9 Replies Latest reply: Feb 8, 2012 11:25 AM by Mr. Horton RSS
    Extra Space printed with EPS file
    freshnayab Community Member
      Hi -
      This is what i am doing. I open an eps file in illustrator and do a save as eps again (reason for doing this is the original eps when edited contains lot of invalid DSC header info which the HP printer fails to understand). The EPS is saved with the following settings in adobe illustrator CS5:
      EPS Options:
      Version = Illustrator 3 EPS
      Preview = None
      Options = Checked only "Compatible Gradient and Gradient Mesh Printing"
      Adobe PostScript = LanguageLevel2
      After doing this i confirmed the eps file header info is all valid.
      The problem iam facing is when this EPS is used to be printed by the printer, the printer prints the image perfectly fine on the coordinate settings where i intend, BUT after the image has been printed, blank space almost equal to a blank page appears and then the remaining text is printed. I tried resizing the image, selecting the art box size equal to the image size but none of it worked. The setting mentioned above is required for the PS HP printer. Dont know from where the extra space is coming up after the image has been printed.
      PLEASE somebody have some solution or some information to solve this.
        • 1. Re: Extra Space printed with EPS file
          Mr. Horton Community Member
          Output a pdf of the orginial EPS and compare it with the results you are getting from the EPS file you are creating with CS5.
          • 2. Re: Extra Space printed with EPS file
            When i ran the same program using the EPS file and created a PDF, i did not have the problem of blank space. Everything came in the position i wanted to, the logo and the text, but the images are now coming as only boxes. This is probably because the SQR program only prints JPEG/BMP not EPS, when its output is selected as PDF. Any idea why the extra space is there after the EPS image has been printed by the printer. If you dont mind ,if sending the EPS file will help us to figure the issue, i can send it to you. And thanks for your prompt reply.
            • 3. Re: Extra Space printed with EPS file
              Send it.
              • 4. Re: Extra Space printed with EPS file
                This is the EPS code below, hope this helps to identify my problem. Thanks
                %!PS-Adobe-3.0 EPSF-3.0
                %%Creator: Adobe Illustrator(TM) 3.2
                %%AI8_CreatorVersion: 15.1.0
                %%For: (cis-a) ()
                %%Title: (logo_Scribus_AI.eps)
                %%CreationDate: 2/8/2012 9:42 AM
                %%Canvassize: 16383
                %%BoundingBox: 123 307 489 484
                %%DocumentProcessColors: Black
                %%DocumentSuppliedResources: procset Adobe_packedarray 2.0 0
                %%+ procset Adobe_cshow 1.1 0
                %%+ procset Adobe_customcolor 1.0 0
                %%+ procset Adobe_IllustratorA_AI3 1.0 1
                %AI3_ColorUsage: Color
                %AI3_IncludePlacedImages
                %AI3_TemplateBox: 306 395 306 395
                %AI3_TileBox: -78.0884 101.5049 689.9121 689.5049
                %AI3_DocumentPreview: Header
                %%PageOrigin:0 0
                %AI7_GridSettings: 72 8 72 8 1 0 0.8 0.8 0.8 0.9 0.9 0.9
                %AI9_Flatten: 1
                %AI12_CMSettings: 00.MS
                %%EndComments
                %%BeginProlog
                %%BeginResource: procset Adobe_packedarray 2.0 0
                %%Title: (Packed Array Operators)
                %%Version: 2.0 0
                %%CreationDate: (8/2/90) ()
                %%Copyright: ((C) 1987-1996 Adobe Systems Incorporated All Rights Reserved)
                userdict /Adobe_packedarray 5 dict dup begin put
                /initialize
                /packedarray where
                      pop
                      Adobe_packedarray begin
                      Adobe_packedarray
                            dup xcheck
                                  bind
                                  } if
                            userdict 3 1 roll put
                            } forall
                end
                      } ifelse
                } def
                /terminate
                } def
                /packedarray
                array astore readonly
                } def
                /setpacking
                pop
                } def
                /currentpacking
                false
                } def
                currentdict readonly pop end
                %%EndResource
                Adobe_packedarray /initialize get exec
                %%BeginResource: procset Adobe_cshow 1.1 0
                %%Title: (cshow Operator)
                %%Version: 1.1 0
                %%CreationDate: (1/23/89) ()
                currentpacking true setpacking
                userdict /Adobe_cshow 3 dict dup begin put
                /initialize
                /cshow where
                      pop
                      userdict /Adobe_cshow_vars 1 dict dup begin put
                      /_cshow
                            {} def
