1. Re: CS4 force quits when you try to change layer order, is this install problem?
MichaelKazlow Feb 5, 2012 10:37 AM (in response to beng8223)Since the program is installed, you are better off asking in the Photoshop forum where users of Photoshop hang out. It could be an issue with Photoshop CS 4 which is a little long in the tooth for Lion, but maybe not. This is where knowledgeable users of Photoshop can give you help based upon their experience.
2. Re: CS4 force quits when you try to change layer order, is this install problem?
Jeff A WrightFeb 6, 2012 1:20 PM (in response to MichaelKazlow)
Moving this discussion to the Photoshop General Discussion forum.
3. Re: CS4 force quits when you try to change layer order, is this install problem?
Jeff Arola Feb 6, 2012 6:17 PM (in response to beng8223)See if this helps:
http://kb2.adobe.com/cps/914/cpsid_91469.html
Also make sure photoshop is up to date (current version for cs4 is 11.02)
4. Re: CS4 force quits when you try to change layer order, is this install problem?
PECourtejoie Feb 7, 2012 12:04 AM (in response to Jeff Arola)Good call, R_Kelly!
I'm wondering if 10.7.3 fixes the issue, but the update itself has been pulled back, and only the combo (total reinstall) is available.
5. Re: CS4 crashes when you try to change layer order, is this install problem?
Chris CoxFeb 7, 2012 12:51 AM (in response to beng8223)
There is a MacOS bug in QuickDraw that was causing that to happen to many people. (Photoshop CS5 doesn't use QuickDraw and doesn't run into that bug)
I'm not sure if 10.7.3 fixes it or not.
