 hifi02s-Mac-Pro authexec[7903]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:39:07 hifi02s-Mac-Pro hdiejectd[7911]: running
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: cts retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/sv.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/sv.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/sv.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/tr.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/tr.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/tr.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/uk.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/uk.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/uk.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/zh_CN.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/zh_CN.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/zh_CN.lproj/MainMenu. nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/zh_CN.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/zh_TW.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/zh_TW.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AcroProUpd920_all/AcroProUpd920_all.app/Contents/Resources/zh_TW.lproj/MainMenu. nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/AcroProUpd920_all.app/Content s/Resources/zh_TW.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 69 folders were found
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/extensions
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/extensions
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/extensions/AdobeCSIAll-131108070529
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/extensions/AdobeCSIAll-1311 08070529
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/extensions/AdobeDriveAll-131108070613
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/extensions/AdobeDriveAll-13 1108070613
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/extensions/AdobeExtensionManager2All-2 01108113541
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/extensions/AdobeExtensionMa nager2All-201108113541
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 4 folders were found
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 7
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/common
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/common
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/common/alert1
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/common/alert1
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/common/error
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/common/error
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/common/scripts
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/common/scripts
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/media
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/media
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/media/css
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/media/css
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/media/img
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/media/img
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 12
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/pages
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/pages
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/resources/scripts
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/resources/scripts
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 8
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 10 folders were found
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 6
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Framewor ks
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/Installe rResults.framework
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Framewor ks/InstallerResults.framework
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/Installe rResults.framework/Versions
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Framewor ks/InstallerResults.framework/Versions
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/Installe rResults.framework/Versions/A
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Framewor ks/InstallerResults.framework/Versions/A
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/Installe rResults.framework/Versions/A/Resources
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Framewor ks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/MacOS
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/MacOS
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lpr oj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/en_US.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lpr oj/DHTMLAlert.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/en_US.lproj/DHTMLAlert.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lpr oj/DHTMLAlert~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/en_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lpr oj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/en_US.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lpr oj/MainMenu~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/en_US.lproj/MainMenu~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.l proj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/English.lproj
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.l proj/DHTMLAlert.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/English.lproj/DHTMLAlert.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.l proj/DHTMLAlert~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/English.lproj/DHTMLAlert~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.l proj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/English.lproj/MainMenu.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.l proj/MainMenu~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/Resource s/English.lproj/MainMenu~.nib
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeExtensionManager-2.1-mul-AdobeUpdate/Setup.app/Contents/SharedSupport
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/extensionmanager2/Setup.app/Contents/SharedSu pport
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 20 folders were found
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/.fseventsd
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/.fseventsd
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 1 folders were found
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/extensions
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/extensions
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/extensions/AdobeCameraRaw5.0All-070410040127
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/extensions/AdobeCameraRaw5.0All-07 0410040127
                      Feb  5 11:39:16 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 2 folders were found
                      Feb  5 11:39:17 hifi02s-Mac-Pro authexec[7940]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:39:26 hifi02s-Mac-Pro hdiejectd[7911]: quitCheck: calling exit(0)
                      Feb  5 11:39:44 hifi02s-Mac-Pro hdiejectd[7967]: running
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:  wantSpec: yes, wantName: yes,
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 7
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/common
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/common
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/common/alert1
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/common/alert1
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/common/error
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/common/error
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/common/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/common/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/media
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/media
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/media/css
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/media/css
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/media/img
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/media/img
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 11
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/pages
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/pages
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/resources/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/resources/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 8
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 10 folders were found
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 6
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Frameworks
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Frameworks
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerResult s.framework
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Frameworks/Inst allerResults.framework
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerResult s.framework/Versions
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Frameworks/Inst allerResults.framework/Versions
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerResult s.framework/Versions/A
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Frameworks/Inst allerResults.framework/Versions/A
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerResult s.framework/Versions/A/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Frameworks/Inst allerResults.framework/Versions/A/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/MacOS
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/MacOS
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/en_US .lproj
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/DHTM LAlert.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/en_US .lproj/DHTMLAlert.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/DHTM LAlert~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/en_US .lproj/DHTMLAlert~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/Main Menu.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/en_US .lproj/MainMenu.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/Main Menu~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/en_US .lproj/MainMenu~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/Engli sh.lproj
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj/DH TMLAlert.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/Engli sh.lproj/DHTMLAlert.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj/DH TMLAlert~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/Engli sh.lproj/DHTMLAlert~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj/Ma inMenu.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/Engli sh.lproj/MainMenu.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj/Ma inMenu~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/Resources/Engli sh.lproj/MainMenu~.nib
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeCameraRaw-5.7-mul-AdobeUpdate/Setup.app/Contents/SharedSupport
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/cameraraw5/Setup.app/Contents/SharedSupport
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 20 folders were found
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/extensions
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/extensions
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/extensions/AdobeOutputModuleAll-2111081718 24
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/extensions/AdobeOutputModuleAll -211108171824
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 2 folders were found
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/common
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/common
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/common/alert1
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/common/alert1
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/common/error
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/common/error
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/common/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/common/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/media
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/media
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/media/css
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/media/css
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/media/img
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/media/img
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/pages
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/pages
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/resources/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/resources/scripts
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Frameworks
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerRes ults.framework
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Frameworks/I nstallerResults.framework
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerRes ults.framework/Versions
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Frameworks/I nstallerResults.framework/Versions
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerRes ults.framework/Versions/A
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Frameworks/I nstallerResults.framework/Versions/A
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Frameworks/InstallerRes ults.framework/Versions/A/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Frameworks/I nstallerResults.framework/Versions/A/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/MacOS
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/MacOS
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources
                      Feb  5 11:39:45 hifi02s-Mac-Pro authexec[7978]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:39:55 hifi02s-Mac-Pro hdiejectd[7967]: quitCheck: calling exit(0)
                      Feb  5 11:39:57 hifi02s-Mac-Pro hdiejectd[8166]: running
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: bjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/en _US.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/D HTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/en _US.lproj/DHTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/D HTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/en _US.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/M ainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/en _US.lproj/MainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/en_US.lproj/M ainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/en _US.lproj/MainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/En glish.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj /DHTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/En glish.lproj/DHTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj /DHTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/En glish.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj /MainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/En glish.lproj/MainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/Resources/English.lproj /MainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/Resources/En glish.lproj/MainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/AdobeOutputModule-2.1-mul-AdobeUpdate/Setup.app/Contents/SharedSupport
