6 Replies Latest reply on Feb 8, 2012 2:37 PM by JJMack
    Transform tool- problems with printing
    feelgood101
      Can anyone please advise?  Been using CS3 for a few years.  Recently used the free transform tool to import several images into a blank template, resize them and then print as one page.  The overall image is sized to fit the print request and looks great inscreen at 100%.  However when I send to lab for printing it is very poor quality.  I have really no idea why this is and I'm hoping someone here can point out my mistake.  I'm guessing it's something really obvious....I just can't figure what.  Very frustrating.  Ideas? Thanks in advance
        • 1. Re: Transform tool- problems with printing
          Zeno Bokor Level 6
          I doubt that you used the Free Transform command (it's not a tool) to import images . Could you post a screenshot of the Image->Image Size dialog box of the document that you sent for printing? also, what sized printouts did you get back?
          • 2. Re: Transform tool- problems with printing
            feelgood101 Level 1
            I will try to do that.  I'm new to this forum so bear with me.  Desperate for an answer.  Prints were 12x8.  They were just very fuzzy and the lab labelled them low res although I know they were high res originals so I'm a bit confused.
            OKay, actually I don't know how to make a screenshot - d'oh!  Can you maybe help with this too??  Sorry, brain has obviously disengaged!
            • 3. Re: Transform tool- problems with printing
              Noel Carboni Level 8
              I've seen cases where he repositioning / resampling algorithms in the Transform tool didn't create nice clean results, though I failed miserably in several attempts just now to reproduce this.  Are you're seeing jaggies, for example, where things should be smooth?  At the time I saw it before I just decided to work at a higher resolution, thinking that's just the way it is, and made a mental note to experiment with Transforms again some time (which you just reminded me to do).  Now everything looks nice.  Go figure.
              Looking forward to seeing your images.
              There's a PrtScrn key on the keyboard that can be used to capture the screen into the clipboard on a Windows system, then you can paste it into a document and save an image file.  I just use a freeware tool called IrfanView myself, which offers a little more sophistication.
              -Noel
              • 4. Re: Transform tool- problems with printing
                Bo LeBeau Level 4
                Maybe the template that you used for the print is low resolution.
                Even though your originals may have been high res, whenever you place, copy & paste, or drag images from the original to the template,
                they take on the resolution of the destination image.
                So if the template had only 72 ppi resolution, dragging high res photos into it would cause them to become 72 ppi resolution.
                • 5. Re: Transform tool- problems with printing
                  feelgood101 Level 1
                  Hi Bo.  Sorry for the delay.  Looks like yours may be the snwer!  Had no idea this was the case but it checks out.  Have just sent revised sample image to printer.  Will find out tomorrow if this is good!!  Unfortunately all my previous work was in vain as I seem unable to 'boost the ppi resolution once it's been created ( Never mind, at least I'm getting somewhere and learning along the way! Thanks again. H
                  • 6. Re: Transform tool- problems with printing
                    Photo Collage Toolkit
                    The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
                    There are eight scripts in this package they provide the following functions:
                    1. TestCollageTemplate.jsx - Used to test a Photo Collage Template while you are making it with Photoshop.
                    2. CollageTemplateBuilder.jsx - Can build Templates compatible with this toolkit's scripts.
                    3. LayerToAlphaChan.jsx - Used to convert a Prototype Image Layer stack into a template document.
                    4. InteractivePopulateCollage.jsx - Used to interactively populate Any Photo Collage template. Offers most user control inserting pictures and text.
                    5. ReplaceCollageImage.jsx - use to replace a populated collage image Smart Object layer with an other image correctly resized and positioned.
                    6. PopulateCollageTemplate.jsx - Used to Automatically populate a Photo Collage template and leave the populated copy open in Photoshop.
                    7. BatchOneImageCollage.jsx - Used to Automatically Batch Populate Collage templates that only have one image inserted. The Collage or Image may be stamped with text.
                    8. BatchMultiImageCollage.jsx - Used to Automatically Batch Populate Any Photo Collage template with images in a source image folder. Easier to use than the interactive script. Saved collages can be tweaked.
                    Documentation and Examples
                    Download
