2 Replies Latest reply on Feb 6, 2012 12:38 PM by JW1015
    using data between views
    JW1015 Level 1
      I need to use the data from one view into a second view.
      The data is just a single string the name of a file eg: Alpha.swf
      In the second view I try to asign the data to a string variable but cannot figure out how to accomplish this.
      I can assign it to a label.text such as label.text="{data}";
      I need this string to resolve the path for a StageWebView.
      public var path:String = new File(new File("app:/assets/"+ data).nativePath).url; No this does not work?
      What am I doing wrong.
      John
        • 1. Re: using data between views
          Janadh
          Hi JW,
          On view1
          create an object;
               var obj:Object = new Object();
               obj.fileName = "File1.JPG";
                                                    navigator.pushView(view2,obj); //Call the second view
          On the second view2
          create a activate event from UI. This will be fired when you activate the view. On the event handler you can do whatever you want with the data.
          protected function view2_viewActivateHandler(event:ViewNavigatorEvent):void
                                                  // TODO Auto-generated method stub
            Label1.label = data.fileName; //get the data from the object.
          There may be other ways. this is all I know. Hope it helps.
          Cheers
          • 2. Re: using data between views
            JW1015 Level 1
            Thanks for the suggestion. however I still have the same problem.
            Getting the data from one view to the other is not the problem, it is trying to assign the data to a string that I have, be it an object or the data passed by pushview.
            I did try your method but the end result is the same:
            protected function stageView_viewActivateHandler(event:FlexEvent):void
                            manualname = data.fileName; //get the data from the object.
            public var path:String = new File(new File("app:/assets/"+ data.filename).nativePath).url;
            Still getting null object.