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/mediagallery2/Setup.app/Contents/SharedSuppor t
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 20 folders were found
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/extensions
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/extensions
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/extensions/AdobeCSIAll-131108070529
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/extensions/Ad obeCSIAll-131108070529
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 6
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/extensions/AdobeDriveAll-131108070613
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/extensions/Ad obeDriveAll-131108070613
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 3 folders were found
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 7
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/common
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/com mon
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/common/alert1
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/com mon/alert1
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/common/error
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/com mon/error
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/common/scripts
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/com mon/scripts
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/media
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/med ia
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/media/css
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/med ia/css
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/media/img
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/med ia/img
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 12
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/pages
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/pag es
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/resources/scripts
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/resources/scr ipts
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 8
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 10 folders were found
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Frameworks
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Frameworks
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Frameworks/InstallerResults.framework
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions/A/ Resources
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/MacOS
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/MacOS
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/en_US.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/en_US.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/en_US.lproj/DHTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/en_US.lproj/DHTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/en_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/en_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/en_US.lproj/MainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/en_US.lproj/MainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/en_US.lproj/MainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/en_US.lproj/MainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/English.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/English.lproj
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/English.lproj/DHTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/English.lproj/DHTMLAlert.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/English.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/English.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/Resources/English.lproj/MainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/Resources/English.lproj/MainMenu~.nib
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Patch-Drive/Setup.app/Contents/SharedSupport
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/creativeservicesinfrastructure1/Setup.app/Con tents/SharedSupport
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 15
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-cs_CZL anguagePack-111108055133
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-cs_CZLanguagePack-111108055133
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-de_DEL anguagePack-121108142220
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-de_DELanguagePack-121108142220
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-it_ITL anguagePack-121108143517
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-it_ITLanguagePack-121108143517
                      Feb  5 11:40:02 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-j
                      Feb  5 11:40:05 hifi02s-Mac-Pro authexec[8194]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:40:13 hifi02s-Mac-Pro hdiejectd[8166]: quitCheck: calling exit(0)
                      Feb  5 11:40:35 hifi02s-Mac-Pro authexec[8217]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:40:39 hifi02s-Mac-Pro hdiejectd[8226]: running
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: a_JPLanguagePack-121108141628
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-ja_JPLanguagePack-121108141628
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-mul-27 0409161853
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-mul-270409161853
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-nl_NLL anguagePack-121108143310
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-nl_NLLanguagePack-121108143310
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-pl_PLL anguagePack-111108055820
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-pl_PLLanguagePack-111108055820
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-pt_BRL anguagePack-121108142432
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-pt_BRLanguagePack-121108142432
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-ru_RUL anguagePack-111108054854
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-ru_RULanguagePack-111108054854
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-STI-en -071108053505
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-STI-en-071108053505
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-STI-es -121108142013
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-STI-es-121108142013
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-STI-fr -121108141821
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-STI-fr-121108141821
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-sv_SEL anguagePack-121108142641
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-sv_SELanguagePack-121108142641
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/extensions/AdobeFlash10-tr_TRL anguagePack-111108060030
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/extensions/A dobeFlash10-tr_TRLanguagePack-111108060030
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 7
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/common
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/co mmon
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/common/alert1
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/co mmon/alert1
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/common/error
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/co mmon/error
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/common/scripts
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/co mmon/scripts
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/media
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/me dia
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/media/css
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/me dia/css
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/media/img
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/me dia/img
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 12
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/pages
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/pa ges
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/resources/scripts
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/resources/sc ripts
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 8
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 6
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Frameworks
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Frameworks
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Frameworks/ InstallerResults.framework
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Frameworks/InstallerResults.framework
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Frameworks/ InstallerResults.framework/Versions
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Frameworks/ InstallerResults.framework/Versions/A
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Frameworks/ InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/MacOS
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/MacOS
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/e n_US.lproj
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/en_US.lproj
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/e n_US.lproj/DHTMLAlert.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/en_US.lproj/DHTMLAlert.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/e n_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/en_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/e n_US.lproj/MainMenu.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/en_US.lproj/MainMenu.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/e n_US.lproj/MainMenu~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/en_US.lproj/MainMenu~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/E nglish.lproj
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/English.lproj
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/E nglish.lproj/DHTMLAlert.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/English.lproj/DHTMLAlert.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/E nglish.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/English.lproj/DHTMLAlert~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/E nglish.lproj/MainMenu.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/Resources/E nglish.lproj/MainMenu~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/Resources/English.lproj/MainMenu~.nib
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Flash-10.0.2-AdobeUpdate/Flash-10.0.2-AdobeUpdate/Setup.app/Contents/SharedSuppo rt
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/flash10/Flash-10.0.2-AdobeUpdate/Setup.app/Co ntents/SharedSupport
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 46 folders were found
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/extensions
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/extensions
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/extensions/AdobePhotoshop11-Core-190510214628
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/extensions/AdobePhotoshop11-Core-190510214628
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/common
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/common
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/common/alert1
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/common/alert1
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/common/error
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/common/error
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/common/scripts
                      Feb  5 11:40:50 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/common/scripts
                      Feb  5 11:40:52 hifi02s-Mac-Pro authexec[8253]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:41:00 hifi02s-Mac-Pro hdiejectd[8226]: quitCheck: calling exit(0)
                      Feb  5 11:41:04 hifi02s-Mac-Pro hdiejectd[8278]: running
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: List -- Copying contents of
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/media
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/media
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/media/css
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/media/css
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/media/img
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/media/img
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 12
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/pages
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/pages
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/resources/scripts
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/resources/scripts
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 8
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 6
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Frameworks
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Frameworks
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/MacOS
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/MacOS
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/DHTMLAlert.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/DHTMLAlert.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/MainMenu.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/MainMenu.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/MainMenu~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/en_US.lproj/MainMenu~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/DHTMLAlert.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/DHTMLAlert.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/DHTMLAlert~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/DHTMLAlert~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/MainMenu~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/Resources/English.lproj/MainMenu~.nib
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/Photoshop_11.0.2_mul_AdobeUpdate/Adobe Photoshop CS4/Setup.app/Contents/SharedSupport
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/photoshop11/Adobe Photoshop CS4/Setup.app/Contents/SharedSupport
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 33 folders were found
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 dupeAction: replace, wantSpec: yes, wantName: yes,
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:                 isDropBox: no, PBHCopyFileSync supported: no
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 27
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppBase -mul-051010083109
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppBase-mul-051010083109
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppFSet -Japan-051010083257
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppFSet-Japan-051010083257
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppFSet -Roman-051010083334
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppFSet-Roman-051010083334
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -cs_CZ-051010081332
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-cs_CZ-051010081332
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -da_DK-051010081415