                      Adobe_cshow begin
                      Adobe_cshow
                            dup xcheck
                                  bind
                                  } if
                            } forall
                end
                end
                      } ifelse
                } def
                /terminate
                } def
                /cshow
                exch
                Adobe_cshow_vars
                      exch /_cshow
                      exch put
                      0 0 Adobe_cshow_vars /_cshow get exec
                      } forall
                } def
                setpacking
                %%EndResource
                %%BeginResource: procset Adobe_customcolor 1.0 0
                %%Title: (Custom Color Operators)
                %%Version: 1.0 0
                %%CreationDate: (5/9/88) ()
                userdict /Adobe_customcolor 5 dict dup begin put
                /initialize
                /setcustomcolor where
                      pop
                      Adobe_customcolor begin
                      Adobe_customcolor
                            dup xcheck
                                  bind
                                  } if
                            pop pop
                            } forall
                end
                      } ifelse
                } def
                /terminate
                currentdict Adobe_customcolor eq
                end
                      } if
                } def
                /findcmykcustomcolor
                5 packedarray
                }  def
                /setcustomcolor
                exch
                aload pop pop
                4
                      4 index mul 4 1 roll
                      } repeat
                5 -1 roll pop
                setcmykcolor
                } def
                /setoverprint
                pop
                } def
                setpacking
                %%EndResource
                %%BeginResource: procset Adobe_IllustratorA_AI3 1.1 3
                %%Title: (Adobe Illustrator (R) Version 3.0 Abbreviated Prolog)
                %%Version: 1.1 3
                %%CreationDate: (3/7/1994) ()
                userdict /Adobe_IllustratorA_AI3 61 dict dup begin put
                /initialize
                userdict /Adobe_IllustratorA_AI3_vars 58 dict dup begin put
                /_lp /none def
                /_pf {} def
                /_ps {} def
                /_psf {} def
                /_pss {} def
                /_pjsf {} def
                /_pjss {} def
                /_pola 0 def
                /_doClip 0 def
                /cf   currentflat def
                /_tm matrix def
                /_renderStart [/e0 /r0 /a0 /o0 /e1 /r1 /a1 /i0] def
                /_renderEnd [null null null null /i1 /i1 /i1 /i1] def
                /_render -1 def
                /_rise 0 def
                /_ax 0 def
                /_ay 0 def
                /_cx 0 def
                /_cy 0 def
                /_leading [0 0] def
                /_ctm matrix def
                /_mtx matrix def
                /_sp 16#020 def
                /_hyphen def
                /_fScl 0 def
                /_cnt 0 def
                /_hs 1 def
                /_nativeEncoding 0 def
                /_useNativeEncoding 0 def
                /_tempEncode 0 def
                /_pntr 0 def
                /_tDict 2 dict def
                /_wv 0 def
                /Tx {} def
                /Tj {} def
                /CRender {} def
                /_AI3_savepage {} def
                /_gf null def
                /_cf 4 array def
                /_if null def
                /_of false def
                /_fc {} def
                /_gs null def
                /_cs 4 array def
                /_is null def
                /_os false def
                /_sc {} def
                /_i null def
                Adobe_IllustratorA_AI3 begin
                      dup xcheck
                            bind
                            } if
                      pop pop
                      } forall
                end
                end
                Adobe_IllustratorA_AI3_vars begin
                newpath
                } def
                /terminate
                end
                end
                } def
                /_
                null def
                /ddef
                Adobe_IllustratorA_AI3_vars 3 1 roll put
                } def
                /xput
                dup load dup length exch maxlength eq
                      dup dup load dup
                      length 2 mul dict copy def
                      } if
                load begin def end
                } def
                /npop
                      pop
                      } repeat
                } def
                /sw
                dup length exch stringwidth
                exch 5 -1 roll 3 index mul add
                4 1 roll 3 1 roll mul add
                } def
                /swj
                dup 4 1 roll
                6 2 roll /_cnt 0 ddef
                {1 index eq {/_cnt _cnt 1 add ddef} if} forall pop
