15 Replies Latest reply on Nov 6, 2013 10:23 AM by Nealf21
    Lost media.ppcx file
    sjreaves5
      HELP!!  I recorded 84 slides of audio...just to find that the media.ppcx file cannot be located.  All of the recordings are in a folder (mp3 and lthmb files)...named with numbers...how can I get those recordings in my power point presentation through Presenter???
        • 1. Re: Lost media.ppcx file
          VideoPep Level 2
          Have you moved your presentation to another location? Please make sure that you also move the asset folder to same location. Asset folder are name as PresentationFileName_pptx/ppt.
          If you have moved both presentation and asset folder then verify that can you see media.ppcx folder in that location. If you are prompted for ppcx file please point to this media.ppcx file and all recording will get attached properly.
          Shubhi
          • 2. Re: Lost media.ppcx file
            sjreaves5 Level 1
            Thank you for your quick response. I have not moved the folder. It is named appropriately. The media.ppcxfile is what is missing.
            • 3. Re: Lost media.ppcx file
              flyingj481 Adobe Community Professional (Moderator)
              What version of Presenter are you using 7.0.0, 7.0.1, 7.0.2, 7.0.5, 7.0.6 or 7.0.7?
              And if the PPCX file is gone, then you will need to go throught he painful process of listening to each audio file, and then determining which slide it should be re-imported into. I would copy them into another folder, and rename them, so you have everything set up should you need it again in the future. This sounds like something that Presenter 7.0.2 or earlier would do, thus why I ask about version.
              • 4. Re: Lost media.ppcx file
                sjreaves5 Level 1
                7.0.1
                I have worked unsuccessfully with our Technology Services Department.  I will
                be re recording tonight, unfortunately.
                Susan Reaves
                ESE Secondary Coordinator
                Volusia County Schools
                386-255-6475  Ext 33247
                Fax Number - 386-943-3445
                • 5. Re: Lost media.ppcx file
                  I would upgrade to 7.0.6 through the Adobe Upadter, or but going into any Adobe application (including Presenter) and checking Help > Check for Updates. You will need to install 7.0.2, 7.0.5 and 7.0.6 sequentially. You could also go here and download the EXE files for the updates: http://www.adobe.com/support/downloads/ … rm=Windows
                  If you decided to go to 7.0.7 it requires that you uninstall the existing version of Presenter on your computer, and then reinstall the new 7.0.7 version as a clean install.
                  • 6. Re: Lost media.ppcx file
                    sjreaves5 Level 1
                    Thank you.  Two more questions…what about the 7.0a update and if I do the
                    7.0.7, will I again need the code for our school district?
                    Susan Reaves
                    • 7. Re: Lost media.ppcx file
                      7.0a is 7.0.0
                      Yes, installing 7.0.7 will require you to put your serial key in again.
                      • 8. Re: Lost media.ppcx file
                        Nealf21 Level 1
                        I have had the same thing happen with Adobe Presenter 8.
                        Just to be sure I wasn’t crazy, I reinstalled the media.ppcx file from backup. Presenter deleted it again!
                        • 9. Re: Lost media.ppcx file
                          Nealf21 Level 1
                          Jorna,
                          What is the best way to import the audio files back into the presentation?
                          Is there any troubleshooting that should be done to the PowerPoint file so that it does not lose the media.ppcx file again?
                          • 10. Re: Lost media.ppcx file
                            It's hard to take a shot at the dark on this, but I'll try.
                            Are you taking a presentation from Presenter 7, Presenter 6, or older and trying to update it to Presenter 8? Are you trying to associate a stand alone PPC (Presenter 6 or older) file or a PPCX file (Presenter 7 and newer)?
                            • 11. Re: Lost media.ppcx file
                              Nealf21 Level 1
                              Jorna,
                              Yes, I believe the two presentations were created in Presenter 7, then I upgraded to 8.  It is a PPCX file.
                              Oddly though, it only happened to 3 of my older files.  I have a few others I have revised with Presenter 8 without problem.
                              FYI, I did reimport the audio and the new presentation publishes fine now.  Thanks for that tip. It was not as bad as I thought it might be. I renamed the audio files by slide number, which made it easy to import them.
                              • 12. Re: Lost media.ppcx file
                                Well, you did my next suggestion and it seems to have worked. The update process has always seemed to leave a few files in a lurch for me. Most work, but some require a little more encouragement than others!
                                • 13. Re: Lost media.ppcx file
                                  Nealf21 Level 1
                                  Thank you!
                                  It is nice to get a candid assessment. Knowing the older files might not update properly is something I can work with (now that I know). Replacing a couple presentations is a lot easier knowing that my new Presenter 8 presentation won’t ge corrupted. I was worried this could happen to any of my presentations at any time.
                                  • 14. Re: Lost media.ppcx file
                                    mkalyanp Level 2
                                    Hi
                                    I require a few more details
                                    1. Which version of PowerPoint are you using?
                                    2. The presentation is a "pptx" or a "ppt"?
                                    If the issue is presentation specific can you package the presentations and send it to mkalyanp@adobe.com ?
                                    Mahesh
                                    • 15. Re: Lost media.ppcx file
                                      Nealf21 Level 1
                                      Hi, Mahesh,
                                      I have PowerPoint 2010.
                                      The presentation is a pptx
                                      I will zip up the files and send it to you.
                                      Thank you!