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-da_DK-051010081415
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -de_DE-051010081456
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-de_DE-051010081456
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -en_GB-051010081536
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-en_GB-051010081536
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -en_US-051010081617
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-en_US-051010081617
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -es_ES-051010081657
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-es_ES-051010081657
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -es_MX-051010081739
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-es_MX-051010081739
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -fi_FI-051010081819
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-fi_FI-051010081819
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -fr_CA-051010081900
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-fr_CA-051010081900
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -fr_FR-051010081942
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-fr_FR-051010081942
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -hu_HU-051010082022
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-hu_HU-051010082022
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -it_IT-051010082104
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-it_IT-051010082104
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -ja_JP-051010082145
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-ja_JP-051010082145
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -ko_KR-051010082225
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-ko_KR-051010082225
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -nb_NO-051010082304
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-nb_NO-051010082304
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -nl_NL-051010082347
                      Feb  5 11:41:05 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-nl_NL-051010082347
                      Feb  5 11:41:16 hifi02s-Mac-Pro hdiejectd[8278]: quitCheck: calling exit(0)
                      Feb  5 11:41:17 hifi02s-Mac-Pro authexec[8295]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:41:22 hifi02s-Mac-Pro hdiejectd[8303]: running
                      Feb  5 11:41:32 hifi02s-Mac-Pro hdiejectd[8303]: quitCheck: calling exit(0)
                      Feb  5 11:41:36 hifi02s-Mac-Pro authexec[8316]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:41:40 hifi02s-Mac-Pro hdiejectd[8324]: running
                      Feb  5 11:41:42 hifi02s-Mac-Pro authexec[8335]: executing /Library/Application Support/Adobe/Installers/R2/Setup.app/Contents/MacOS/Setup
                      Feb  5 11:41:50 hifi02s-Mac-Pro hdiejectd[8324]: quitCheck: calling exit(0)
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: /AdobeInDesign6AppLang-pl_PL-051010082429
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:         to
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-pl_PL-051010082429
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: ProcessFolderList -- Copying contents of
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -pt_BR-051010082511
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-pt_BR-051010082511
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -ru_RU-051010082552
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-ru_RU-051010082552
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -sv_SE-051010082633
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-sv_SE-051010082633
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -tr_TR-051010082714
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-tr_TR-051010082714
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -uk_UA-051010082753
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-uk_UA-051010082753
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -zh_CN-051010082836
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-zh_CN-051010082836
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/extensions/AdobeInDesign6AppLang -zh_TW-051010082919
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/ext ensions/AdobeInDesign6AppLang-zh_TW-051010082919
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 7
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/common
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/common
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/common/alert1
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/common/alert1
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/common/error
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/common/error
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/common/scripts
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/common/scripts
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/media
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/media
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/media/css
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/media/css
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/media/img
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/media/img
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 12
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/pages
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/pages
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/resources/scripts
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/res ources/scripts
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 8
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 6
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Frameworks
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Frameworks
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Frameworks/In stallerResults.framework
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Frameworks/InstallerResults.framework
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Frameworks/In stallerResults.framework/Versions
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Frameworks/InstallerResults.framework/Versions
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Frameworks/In stallerResults.framework/Versions/A
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Frameworks/In stallerResults.framework/Versions/A/Resources
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/MacOS
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/MacOS
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/en_ US.lproj
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/en_US.lproj
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/en_ US.lproj/DHTMLAlert.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/en_US.lproj/DHTMLAlert.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/en_ US.lproj/DHTMLAlert~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/en_US.lproj/DHTMLAlert~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/en_ US.lproj/MainMenu.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/en_US.lproj/MainMenu.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/en_ US.lproj/MainMenu~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/en_US.lproj/MainMenu~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/Eng lish.lproj
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/English.lproj
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/Eng lish.lproj/DHTMLAlert.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/English.lproj/DHTMLAlert.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/Eng lish.lproj/DHTMLAlert~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/English.lproj/DHTMLAlert~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/Eng lish.lproj/MainMenu.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/English.lproj/MainMenu.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/Resources/Eng lish.lproj/MainMenu~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/Resources/English.lproj/MainMenu~.nib
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Volumes/InDesignCS4-AdobeUpdate/InDesignCS4-AdobeUpdate/Setup.app/Contents/SharedSupport
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]:     /Users/hifi02/Library/Caches/Adobe/Updater6/indesign6-RELEASE/InDesignCS4-AdobeUpdate/Set up.app/Contents/SharedSupport
                      Feb  5 11:42:11 hifi02s-Mac-Pro [0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: FSCopyFolder -- 59 folders were found
                      Feb  5 11:42:14 hifi02s-Mac-Pro com.apple.launchd[1] (com.apple.suhelperd[111]): Exited with exit code: 2
                      Feb  5 11:42:14 hifi02s-Mac-Pro com.apple.launchd.peruser.501[92] ([0x0-0xe00e].com.apple.SoftwareUpdate[140]): Exited: Killed
                      Feb  5 11:42:14 hifi02s-Mac-Pro SecurityAgent[3823]: NSDocumentController's invocation of -[NSFileManager URLForDirectory:inDomain:appropriateForURL:create:error:] returned nil for NSAutosavedInformationDirectory. Here's the error:\nError Domain=NSCocoaErrorDomain Code=513 UserInfo=0x10e500ec0 "You don’t have permission to save the file “Library” in the folder “empty”." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=13 "The operation couldn’t be completed. Permission denied")
                      Feb  5 11:42:14 hifi02s-Mac-Pro loginwindow[37]: DEAD_PROCESS: 37 console
                      Feb  5 11:42:14 hifi02s-Mac-Pro /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[8353]: Login Window Application Started
                      Feb  5 11:42:16 hifi02s-Mac-Pro loginwindow[8353]: USER_PROCESS: 8353 console
                      Feb  5 11:42:16 hifi02s-Mac-Pro WindowServer[8354]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 11:42:16 hifi02s-Mac-Pro com.apple.WindowServer[8354]: Sun Feb  5 11:42:16 hifi02s-Mac-Pro.local WindowServer[8354] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 11:42:17 hifi02s-Mac-Pro Software Update[8361]: Looking for products to install
                      Feb  5 11:42:17 hifi02s-Mac-Pro Software Update[8361]: Performing preflight
                      Feb  5 11:42:17 hifi02s-Mac-Pro Software Update[8361]: Preparing session
                      Feb  5 11:42:17 hifi02s-Mac-Pro Software Update[8361]: Starting session
                      Feb  5 11:42:18 hifi02s-Mac-Pro Software Update[8361]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:42:20 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.AirPortUtility"
                      Feb  5 11:42:23 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.JavaForMacOSX10.6"
                      Feb  5 11:42:26 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.Safari511SnowLeopard"
                      Feb  5 11:42:27 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.RemoteDesktopClient"
                      Feb  5 11:42:28 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.AppleMobileDeviceSupport"
                      Feb  5 11:42:29 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.CoreFP"
                      Feb  5 11:42:30 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.CoreFP1"
                      Feb  5 11:42:34 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.iTunesX"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: extracting "com.apple.pkg.iTunesAccess"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.AirPortUtility"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.JavaForMacOSX10.6"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.Safari511SnowLeopard"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.RemoteDesktopClient"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.AppleMobileDeviceSupport"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.CoreFP"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.CoreFP1"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.iTunesX"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-flight scripts for "com.apple.pkg.iTunesAccess"
                      Feb  5 11:42:35 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.AirPortUtility"
                      Feb  5 11:42:38 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.JavaForMacOSX10.6"
                      Feb  5 11:42:38 hifi02s-Mac-Pro pkgutil[8392]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:42:55 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.Safari511SnowLeopard"
                      Feb  5 11:42:55 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.RemoteDesktopClient"
                      Feb  5 11:42:55 hifi02s-Mac-Pro sudo[8443]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Au3cfX/Scripts/com.apple.pkg.AppleMobileDeviceSupport.D RWDCF ; USER=root ; COMMAND=/bin/launchctl unload //System/Library/LaunchDaemons/com.apple.usbmuxd.plist
                      Feb  5 11:42:55 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.AppleMobileDeviceSupport"
                      Feb  5 11:42:55 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.CoreFP"
                      Feb  5 11:42:55 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.CoreFP1"
                      Feb  5 11:42:58 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.iTunesX"
                      Feb  5 11:42:58 hifi02s-Mac-Pro Software Update[8361]: PKG: pre-install scripts for "com.apple.pkg.iTunesAccess"
                      Feb  5 11:43:48 hifi02s-Mac-Pro Software Update[8361]: REQ: moving files into place with shove
                      Feb  5 11:43:53 hifi02s-Mac-Pro com.apple.kextd[10]: Cache file /System/Library/Caches/com.apple.kext.caches/Directories//System/Library/Extensions/IOKit Personalities_i386.ioplist.gz is out of date; not using.
                      Feb  5 11:43:53 hifi02s-Mac-Pro com.apple.kextd[10]: Rescanning kernel extensions.
                      Feb  5 11:44:02 hifi02s-Mac-Pro com.apple.kextcache[8525]: JMicronATA.kext does not declare a kernel dependency; using com.apple.kernel.6.0.
                      Feb  5 11:44:10 hifi02s-Mac-Pro com.apple.kextcache[8525]: Created mkext archive //System/Library/Caches/com.apple.kext.caches/Startup/Extensions.mkext.
                      Feb  5 11:44:10 hifi02s-Mac-Pro com.apple.kextcache[8523]: /: no supported helper partitions to update.
                      Feb  5 11:44:10 hifi02s-Mac-Pro kextd[10]: updated kernel boot caches
                      Feb  5 11:44:10: --- last message repeated 1 time ---
                      Feb  5 11:44:10 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.AirPortUtility"
                      Feb  5 11:44:10 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.JavaForMacOSX10.6"
                      Feb  5 11:44:10 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.Safari511SnowLeopard"
                      Feb  5 11:44:11 hifi02s-Mac-Pro pkgutil[8568]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:15 hifi02s-Mac-Pro pkgutil[8570]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:16 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.RemoteDesktopClient"
                      Feb  5 11:44:16 hifi02s-Mac-Pro com.apple.kextd[10]: Rescanning kernel extensions.