                exch _cnt mul exch _cnt mul 2 index add 4 1 roll 2 index add 4 1 roll pop pop
                } def
                /ss
                4 1 roll
                      2 npop
                      (0) exch 2 copy 0 exch put pop
                      gsave
                      false charpath currentpoint
                      4 index setmatrix
                      stroke
                      grestore
                      moveto
                      2 copy rmoveto
                      } exch cshow
                3 npop
                } def
                /jss
                4 1 roll
                      2 npop
                      gsave
                      _sp eq
                            exch 6 index 6 index 6 index 5 -1 roll widthshow
                            currentpoint
                            4 index setmatrix stroke
                            }ifelse
                      grestore
                      moveto
                      2 copy rmoveto
                      } exch cshow
                6 npop
                } def
                /sp
                      2 npop (0) exch
                      false charpath
                      2 copy rmoveto
                      } exch cshow
                2 npop
                } def
                /jsp
                      2 npop
                      _sp eq
                            exch 5 index 5 index 5 index 5 -1 roll widthshow
                            false charpath
                            }ifelse
                      2 copy rmoveto
                      } exch cshow
                5 npop
                } def
                /pl
                transform
                1. 0.25 sub round 0.25 add exch
                2. 0.25 sub round 0.25 add exch
                itransform
                } def
                /setstrokeadjust where
                      pop true setstrokeadjust
                      /c
                      curveto
                      } def
                      /C
                      /c load def
                      /v
                      currentpoint 6 2 roll curveto
                      } def
                      /V
                      /v load def
                      /y
                      2 copy curveto
                      } def
                      /Y
                      /y load def
                      /l
                      lineto
                      } def
                      /L
                      /l load def
                      /m
                      moveto
                      } def
                      /c
                      pl curveto
                      } def
                      /C
                      /c load def
                      /v
                      currentpoint 6 2 roll pl curveto
                      } def
                      /V
                      /v load def
                      /y
                      pl 2 copy curveto
                      } def
                      /Y
                      /y load def
                      /l
                      pl lineto
                      } def
                      /L
                      /l load def
                      /m
                      pl moveto
                      } def
                      }ifelse
                /d
                setdash
                } def
                /cf   {} def
                /i
                dup 0 eq
                      pop cf
                      } if
                setflat
                } def
                /j
                setlinejoin
                } def
                /J
                setlinecap
                } def
                /M
                setmiterlimit
                } def
                /w
                setlinewidth
                } def
                /H
                {} def
                /h
                closepath
                } def
                /N
                _pola 0 eq
                      _doClip 1 eq {clip /_doClip 0 ddef} if
                      newpath
                      /CRender {N} ddef
                      }ifelse
                } def
                /n
                {N} def
                /F
                _pola 0 eq
                      _doClip 1 eq
                            gsave _pf grestore clip newpath /_lp /none ddef _fc
                            /_doClip 0 ddef
                            _pf
                            }ifelse
                      /CRender {F} ddef
                      }ifelse
                } def
                /f
                closepath
                F
                } def
                /S
                _pola 0 eq
                      _doClip 1 eq
                            gsave _ps grestore clip newpath /_lp /none ddef _sc
                            /_doClip 0 ddef
                            _ps
                            }ifelse
                      /CRender {S} ddef
                      }ifelse
                } def
                /s
                closepath
                S
                } def
                /B
                _pola 0 eq
                      _doClip 1 eq
                      gsave F grestore
