1 Reply Latest reply on Feb 7, 2012 3:01 AM by Mathangi Ramachandran
    Using dynamic column name in datagrid selectedItems
      Hi
      I have a datagrid loaded with 2 columns. Allowmultiselect is turned on.
      Based on the values selected at run time, I get the corresponding selected column name and its values and shown it on HTML screen.
      // grp is datagrid
      // dgrcl is a data grid column
      // selflds is an array which has 0,1,2,3 values
      //selflds[0] = name,selflds[1]=age
      for (var l:int=0; l<grp.columnCount; l++)
      dgrcl =grp.columns[l];
      selflds[l] = dgrcl.dataField;
      // srhVals will have only one selected value at any point
      // getting the corresponding selected column name and its value
      var  srhVals:String;
      srhVals = String(grp.selectedItem[selflds[1]]);
      I am trying to achieve the above selection instead by .selectedItems somthing like this below. By doing like this, I will get all the selected items but not only one. If i try below syntax, i get error. Any one has ideas on how to do.
      srhVals = String(grp.selectedItems.selflds[1]);
        • 1. Re: Using dynamic column name in datagrid selectedItems
          Mathangi Ramachandran Level 1
          Hi
          I got my mistake, there should be no dot operator after selectedItems;
          I got a solution - it goes like this:
          for(var g:int=0;g<grp.selectedItems.length;g++)
          srhVals = srhVals + String(grp.selectedItems[g][selflds[1]]);
          So the complete scenario is like this:
          Datagrid:
          Name      Age
          a               20
          b               30
          c               40
          d               50
          I am selecting b,d in UI. At run time, I get programatically the selecteditem column name as "Name", loop through the selecteditems and store the value in srhVals as b,d.
          b,d will be finally shown in UI.
