2 Replies Latest reply on Feb 7, 2012 6:09 AM by diamond_1982
    Problem with images in richeditabletext
    diamond_1982
      I've got the following code for scrollbar + ret:
      <s:Scroller id="scroller" left="0" top="0" width="100%" height="100%">
           <s:RichEditableText id="rte" left="0" top="0" clipAndEnableScrolling="true" editable="false" textFlow="{TextConverter.importToFlow(new XML(_course.ShortDescription, TextConverter.TEXT_LAYOUT_FORMAT)}"/>
      </s:Scroller>
      My TextFlow contains:
      <TextFlow whiteSpaceCollapse="preserve" version="2.0.0" xmlns="http://ns.adobe.com/textLayout/2008">
           <p>
                <span>abasdfasdfasdfa Dit is de omschrijving die langer gemaakt is om te testen wat er gebeurt in het overzicht gen op de homepagina.</span>
           </p>
           <p>
                <span>
                </span>
           </p>
           <list listStyleType="disc">
                <li>
                     <p>
                          <span>test</span>
                      </p>
                </li>
                <li>
                     <p>
                          <span>test2</span>
                     </p>
                </li>
           </list>
           <p>
                <span></span>
           </p>
                <li>
                     <p>
                          <span>test3</span>
                     </p>
               </li>
                <li>
                     <p>
                          <span>test4</span>
                     </p>
               </li>
           </list>
           <p>
                <span></span>
           </p>
           <p>
                <span></span>
           </p>
           <p>
                <img source="http://stagingdigilearner.sagamgraphic.be/assetDirectory/default/Afbeelding(17).jpg?guid=0 .05344812013208866"/>
                <span></span>
           </p>
           <p>
                <span></span>
            </p>
           <p>
                <span>t</span>
           </p>
      </TextFlow>
      It seems that my ret is crashing whenever the image is widerthan my ret. I have this only with one ret. On another location the exact same code seems to work well. Has anyone experience with such a problem?