                      Feb  5 11:44:16 hifi02s-Mac-Pro com.apple.kextd[10]: Cache file /System/Library/Caches/com.apple.kext.caches/Directories//System/Library/Extensions/KextI dentifiers.plist.gz is out of date; not using.
                      Feb  5 11:44:17 hifi02s-Mac-Pro com.apple.kextd[10]: Cache file /System/Library/Caches/com.apple.kext.caches/Directories//System/Library/Extensions/IOKit Personalities_i386.ioplist.gz is out of date; not using.
                      Feb  5 11:44:21 hifi02s-Mac-Pro sudo[8668]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Au3cfX/Scripts/com.apple.pkg.AppleMobileDeviceSupport.D RWDCF ; USER=root ; COMMAND=/bin/launchctl load //System/Library/LaunchDaemons/com.apple.usbmuxd.plist
                      Feb  5 11:44:21 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.AppleMobileDeviceSupport"
                      Feb  5 11:44:21 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.CoreFP"
                      Feb  5 11:44:21 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.CoreFP1"
                      Feb  5 11:44:21 hifi02s-Mac-Pro com.apple.usbmuxd[8669]: usbmuxd-263 on Nov 14 2011 at 18:58:10, running 64 bit
                      Feb  5 11:44:22 hifi02s-Mac-Pro com.apple.kextcache[8680]: JMicronATA.kext does not declare a kernel dependency; using com.apple.kernel.6.0.
                      Feb  5 11:44:26 hifi02s-Mac-Pro com.apple.kextcache[8680]: Created mkext archive //System/Library/Caches/com.apple.kext.caches/Startup/Extensions.mkext.
                      Feb  5 11:44:26 hifi02s-Mac-Pro com.apple.kextcache[8679]: /: no supported helper partitions to update.
                      Feb  5 11:44:26 hifi02s-Mac-Pro kextd[10]: updated kernel boot caches
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8707]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8708]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8709]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.iTunesX"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-install scripts for "com.apple.pkg.iTunesAccess"
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8733]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8734]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8735]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8736]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8737]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8738]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8739]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro pkgutil[8740]: PackageKit: *** Missing bundle identifier: /Library/Receipts/PPD_Installer_NRGC38U3.pkg
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.AirPortUtility"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.JavaForMacOSX10.6"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.Safari511SnowLeopard"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.RemoteDesktopClient"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.AppleMobileDeviceSupport"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.CoreFP"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.CoreFP1"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.iTunesX"
                      Feb  5 11:44:33 hifi02s-Mac-Pro Software Update[8361]: PKG: post-flight scripts for "com.apple.pkg.iTunesAccess"
                      Feb  5 11:44:34 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.AirPortUtility"
                      Feb  5 11:44:34 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.JavaForMacOSX10.6"
                      Feb  5 11:44:34 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.Safari511SnowLeopard"
                      Feb  5 11:44:34 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.RemoteDesktopClient"
                      Feb  5 11:44:35 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.AppleMobileDeviceSupport"
                      Feb  5 11:44:35 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.CoreFP"
                      Feb  5 11:44:35 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.CoreFP1"
                      Feb  5 11:44:35 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.iTunesX"
                      Feb  5 11:44:35 hifi02s-Mac-Pro Software Update[8361]: PKG: writing receipt for "com.apple.pkg.iTunesAccess"
                      Feb  5 11:44:35 hifi02s-Mac-Pro Software Update[8361]: REQ: install succeeded
                      Feb  5 11:44:36 hifi02s-Mac-Pro Software Update[8361]: SWU: installing "AirPort Utility, 5.5.3"
                      Feb  5 11:44:36 hifi02s-Mac-Pro Software Update[8361]: SWU: installing "Java for Mac OS X 10.6 Update 6, 6.0"
                      Feb  5 11:44:36 hifi02s-Mac-Pro Software Update[8361]: SWU: installing "Safari, 5.1.2"
                      Feb  5 11:44:36 hifi02s-Mac-Pro Software Update[8361]: SWU: installing "Remote Desktop Client Update, 3.5.2"
                      Feb  5 11:44:36 hifi02s-Mac-Pro Software Update[8361]: SWU: installing "iTunes, 10.5.3"
                      Feb  5 11:44:38 hifi02s-Mac-Pro [0x0-0x76076].com.apple.SoftwareUpdate[8361]: /: no supported helper partitions to update.
                      Feb  5 11:44:38 hifi02s-Mac-Pro kextd[10]: updated kernel boot caches
                      Feb  5 11:44:38 hifi02s-Mac-Pro Software Update[8361]: kextcache returned 0
                      Feb  5 11:44:38 hifi02s-Mac-Pro Software Update[8361]: Running /sbin/reboot
                      Feb  5 11:44:38 hifi02s-Mac-Pro reboot[8749]: rebooted by _spotlight
                      Feb  5 11:44:38 hifi02s-Mac-Pro reboot[8749]: BOOT_TIME: 1328435078 647042
                      Feb  5 11:44:38 hifi02s-Mac-Pro mDNSResponder[36]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) stopping
                      Feb  5 11:44:38 hifi02s-Mac-Pro DirectoryService[15]: BUG in libdispatch: 10K549 - 1960 - 0x10004004
                      Feb  5 11:44:38 hifi02s-Mac-Pro WindowServer[8354]: hidd died. Reestablishing connection.