                            gsave S grestore clip newpath /_lp /none ddef _sc
                            /_doClip 0 ddef
                            S
                            }ifelse
                      /CRender {B} ddef
                      }ifelse
                } def
                /b
                closepath
                B
                } def
                /W
                /_doClip 1 ddef
                } def
                count 0 ne
                      dup type (stringtype) eq {pop} if
                      } if
                _pola 0 eq {newpath} if
                } def
                /u
                {} def
                /U
                {} def
                /q
                _pola 0 eq {gsave} if
                } def
                /Q
                _pola 0 eq {grestore} if
                } def
                /*u
                _pola 1 add /_pola exch ddef
                } def
                /*U
                _pola 1 sub /_pola exch ddef
                _pola 0 eq {CRender} if
                } def
                /D
                {pop} def
                /*w
                {} def
                /*W
                {} def
                /_i save ddef
                6 1 roll 4 npop
                concat pop
                userdict begin
                /showpage {} def
                0 setgray
                0 setlinecap
                1 setlinewidth
                0 setlinejoin
                10 setmiterlimit
                [] 0 setdash
                /setstrokeadjust where {pop false setstrokeadjust} if
                newpath
                0 setgray
                false setoverprint
                } def
                end
                _i restore
                } def
                /O
                0 ne
                /_of exch ddef
                /_lp /none ddef
                } def
                /R
                0 ne
                /_os exch ddef
                /_lp /none ddef
                } def
                /g
                /_gf exch ddef
                /_fc
                _lp /fill ne
                      _of setoverprint
                      _gf setgray
                      /_lp /fill ddef
                      } if
                } ddef
                /_pf
                _fc
                fill
                } ddef
                /_psf
                _fc
                ashow
                } ddef
                /_pjsf
                _fc
                awidthshow
                } ddef
                /_lp /none ddef
                } def
                /G
                /_gs exch ddef
                /_sc
                _lp /stroke ne
                      _os setoverprint
                      _gs setgray
                      /_lp /stroke ddef
                      } if
                } ddef
                /_ps
                _sc
                stroke
                } ddef
                /_pss
                _sc
                ss
                } ddef
                /_pjss
                _sc
                jss
                } ddef
                /_lp /none ddef
                } def
                /k
                _cf astore pop
                /_fc
                _lp /fill ne
                      _of setoverprint
                      _cf aload pop setcmykcolor
                      /_lp /fill ddef
                      } if
                } ddef
                /_pf
                _fc
                fill
                } ddef
                /_psf
                _fc
                ashow
                } ddef
                /_pjsf
                _fc
                awidthshow
                } ddef
                /_lp /none ddef
                } def
                /K
                _cs astore pop
                /_sc
                _lp /stroke ne
                      _os setoverprint
                      _cs aload pop setcmykcolor
                      /_lp /stroke ddef
                      } if
                } ddef
                /_ps
                _sc
                stroke
                } ddef
                /_pss
                _sc
                ss
                } ddef
                /_pjss
                _sc
                jss
                } ddef
                /_lp /none ddef
                } def
                /x
                /_gf exch ddef
                findcmykcustomcolor
                /_if exch ddef
                /_fc
                _lp /fill ne
                      _of setoverprint
                      _if _gf 1 exch sub setcustomcolor
                      /_lp /fill ddef
                      } if
                } ddef
                /_pf
                _fc
                fill
                } ddef
                /_psf
                _fc
                ashow
                } ddef
                /_pjsf
                _fc
                awidthshow
                } ddef
                /_lp /none ddef
                } def
                /X
                /_gs exch ddef
                findcmykcustomcolor
                /_is exch ddef
                /_sc
                _lp /stroke ne
