7 Replies Latest reply on Feb 7, 2012 9:15 AM by bre_an
    Iterate through itemRenderer in Flex DataGrid
    bre_an
      I have an ItemRenderer for my first DataGrid column of a message board containing a spark CheckBox.
      I want to iterate through all these itemRenderer and set the Checkbox to true (when the user clicks on "check all messages")
      In Flex 3 with a mx-DataGrid this was possible using dataGrid.getListItems(), is there a counterpart for spark?
      Andreas
        • 1. Re: Iterate through itemRenderer in Flex DataGrid
          andrerdp
          Hi bre_an
          i create headerRenderer in my column to select all values.
          ex:
          <s:Datagrid >
               <s:columns>
                    <s:ArraList>
                         <s:GridColumn dataField="select" headerRenderer=GridCheckHeader sortable=false
                                                itemRenderer=CheckGridColumn />
                    </s:ArraList>
               </s:columns>
          </s:DataGrid>
          inside my GridCheckHeader i change layout HGroup from default headerRenderer
          <s:Hgroup>
                <s:CheckBox id="checkAll" click="checkAll_click(event)">
          </s:Hgroup>
          protected function checkAll_click(event:mouseEvent):void{
               for(var obj:Object in grid.dataProvider){
                    grid.dataProvider[obj][column.dataField] = true;
          • 2. Re: Iterate through itemRenderer in Flex DataGrid
            bre_an Level 1
            Hi andrerdp,
            thank you very much for your response, but that is not quite what i meant.
            I have an itemrenderer containing a checkbox:
            <s:GridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                focusEnabled="true">
                <fx:Script>
                <s:Group width="100%" >
                    <s:CheckBox id="chk"
                        horizontalCenter="0" verticalCenter="0" />
                </s:Group>
            </s:GridItemRenderer>
            and now I want to check all checkboxes for evey row.
            this is for a messaging system, where the user can select messages to delete them (or click the button "select all" to check all messages).
            The model for the message data does not have a chk-value, and I think it is clearer to keep the model that way, but I can modify it so that it stores the value if a message is selected if it is not possible to iterate through the itemRenderer.
            Andreas
            • 3. Re: Iterate through itemRenderer in Flex DataGrid
              bre_an Level 1
              anyway... extending my data model works:
              class Message {
                 public var chk:Boolean = false;
              than I can call this function on click:
              private function markAll():void {
                  for each (var obj:Object in dataGrid.dataProvider){
                      obj.chk = true;
                  (dataGrid.dataProvider as ArrayCollection).refresh();
              and this is how the ItemRenderer looks like:
                  xmlns:s="library://ns.adobe.com/flex/spark" >
                  <fx:Script>
                  <![CDATA[
                          public override function set data(value:Object):void {
                              super.data = value
                              if (value == null)
                                  chk.selected = false
                              else
                                  chk.selected = value.chk as Boolean;
                          override public function setFocus():void {
                              chk.setFocus();
                  </fx:Script>
              as i wrote, not the nicest way, but it works... so if anyone knows a nicer way without modifying the model please tell me.
              • 4. Re: Iterate through itemRenderer in Flex DataGrid
                drkstr_1 Level 4
                While your method requires more typing than others, I think most (including myself) would consider it the preferred method for updating an item renderer view.
                • 5. Re: Iterate through itemRenderer in Flex DataGrid
                  bre_an Level 1
                  It is not the lines of code i meant, for this I have to extend my data model.
                  In my case the original model is generated from my database model which does not need to know anything about the checkboxes.
                  So I had to modify my model generator (that creates the code from the database model into actionscript code) for this to add a variable that does not exist as database-column.
                  • 6. Re: Iterate through itemRenderer in Flex DataGrid
                    drkstr_1 Level 4
                    This is what's called a Presentation Model (PM). Usually I encapsulate my domain objects in a PM, or use some kind of controller to handle the translation between domain objects and the PMs. Extending the domain object is also an option, but I'm a bit wary of extension as a practice, in most instances.
                    • 7. Re: Iterate through itemRenderer in Flex DataGrid
                      bre_an Level 1
                      ah, ok, I'll create a pm for my data than.
                      Thank you for your response! I definitively learned something here!