                      Feb  5 11:44:38 hifi02s-Mac-Pro WindowServer[8354]: bootstrap_look_ip failed: Unknown service name
                      Feb  5 11:45:14 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
                      Feb  5 11:45:21 hifi02s-Mac-Pro configd[13]: setting hostname to "hifi02s-Mac-Pro.local"
                      Feb  5 11:45:21 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 11:45:22 hifi02s-Mac-Pro blued[16]: Apple Bluetooth daemon started
                      Feb  5 11:45:28 hifi02s-Mac-Pro bootlog[45]: BOOT_TIME: 1328435113 0
                      Feb  5 11:45:30 hifi02s-Mac-Pro com.apple.usbmuxd[26]: usbmuxd-263 on Nov 14 2011 at 18:58:10, running 64 bit
                      Feb  5 11:45:30 hifi02s-Mac-Pro mDNSResponder[33]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) starting
                      Feb  5 11:45:30 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 11:45:31: --- last message repeated 1 time ---
                      Feb  5 11:45:31 hifi02s-Mac-Pro /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[34]: Login Window Application Started
                      Feb  5 11:45:35 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 11:45:37 hifi02s-Mac-Pro loginwindow[34]: Login Window Started Security Agent
                      Feb  5 11:45:37 hifi02s-Mac-Pro loginwindow[34]: Login Window - Returned from Security Agent
                      Feb  5 11:45:37 hifi02s-Mac-Pro loginwindow[34]: USER_PROCESS: 34 console
                      Feb  5 11:45:37 hifi02s-Mac-Pro com.apple.launchd.peruser.501[87] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
                      Feb  5 11:45:40 hifi02s-Mac-Pro com.apple.launchd.peruser.501[87] (com.apple.Kerberos.renew.plist[109]): Exited with exit code: 1
                      Feb  5 11:45:45 hifi02s-Mac-Pro ntpd[23]: time reset -0.235850 s
                      Feb  5 11:47:12 hifi02s-Mac-Pro fontd[97]: query/build result time = 0.774296 sec
                      Feb  5 11:50:36 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x9001070 of class NSCFArray autoreleased with no pool in place - just leaking
                      Feb  5 11:50:36 hifi02s-Mac-Pro WindowServer[70]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 11:50:36 hifi02s-Mac-Pro com.apple.WindowServer[70]: Sun Feb  5 11:50:36 hifi02s-Mac-Pro.local WindowServer[70] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 11:51:16 hifi02s-Mac-Pro /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[152]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x39139280 of class NSCFArray autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x3830fd40 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x38329ee0 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x38345510 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x38343a10 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x3832af50 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x38328d00 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x3830a560 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x38345a60 of class NSConcreteMutableData autoreleased with no pool in place - just leaking
                      Feb  5 11:51:18 hifi02s-Mac-Pro Adobe InDesign CS4[144]: *** __NSAutoreleaseNoPool(): Object 0x333e430 of class NSCFArray autoreleased with no pool in place - just leaking
                      Feb  5 11:51:23 hifi02s-Mac-Pro Adobe InDesign CS4[144]: kCGErrorInvalidConnection: CGSDisableUpdateForConnections: Invalid connection
                      Feb  5 11:51:23 hifi02s-Mac-Pro Adobe InDesign CS4[144]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 11:51:23 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Sun Feb  5 11:51:23 hifi02s-Mac-Pro.local Adobe InDesign CS4[144] <Error>: kCGErrorInvalidConnection: CGSDisableUpdateForConnections: Invalid connection
                      Feb  5 11:51:23 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Sun Feb  5 11:51:23 hifi02s-Mac-Pro.local Adobe InDesign CS4[144] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 11:51:23 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Menu tracking: ignoring exception 'CGSDisableUpdate returned error 1002d' that raised inside runloop\n(\n    0   CoreFoundation                      0x938716ca __raiseError + 410\n    1   libobjc.A.dylib                     0x9323d5a9 objc_exception_throw + 56\n    2   CoreFoundation                      0x938713f8 +[NSException raise:format:arguments:] + 136\n    3   CoreFoundation                      0x9387136a +[NSException raise:format:] + 58\n    4   AppKit                              0x93dad06d NSDisableScreenUpdates + 101\n    5   AppKit                              0x943094c0 _servicesInfoHasChanged + 48\n    6   CoreFoundation                      0x93836aeb __CFXNotificationHandleMessage + 587\n    7   CoreFoundation                      0x93836894 __CFXNotificationReceiveFromServer + 356\n    8   CoreFoundation                      0x937df702 __CFMachPortPerform + 338\n    9   CoreFoundation                      0x937db46b __CFRunLoopRun + 6523\n    10  CoreFoundation                      0x937d93f4 CFRunLoopRunSpecific + 452\n    11  CoreFoundation                      0x937d9221 CFRunLoopRunInMode + 97\n    12  HIToolbox                           0x9a649e04 RunCurrentEventLoopInMode + 392\n    13  HIToolbox                           0x9a649bb9 ReceiveNextEventCommon + 354\n    14  HIToolbox                           0x9a6866d4 _ZL19IsUserStillTrackingP14MenuSelectDataPh + 510\n    15  HIToolbox                           0x9a6674a0 _ZL15TrackMenuCommonR14MenuSelectDataPh + 3831\n    16  HIToolbox                           0x9a8113bb _ZL19PopUpMenuSelectCoreP8MenuData5PointdS1_tjPK4RecttmS4_S4_PK10__CFStringPP13OpaqueMenu RefPt + 1944\n    17  HIToolbox                           0x9a8116bb _HandlePopUpMenuSelection7 + 678\n    18  HIToolbox                           0x9a81173f _HandlePopUpMenuSelection6 + 103\n    19  HIToolbox                           0x9a750214 _ZN13HIPopupButton9TrackMenuEv + 1102\n    20  HIToolbox                           0x9a750413 _ZN13HIPopupButton15TrackSelfCommonEsPs + 59\n    21  HIToolbox                           0x9a7504f6 _ZN13HIPopupButton9TrackSelfEP14OpaqueEventRefPs + 132\n    22  HIToolbox                           0x9a62fbc6 _ZN6HIView12EventHandlerEP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 2568\n    23  HIToolbox                           0x9a61cc2f _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1567\n    24  HIToolbox                           0x9a61bef6 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 411\n    25  HIToolbox                           0x9a61bd55 SendEventToEventTargetWithOptions + 58\n    26  HIToolbox                           0x9a6fad9a _Z19SendControlDefTrackP6HIViewRK7CGPointPmPFvP16OpaqueControlRefsEP14OpaqueEventRefPs + 311\n    27  HIToolbox                           0x9a6f25e6 _ZN6HIView13ClickInternalERK7CGPointmPFvP16OpaqueControlRefsEP14OpaqueEventRefb + 124\n    28  HIToolbox                           0x9a6f27a0 HandleControlClick + 199\n    29  WidgetBinLib.dylib                  0x027b40d2 _ZN22MCntlMgrDropDownListEH9LButtonDnEP6IEvent + 674\n    30  WidgetBinLib.dylib                  0x0277dda4 _ZN17PanelEventHandler9LButtonDnEP6IEvent + 116\n    31  WidgetBinLib.dylib                  0x0277dda4 _ZN17PanelEventHandler9LButtonDnEP6IEvent + 116\n    32  WidgetBinLib.dylib                  0x0277dda4 _ZN17PanelEventHandler9LButtonDnEP6IEvent + 116\n    33  WidgetBinLib.dylib                  0x0277dda4 _ZN17PanelEventHandler9LButtonDnEP6IEvent + 116\n    34  WidgetBinLib.dylib                  0x027fcf73 _ZN9MWindowEH9LButtonDnEP6IEvent + 595\n    35  WidgetBinLib.dylib                  0x027fb5f0 _ZN10CDefaultEH9LButtonDnEP6IEvent + 48\n    36  PublicLib.dylib                     0x010cfb4e _ZN16CEventDispatcher23DispatchToEventHandlersEP6IEvent + 206\n    37  PublicLib.dylib                     0x010cf708 _ZN16CEventDispatcher13DispatchEventEP6IEventNS0_18SystemHandledStateE + 24\n    38  Application UI                      0x1c433d36 GetPlugIn + 282342\n    39  Application UI                      0x1c431b8c GetPlugIn + 273724\n    40  HIToolbox                           0x9a61cc2f _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1567\n    41  HIToolbox                           0x9a61bef6 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 411\n    42  HIToolbox                           0x9a63e7f3 SendEventToEventTarget + 52\n    43  HIToolbox                           0x9a65034f _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 1257\n    44  HIToolbox                           0x9a61d080 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 2672\n    45  HIToolbox                           0x9a61bef6 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 411\n    46  HIToolbox                           0x9a63e7f3 SendEventToEventTarget + 52\n    47  AppFramework                        0x1c1d08f7 0x0 + 471664887\n    48  Widgets                             0x21204b5a 0x0 + 555764570\n    49  Plugin Manager                      0x1be93f48 0x0 + 468270920\n    50  Actions                             0x1c17fc03 GetPlugIn + 15171\n    51  Actions                             0x1c184a3b GetPlugIn + 35195\n    52  AppFramework                        0x1c1cf803 0x0 + 471660547\n    53  HIToolbox                           0x9a61cc2f _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1567\n    54  HIToolbox                           0x9a61bef6 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 411\n    55  HIToolbox                           0x9a63e7f3 SendEventToEventTarget + 52\n    56  AppFramework                        0x1c1d08f7 0x0 + 471664887\n    57  AppFramework                        0x1c1f3b3e GetPlugIn + 16750\n    58  Adobe InDesign CS4                  0x000026eb main + 187\n    59  Adobe InDesign CS4                  0x00001fb2 start + 258\n    60  Adobe InDesign CS4                  0x00001ed9 start + 41\n)
                      Feb  5 11:55:17 hifi02s-Mac-Pro com.apple.kextcache[130]: Created prelinked kernel /System/Library/Caches/com.apple.kext.caches/Startup/kernelcache_i386.D7132895.
