0 Replies Latest reply on Feb 6, 2012 6:28 AM by Andrew Kinnear
    Key press elapsed time
    Andrew Kinnear
      I'm building a shooting game. I want to record how long the player has the F key pressed in order to use that value to remove ammunition sprites from the stage.
      My application loops in frame 1.
      I have a script that subtracts the key press time from the system time on key release. I think the repeat rate of the keyboard is interfering with this as the output figures are quite random and holding the key down for longer returns a lower number.
      global gFire, gTotal, gStartTime
      on startMovie
        the keyDownScript = "handleKeydown"
        the keyUpScript = "handleKeyUp"
      end startMovie
      --Handler to fire
      on handleKeydown
        if the key = "f" then
          gStartTime = the milliseconds
        end if
      end handleKeydown
      --Handler to stop firing
      on handleKeyUp
          gfire = (the milliseconds - gStartTime)/10
          gLeft = gTotal - gFire
          gTotal = gLeft -- gTotal is used to incrementally turn off sprite visibility
          put gfire -- Trace elapsed time to Message window
        end if
      end handleKeyUp
      --This sequence removes bullets from the stage\
      according to he time spent firing
      on enterFrame
        if tTotal < 900 then
          sprite(10).visible = False --this repeated for a sequence of 10 sprites
        end if
      end
      The other problem with this is that it doesn't update the stage till the key is released, so a player can defeat the logic by just holding the key down continuously (especially because the value of gFire doesn't increase as expected)
      Ideally I'd like to record the elapsed time the key is down, add it to a global and have it update the stage at the frame rate, so I guess it would have to be within a frame event handler.
      Any help would be gratefully received.
