I have downloaded Adobe Flash Player numerous times, says it is installed successfully BUT when I go into games it tells me to download Adobe. Plus I have no showing I have it. Please help TY
Moving this discussion to the Install Flash Player forum.
When posting, please provide:
j'ai le meme probleme . . . sur 2 PC avec
> windows XP pack 3
> systeme 32
> internet explorer 8
> flash player version 11.1.102.55
téléchargement OK (info Adobe). . . mais pas installé ? ?
restart . . is the same ! !
How can I do ? ?
thank you
JBO
Is Shockwave Flash Object add-on enabled in Internet Explorer?
YES but is the same after new download flash player and restart.
Also : all videos "youtube" on our website dont seen after this enable ! !
best regards
I have the same problem. Once I turned off IE, the 64 bit version installed immediately with no apparent problem.
However, going to Flash Earth, it seems it cannot see the Flash Player and asks me to download it.
A search in my Win7 Home Premium system finds no sign of Flash Player.
Installed? Apparently.
Invisible? Apparently.
The Flash Player files will be in folders C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash.
Thank you. New to Win 7, I cannot explain why search did not point to the appropriate folder.
I have a constructive suggestion...when I looked in the folder, the only .exe file was the uninstaller.
However Flash Earth showed me I now????? have a working Flash Player. I concluded that the .ddll file and the active x file are all that is needed.
Somehow, this should be explicitly pointed out so people wont go looking for an .exe file to conclude all is OK.
As far as checking to see if the plugins work, I assume that if the flash player is properly installed, you don't get a gear to click on to progress further.
I got a page saying I was successfully installed.
Thank you for your help and professional patience.
The Web Flash Player is not a stand alone program but a add-on used by a web browser. Just because you have successfully installed the ActiveX Flash Player add-on for Internet Explorer, that does not mean that the Internet Explorer is set to use ActiveX add-ons.
merci pour votre reponce but my problem is not to have Flash Player or not with Internet Explorer it is Dreamveaver CS5 which requires the Flash Player to use a program .....