                      Feb  5 11:55:40 hifi02s-Mac-Pro /System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer[117]: No valid tickets, timing out
                      Feb  5 11:56:27 hifi02s-Mac-Pro com.apple.launchd.peruser.501[87] (com.apple.NetworkDiagnostics[210]): Check-in of Mach service failed. Already active: com.apple.NetworkDiagnostic.agent
                      Feb  5 11:58:23 hifi02s-Mac-Pro [0x0-0xc00c].ch.sudo.cyberduck[122]: 2012-02-05 11:58:23,180 [background-12] ERROR ch.cyberduck.core.ftp.FTPSession - Connection attempt canceled
                      Feb  5 11:58:37 hifi02s-Mac-Pro [0x0-0xc00c].ch.sudo.cyberduck[122]: 2012-02-05 11:58:37,755 [background-11] ERROR ch.cyberduck.core.ftp.FTPSession - Connection attempt canceled
                      Feb  5 12:01:20 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=6291456) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:01:20 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=6291456) failed (error code=12)
                      Feb  5 12:01:20 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** error: can't allocate region
                      Feb  5 12:01:20 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:01:20 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:01:20 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:04:12 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:04:12 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)
                      Feb  5 12:04:12 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** error: can't allocate region
                      Feb  5 12:04:12 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:04:14 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:04:14: --- last message repeated 1 time ---
                      Feb  5 12:04:14 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)
                      Feb  5 12:04:14 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** error: can't allocate region
                      Feb  5 12:04:14 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:04:14 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:04:14 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:05:42 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=53686272) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:05:42 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=53686272) failed (error code=12)
                      Feb  5 12:05:42 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** error: can't allocate region
                      Feb  5 12:05:42 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:05:42: --- last message repeated 1 time ---
                      Feb  5 12:05:42 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:05:42 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:05:44 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=71741440) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:05:44: --- last message repeated 1 time ---
                      Feb  5 12:05:44 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=71741440) failed (error code=12)
                      Feb  5 12:05:44 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** error: can't allocate region
                      Feb  5 12:05:44 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:05:44 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:05:44 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:19:18 hifi02s-Mac-Pro quicklookd[369]: [QL] 'Creating thumbnail - cancelled' timed out for '<QLThumbnailRequest / WIP/ HiFi JOBS/INS205 PG8/INS 205/INS205 SA PG8/Links/1025476_SIDE.eps>' (Start date: 2012-02-05 12:19:14 +0200)
                      Feb  5 12:19:23 hifi02s-Mac-Pro quicklookd[379]: [QL] 'Creating thumbnail - cancelled' timed out for '<QLThumbnailRequest / WIP/ HiFi JOBS/INS205 PG8/INS 205/INS205 SA PG8/Links/3DLG.eps>' (Start date: 2012-02-05 12:19:18 +0200)
                      Feb  5 12:19:28 hifi02s-Mac-Pro quicklookd[381]: [QL] 'Creating thumbnail - cancelled' timed out for '<QLThumbnailRequest / WIP/ HiFi JOBS/INS205 PG8/INS 205/INS205 SA PG8/Links/1025476_SIDE.eps>' (Start date: 2012-02-05 12:19:24 +0200)
                      Feb  5 12:19:34 hifi02s-Mac-Pro quicklookd[382]: [QL] 'Creating thumbnail - cancelled' timed out for '<QLThumbnailRequest / WIP/ HiFi JOBS/INS205 PG8/INS 205/INS205 SA PG8/Links/1032806_HFC_V1.eps>' (Start date: 2012-02-05 12:19:29 +0200)
                      Feb  5 12:19:38 hifi02s-Mac-Pro quicklookd[384]: [QL] 'Creating thumbnail - cancelled' timed out for '<QLThumbnailRequest / WIP/ HiFi JOBS/INS205 PG8/INS 205/INS205 SA PG8/Links/1035338_HFC.eps>' (Start date: 2012-02-05 12:19:34 +0200)
                      Feb  5 12:24:07 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:24:07 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)
                      Feb  5 12:24:07 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** error: can't allocate region
                      Feb  5 12:24:07 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:24:08 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:24:08 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)
                      Feb  5 12:24:08 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** error: can't allocate region
                      Feb  5 12:24:08 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:24:08: --- last message repeated 1 time ---
                      Feb  5 12:24:08 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:24:08 hifi02s-Mac-Pro [0x0-0x10010].com.adobe.InDesign[144]: Adobe InDesign CS4(144,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:24:44 hifi02s-Mac-Pro Adobe InDesign CS4[144]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
                      Feb  5 12:25:04 hifi02s-Mac-Pro /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[435]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
                      Feb  5 12:27:02 hifi02s-Mac-Pro Adobe InDesign CS4[431]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
                      Feb  5 12:27:36 hifi02s-Mac-Pro Adobe InDesign CS4[474]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
                      Feb  5 12:27:54 hifi02s-Mac-Pro com.apple.launchd.peruser.501[87] (com.apple.AirPortBaseStationAgent[111]): Exited: Killed
                      Feb  5 12:27:54 hifi02s-Mac-Pro loginwindow[34]: DEAD_PROCESS: 34 console
                      Feb  5 12:27:55 hifi02s-Mac-Pro shutdown[483]: reboot by hifi02:
                      Feb  5 12:27:55 hifi02s-Mac-Pro shutdown[483]: SHUTDOWN_TIME: 1328437675 226303
                      Feb  5 12:27:55 hifi02s-Mac-Pro mDNSResponder[33]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) stopping
                      Feb  5 12:27:55 hifi02s-Mac-Pro DirectoryService[15]: BUG in libdispatch: 10K549 - 1960 - 0x10004004
                      Feb  5 12:27:55 hifi02s-Mac-Pro WindowServer[70]: hidd died. Reestablishing connection.
                      Feb  5 12:27:55 hifi02s-Mac-Pro WindowServer[70]: bootstrap_look_ip failed: Unknown service name
                      Feb  5 12:28:24 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
                      Feb  5 12:28:29 localhost blued[17]: Apple Bluetooth daemon started
                      Feb  5 12:28:31 localhost configd[13]: network configuration changed.
                      Feb  5 12:28:31 hifi02s-Mac-Pro configd[13]: setting hostname to "hifi02s-Mac-Pro.local"
                      Feb  5 12:28:35 hifi02s-Mac-Pro bootlog[44]: BOOT_TIME: 1328437704 0
                      Feb  5 12:28:36 hifi02s-Mac-Pro mDNSResponder[32]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) starting
                      Feb  5 12:28:39 hifi02s-Mac-Pro /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[33]: Login Window Application Started
                      Feb  5 12:28:39 hifi02s-Mac-Pro com.apple.usbmuxd[25]: usbmuxd-263 on Nov 14 2011 at 18:58:10, running 64 bit
                      Feb  5 12:28:40 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 12:28:43: --- last message repeated 1 time ---
                      Feb  5 12:28:43 hifi02s-Mac-Pro loginwindow[33]: Login Window Started Security Agent
                      Feb  5 12:28:43 hifi02s-Mac-Pro WindowServer[66]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 12:28:43 hifi02s-Mac-Pro com.apple.WindowServer[66]: Sun Feb  5 12:28:43 hifi02s-Mac-Pro.local WindowServer[66] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 12:28:44 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 12:28:51 hifi02s-Mac-Pro loginwindow[33]: Login Window - Returned from Security Agent
                      Feb  5 12:28:51 hifi02s-Mac-Pro shutdown[90]: reboot by root:
                      Feb  5 12:28:51 hifi02s-Mac-Pro shutdown[90]: SHUTDOWN_TIME: 1328437731 550758
                      Feb  5 12:28:51 hifi02s-Mac-Pro mDNSResponder[32]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) stopping
                      Feb  5 12:28:51 hifi02s-Mac-Pro DirectoryService[15]: BUG in libdispatch: 10K549 - 1960 - 0x10004004
                      Feb  5 12:28:51 hifi02s-Mac-Pro WindowServer[66]: hidd died. Reestablishing connection.
