9 Replies Latest reply: Feb 6, 2012 11:12 AM by igregurec RSS
    TOUCH_BEGIN calls function twice
    igregurec Community Member
      hi there people!
      I've decided to experiment with multitouch basics:
      import flash.display.MovieClip;
      import flash.events.TouchEvent;
      import flash.events.Event;
      import flash.ui.Multitouch;
      import flash.ui.MultitouchInputMode;
      var i:int=0;
      Multitouch.inputMode = MultitouchInputMode.TOUCH_POINT;
      function touchBegin(evt:TouchEvent)
          i++;
          trace(i);
      stage.addEventListener(TouchEvent.TOUCH_BEGIN, touchBegin);
      function touchEnd(evt:TouchEvent)
          i--;
      stage.addEventListener(TouchEvent.TOUCH_END, touchEnd);
      the results are strange - on every touch_begin event touchBegin() is called twice and on touch_end only once so "i" is getting bigger and bigger...
      any idea?
        • 1. Re: TOUCH_BEGIN calls function twice
          Anton Azarov Community Member
              i--;
          trace(i);
          may be this help?
          but anywhere - you should 'save' your touchpoint id and if it wass released - just for decrease for it.
          • 2. Re: TOUCH_BEGIN calls function twice
            boat5 Community Member
            looking at your code, nothing is wrong, bug perhaps? what is your device? i have never seen that happen before
            • 3. Re: TOUCH_BEGIN calls function twice
              and which SDK?
              • 4. Re: TOUCH_BEGIN calls function twice
                in fact - this sometimes occur on iPhone 4 and iPhone 3GS with any Air SDK. Simply I don't have another devices for test. But ! This happen when you have more than 2 touch point id at once. But this simply can be solved - use saving of current pressed touchpoint and chen when you doing decrement so if your exact touch_begin ID point was touch_end - than you will do i--. In another case do nothing =)
                This will help you at 100% I done this many times
                • 5. Re: TOUCH_BEGIN calls function twice
                  it happened every time in device central and sometimes, with faster taping on iPhone 3GS. I'm planning to create some kind of polyphonic synth - you can imagine what kind of chaos would this produce
                  seems like touchPointID will do the trick but removeChild is what bothers me now...
                  • 6. Re: TOUCH_BEGIN calls function twice
                    Don't worry. Simply don't use TOUCH_END with exact object. Like a movieclips.
                    Use TOUCH_BEGIN for movieclip/sprite, but always use stage for TOUCH_END. This will help you controlling TOUCH_END if you removeChild before than TOUCH_END will occur.
                    import flash.geom.Point;
                    // Enable touch input mode because in devices always used Gestures as defaults
                    // Create object that will contain all user touches ids with properties
                    var touchPoints : Object = {};
                    // add touch listener
                    Any_DisplayObject.addEventListener(TouchEvent.TOUCH_BEGIN, TOUCH_BEGIN_FUNC);
                    stage.addEventListener(TouchEvent.TOUCH_END, TOUCH_END_FUNC);
                    function TOUCH_BEGIN_FUNC (e:TouchEvent):void{
                       // save current touch point id to object
                        // exactly we save here current touch position as point
                         // note if you will use e.localX and Y - this will return local "mouseX" and "mouseY" in your MovieClip. Not global. For example your stage.stageWidth & stage.stageHeight = 960x640 and you will have there square MC in x=300 & y=100
                         // localX and Y will return not 300 + offset and Y the same. It will return from 0 to maximum X and Y depending on your square.
                         // If you want know exact touch coordinates on screen - you can simple use e.stageX and e.stageY
                        touchPoints[ e.touchPointID ] = new Point(e.localX, e.localY);
                        // you can use many objects so this will help determinate exact one
                        // that was touched
                        if ( touchPoints[ e.touchPointID ] ) {
                            trace ( "You touch some point in X:", touchPoints[ e.touchPointID ].x, "Y:", touchPoints[ e.touchPointID ].y );
                    function TOUCH_END_FUNC (e:TouchEvent):void{
                        // during TOUCH_END event we can check if this TOUCH_END was registered
                        // in touchPoints object
                            // if touch was registered - do your code things
                            trace ( "You just released touch point saved in", touchPoints[ e.touchPointID ].x, "Y:", touchPoints[ e.touchPointID ].y );
                            // you need to delete it because after touch for exact point is ends
                            // we are good programmers, we don't like unused but not free memory
                            // so simply delete information about current touchpoint in object
                            delete touchPoints[ e.touchPointID ];
                    • 7. Re: TOUCH_BEGIN calls function twice
                      thank you for all those details!
                      Today I've learned a new logic therm: singleton and it seams that is just what i need here.
                      I'll try with: delete touchPoints[ e.touchPointID ]; - it might help!
                      • 8. Re: TOUCH_BEGIN calls function twice
                        someone might want to report it as a bug, I am using the ipod4, I just copy/pasted your code into a new document and i always returns back to 0 as it should.
                        I am running a continuous trace on i outside of the touch functions.
                        I tried tapping all over, quick, slow, whole hand, simultaneous.
                        No double event firing, every touch begin and touch end is heard exactly correct and once.
                        • 9. Re: TOUCH_BEGIN calls function twice
                          it has a life of it's own!