                      Feb  5 12:28:51 hifi02s-Mac-Pro SecurityAgent[82]: CGSShutdownServerConnections: Detaching application from window server
                      Feb  5 12:28:51 hifi02s-Mac-Pro WindowServer[66]: bootstrap_look_ip failed: Unknown service name
                      Feb  5 12:28:51 hifi02s-Mac-Pro SecurityAgent[82]: MIG: server died: CGSReleaseShmem : Cannot release shared memory
                      Feb  5 12:28:51 hifi02s-Mac-Pro SecurityAgent[82]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 12:28:51 hifi02s-Mac-Pro SecurityAgent[82]: CGSDisplayServerShutdown: Detaching display subsystem from window server
                      Feb  5 12:30:31 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
                      Feb  5 12:30:36 localhost blued[17]: Apple Bluetooth daemon started
                      Feb  5 12:30:37 localhost configd[13]: network configuration changed.
                      Feb  5 12:30:37 hifi02s-Mac-Pro configd[13]: setting hostname to "hifi02s-Mac-Pro.local"
                      Feb  5 12:30:39 hifi02s-Mac-Pro bootlog[44]: BOOT_TIME: 1328437831 0
                      Feb  5 12:30:39 hifi02s-Mac-Pro mDNSResponder[32]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) starting
                      Feb  5 12:30:39 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 12:30:40: --- last message repeated 1 time ---
                      Feb  5 12:30:40 hifi02s-Mac-Pro com.apple.usbmuxd[25]: usbmuxd-263 on Nov 14 2011 at 18:58:10, running 64 bit
                      Feb  5 12:30:40 hifi02s-Mac-Pro /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[33]: Login Window Application Started
                      Feb  5 12:30:41 hifi02s-Mac-Pro configd[13]: network configuration changed.
                      Feb  5 12:30:45 hifi02s-Mac-Pro loginwindow[33]: Login Window Started Security Agent
                      Feb  5 12:30:45 hifi02s-Mac-Pro loginwindow[33]: Login Window - Returned from Security Agent
                      Feb  5 12:30:45 hifi02s-Mac-Pro loginwindow[33]: USER_PROCESS: 33 console
                      Feb  5 12:30:45 hifi02s-Mac-Pro com.apple.launchd.peruser.501[86] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
                      Feb  5 12:30:51 hifi02s-Mac-Pro com.apple.launchd.peruser.501[86] (com.apple.Kerberos.renew.plist[110]): Exited with exit code: 1
                      Feb  5 12:32:20 hifi02s-Mac-Pro /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[133]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
                      Feb  5 12:33:09 hifi02s-Mac-Pro WindowServer[66]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 12:33:09 hifi02s-Mac-Pro com.apple.WindowServer[66]: Sun Feb  5 12:33:09 hifi02s-Mac-Pro.local WindowServer[66] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 12:34:38 hifi02s-Mac-Pro Adobe InDesign CS4[122]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
                      Feb  5 12:36:02 hifi02s-Mac-Pro Adobe InDesign CS4[162]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
                      Feb  5 12:36:17 hifi02s-Mac-Pro /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[190]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
                      Feb  5 12:37:16 hifi02s-Mac-Pro Adobe InDesign CS4[186]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
                      Feb  5 12:37:28 hifi02s-Mac-Pro Adobe InDesign CS4[215]: *** __NSAutoreleaseNoPool(): Object 0x3603100 of class NSCFArray autoreleased with no pool in place - just leaking
                      Feb  5 12:37:33 hifi02s-Mac-Pro /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[220]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
                      Feb  5 12:40:51 hifi02s-Mac-Pro /System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer[117]: No valid tickets, timing out
                      Feb  5 12:48:29 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:29 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=51855360) failed (error code=12)
                      Feb  5 12:48:29 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:48:29 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:30 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:30 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:48:30 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:48:30 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:38 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=36003840) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:38 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=36003840) failed (error code=12)
                      Feb  5 12:48:38 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:48:38 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:40 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:40 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:48:40 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:48:40 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:46 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=73080832) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:46 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=73080832) failed (error code=12)
                      Feb  5 12:48:46 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:48:46 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:46 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:46 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:48:46 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=53686272) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:46 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=53686272) failed (error code=12)
                      Feb  5 12:48:47 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:48:47 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:48:47 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:48:47 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:49:39 hifi02s-Mac-Pro fseventsd[37]: check_vol_last_mod_time:XXX failed to get mount time (25; &mount_time == 0x10047f8b8)
                      Feb  5 12:49:39 hifi02s-Mac-Pro fseventsd[37]: log dir: /Volumes/SAMSUNG/.fseventsd getting new uuid: B091F523-F48E-493C-93E2-D72200816FB3
                      Feb  5 12:51:17 hifi02s-Mac-Pro Adobe InDesign CS4[215]: kCGErrorIllegalArgument: _CGSFindSharedWindow: WID 384
                      Feb  5 12:51:17 hifi02s-Mac-Pro Adobe InDesign CS4[215]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 12:51:17 hifi02s-Mac-Pro Adobe InDesign CS4[215]: kCGErrorIllegalArgument: CGSGetWindowTags: Invalid window 0x180
                      Feb  5 12:51:17 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Sun Feb  5 12:51:17 hifi02s-Mac-Pro.local Adobe InDesign CS4[215] <Error>: kCGErrorIllegalArgument: _CGSFindSharedWindow: WID 384
                      Feb  5 12:51:17 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Sun Feb  5 12:51:17 hifi02s-Mac-Pro.local Adobe InDesign CS4[215] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
                      Feb  5 12:51:17 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Sun Feb  5 12:51:17 hifi02s-Mac-Pro.local Adobe InDesign CS4[215] <Error>: kCGErrorIllegalArgument: CGSGetWindowTags: Invalid window 0x180
                      Feb  5 12:55:14 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=53673984) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:14 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=53673984) failed (error code=12)
                      Feb  5 12:55:14 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:55:14 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:15 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:15 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:55:15 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:55:15 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:25 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=83812352) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:25: --- last message repeated 1 time ---
                      Feb  5 12:55:25 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=83812352) failed (error code=12)
                      Feb  5 12:55:25 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** error: can't allocate region
                      Feb  5 12:55:25 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: *** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:25 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)
                      Feb  5 12:55:25 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=64000000) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:25 hifi02s-Mac-Pro Adobe InDesign CS4[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=53673984) failed (error code=12)\n*** error: can't allocate region\n*** set a breakpoint in malloc_error_break to debug
                      Feb  5 12:55:25 hifi02s-Mac-Pro [0x0-0x11011].com.adobe.InDesign[215]: Adobe InDesign CS4(215,0xa0123540) malloc: *** mmap(size=53673984) failed (error code=12)
                      Feb  5 12:58:16 hifi02s-Mac-Pro com.apple.kextcache[325]: Created prelinked kernel /System/Library/Caches/com.apple.kext.caches/Startup/kernelcache_i386.D7132895.
                      Here is a sceond one i found:
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ProcessFolderList -- Copying contents of
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]            to
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/MacOS
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/MacOS
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 38
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      2012/02/05 11:36:03 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      2012/02/05 11:36:04 AMauthexec[3862]executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      2012/02/05 11:36:05 AMauthexec[3926]executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      2012/02/05 11:36:13 AMhdiejectd[3837]quitCheck: calling exit(0)
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Adobe SelfHealing
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] Error:  shmFSCopyObjectFailed in line 949 of file /Volumes/Bu
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ildDisk_mbs73/Acro_root_nsd/Common/SelfHealin
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]gSDK/Source/src/MoverCFMP.cp.
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Acrobat SelfHea
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ling Error:  Copy failed for:
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Contents/MacOS/SelfHealFi
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]les/Library/Automator/Save As Adobe PDF.a
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ction
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ling Error:  shmFSCopyObjectFailed in line 94
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]9 of file /Volumes/BuildDisk_mbs73/Acr
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]o_root_nsd/Common/SelfHealingSDK/Source/sr
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]c/MoverCFMP.cp.
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Acrobat SelfHealing Error:
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]  Copy failed for:
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]cOS/SelfHealFiles/Library/Autom
                      2012/02/05 11:36:21 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ator/Save As Adobe PDF.action
                      2012/02/05 11:36:21 AMauthexec[4464]executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Adobe SelfHealing Error:  shmFSCopyObjectFailed in line 949 of file /
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Volumes/BuildDisk_mbs73/Acro_root_nsd/Common/SelfHealingSDK/Source/src/MoverCFMP.cp.
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Acrobat SelfHealing Error:  Copy failed for:
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Contents/MacOS/
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]SelfHealFiles/Library/Automator/Save As Adobe PDF.action
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]FSCopyObjectFailed in line 949 of file /Vo
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]lumes/BuildDisk_mbs73/Acro_root_ns
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]d/Common/SelfHealingSDK/Source/src/M
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]overCFMP.cp.
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] SelfHealing Error:  Copy failed for:
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Contents/MacOS/SelfHealFi
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]les/Library/Automator/Save As A
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]dobe PDF.action
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]aling Error:  shmFSCopyObjectFailed in line 949 of
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] file /Volumes/BuildDisk_mbs73/Acro
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]_root_nsd/Common/SelfHealingSDK/Sour
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ce/src/MoverCFMP.cp.
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] Copy failed for:
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]s/MacOS/SelfHealFiles/Libra
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ry/Automator/Save As Adobe PD
                      2012/02/05 11:37:30 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]F.action
                      2012/02/05 11:37:30 AMhdiejectd[6190]running
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ProcessFolderList -- Copying contents of
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]            to
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd910_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]FSCopyFolder -- 69 folders were found
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            dupeAction: replace, wantSpec: yes, wantName: yes,
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            isDropBox: no, PBHCopyFileSync supported: no
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/MacOS
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/MacOS
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 37
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      2012/02/05 11:37:32 AMauthexec[6214]executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      2012/02/05 11:37:32 AMauthexec[6227]executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Adobe SelfHealing Error:  shmFSCopyObjectFailed in lin
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]e 949 of file /Volumes/BuildDisk_mbs73/Acro_root_nsd/Common/SelfHealingSDK/Source/src/MoverCFMP.cp.
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Acrobat SelfHealing Error:  Copy failed for:
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Contents/MacOS/SelfHealFiles/Library/Au
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]tomator/Save As Adobe PDF.action
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ealing Error:  shmFSCopyObjectFailed
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] in line 949 of file /Volumes/BuildDisk_mbs73/Acro_ro
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ot_nsd/Common/SelfHealingSDK/Source
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]/src/MoverCFMP.cp.
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]robat SelfHealing Error:  Copy failed f
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]or:
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Files/Library/Automator/Sav
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]e As Adobe PDF.action
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ealing Error:  shmFSCopyObjectFailed in line 949
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] of file /Volumes/BuildDisk_mbs73/A
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]cro_root_nsd/Common/SelfHealingSDK/Source/src/MoverCFM
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]P.cp.
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Healing Error:  Copy failed for:
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]s/Library/Automator/Save As
                      2012/02/05 11:37:34 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Adobe PDF.action
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] FSGetCatalogInfoBulk: 3
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ProcessFolderList -- Copying contents of
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]            to
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 4
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 1
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ro.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/ru.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/sv.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/tr.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/uk.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_CN.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd911_all/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/zh_TW.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]FSCopyFolder -- 69 folders were found
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]FSCopyObject -- err: 0, maxLevels: 0, whichInfo: 0000c000,
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            dupeAction: replace, wantSpec: yes, wantName: yes,
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            filterProcPtr: 0x0004e488, yourDataPtr: 0xb01029f8,
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            newObjectRef: 0xb01028a0, newObjectSpec: 0x00000000,
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            copyBufferSize: 256kB, isDirectory: yes, isLocal: yes,
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]                            isDropBox: no, PBHCopyFileSync supported: no
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 5
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 2
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]: 2
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Frameworks/adobe_caps .framework/Versions/A/Resources/English.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/AdobeSelfHealing.framework/Versions/A/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/A/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Frameworks/InstallerResults.framework/Versions/Current/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/MacOS
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/MacOS
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 37
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/cs.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/da.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/de.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/English.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/es.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/eulas/html/en_US
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fi.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/fr.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/hu.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/it.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ja.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/ko.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/nl.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/no.lproj/MainMenu.nib
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj
                      2012/02/05 11:37:35 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/Ma
                      2012/02/05 11:37:36 AMauthexec[6287]executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      2012/02/05 11:37:36 AMauthexec[6300]executing /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/InstallUpdates.sh
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Adobe SelfHeali
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ng Error:  shmFSCopyObjectFailed in line 949 of file /Volumes/Bui
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ldDisk_mbs73/Acro_root_nsd/Common/
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]SelfHealingSDK/Source/src/MoverCFMP.cp.
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Acrobat
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]SelfHealing Error:  Copy failed for:
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]C
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ontents/MacOS/SelfHealFiles/Library/Automato
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]r/Save As Adobe PDF.action
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ealing Error:  shmFSCopyObjectFailed in line 949 of
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222] file /Volumes/BuildDisk_mbs73/Acro
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]_root_nsd/Common/SelfHealingSDK/So
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]urce/src/MoverCFMP.cp.
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Acrobat SelfHealing Error:  Copy failed fo
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]r:
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]Contents/MacOS/SelfHealFiles/Libra
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ry/Automator/Save As Adobe PDF.action
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]aling Error:  shmFSCopyObjectFailed in li
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ne 949 of file /Volumes/BuildDisk_mbs73/A
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]cro_root_nsd/Common/SelfHealingSDK/Source/src/Move
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]rCFMP.cp.
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ling Error:  Copy failed for:
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]tents/MacOS/SelfHealFiles/Library/Automat
                      2012/02/05 11:37:45 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]or/Save As Adobe PDF.action
                      2012/02/05 11:37:47 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]inMenu.nib
                      2012/02/05 11:37:47 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]            to
                      2012/02/05 11:37:47 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Users/hifi02/Library/Caches/Adobe/Updater6/acrobat9pro-EFG/Acrobat 9 Pro Patch.app/Contents/Resources/pl.lproj/MainMenu.nib
                      2012/02/05 11:37:47 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]CopyFolder -- actualObjects retrieved from FSGetCatalogInfoBulk: 3
                      2012/02/05 11:37:47 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]ProcessFolderList -- Copying contents of
                      2012/02/05 11:37:47 AM[0x0-0x16016]."com.Adobe.ESD.AdobeUpdaterApplication"[222]    /Volumes/AcroProUpd912_all/Acrobat 9 Pro Patch.app/Contents/Resources/pt.lproj