                      _os setoverprint
                      _is _gs 1 exch sub setcustomcolor
                      /_lp /stroke ddef
                      } if
                } ddef
                /_ps
                _sc
                stroke
                } ddef
                /_pss
                _sc
                ss
                } ddef
                /_pjss
                _sc
                jss
                } ddef
                /_lp /none ddef
                } def
                /A
                pop
                } def
                setpacking
                /annotatepage
                } def
                %%EndResource
                %%EndProlog
                %%BeginSetup
                Adobe_cshow /initialize get exec
                Adobe_customcolor /initialize get exec
                Adobe_IllustratorA_AI3 /initialize get exec
                %%EndSetup
                0 A
                u
                0 O
                0 0 0 1 k
                0 J 0 j 1 w 10 M []0 d
                1. 147.8125 357.4219 m
                2. 147.8125 307.4668 l
                3. 165.5332 307.4668 l
                4. 148.0332 357.4219 l
                5. 147.8125 357.4219 l
                6. 147.8125 357.4219 l
                f
                1. 211.0371 414.4248 m
                2. 216.0234 414.4248 218.3496 417.3042 218.3496 423.1743 c
                3. 218.3496 483.541 l
                4. 203.7266 483.541 l
                5. 203.7266 423.1743 l
                6. 203.7266 417.3042 206.0527 414.4248 211.0371 414.4248 c
                7. 211.0371 414.4248 l
                f
                1. 232.084 483.541 m
                2. 232.084 423.728 l
                3. 232.084 409.9941 224.1069 402.4629 211.0371 402.4629 c
                4. 197.9668 402.4629 189.9922 409.9941 189.9922 423.728 c
                5. 189.9922 483.541 l
                6. 163.752 483.541 l
                7. 172.5449 480.6328 176.832 472.3203 176.832 462.7178 c
                8. 176.832 456.8477 l
                9. 163.0977 456.8477 l
                10. 163.0977 463.0493 l
                11. 163.0977 469.8066 159.9961 472.6855 156.4512 472.6855 c
                12. 150.9141 472.6855 149.1406 469.8066 149.1406 463.8252 c
                13. 149.1406 423.2847 l
                14. 149.1406 417.3042 150.9141 414.4248 156.4512 414.4248 c
                15. 161.4355 414.4248 163.0977 417.3042 163.0977 422.5098 c
                16. 163.0977 432.146 l
                17. 176.832 432.146 l
                18. 176.832 422.9531 l
                19. 176.832 411.6563 170.1855 402.4629 156.4512 402.4629 c
                20. 142.0527 402.4629 135.4063 411.6563 135.4063 422.9531 c
                21. 135.4063 464.1577 l
                22. 135.4063 473.1484 139.6309 480.7871 148.6055 483.541 c
                123 483.541 l
                123 307.4668 l
                1. 135.4063 307.4668 l
                2. 135.4063 387.4395 l
                3. 148.1445 387.4395 l
                4. 164.8691 341.6934 l
                5. 165.0918 341.6934 l
                6. 165.0918 387.4395 l
                7. 177.4961 387.4395 l
                8. 177.4961 307.4668 l
                9. 203.9453 307.4668 l
                10. 203.9453 340.6982 l
                11. 187.3301 387.4395 l
                12. 201.2871 387.4395 l
                13. 210.9219 356.9785 l
                14. 211.1445 356.9785 l
                15. 220.3379 387.4395 l
                16. 234.2949 387.4395 l
                17. 217.6797 340.6982 l
                18. 217.6797 307.4668 l
                19. 299.0752 307.4668 l
                20. 299.0752 483.541 l
                21. 232.084 483.541 l
                22. 232.084 483.541 l
                f
                0 0 0 0 k
                1. 135.4063 464.1577 m
                2. 135.4063 422.9531 l
                3. 135.4063 411.6563 142.0527 402.4629 156.4512 402.4629 c
                4. 170.1855 402.4629 176.832 411.6563 176.832 422.9531 c
                5. 176.832 432.146 l
                7. 163.0977 422.5098 l
                8. 163.0977 417.3042 161.4355 414.4248 156.4512 414.4248 c
                9. 150.9141 414.4248 149.1406 417.3042 149.1406 423.2847 c
                10. 149.1406 463.8252 l
                11. 149.1406 469.8066 150.9141 472.6855 156.4512 472.6855 c
                12. 159.9961 472.6855 163.0977 469.8066 163.0977 463.0493 c
                13. 163.0977 456.8477 l
                14. 176.832 456.8477 l
                15. 176.832 462.7178 l
                16. 176.832 472.3203 172.5449 480.6328 163.752 483.541 c
                17. 148.6055 483.541 l
                18. 139.6309 480.7871 135.4063 473.1484 135.4063 464.1577 c
                19. 135.4063 464.1577 l
                f
                1. 165.0918 387.4395 m
                2. 165.0918 341.6934 l
                3. 164.8691 341.6934 l
                4. 148.1445 387.4395 l
                5. 135.4063 387.4395 l
                6. 135.4063 307.4668 l
                7. 147.8125 307.4668 l
                8. 147.8125 357.4219 l
                9. 148.0332 357.4219 l
                10. 165.5332 307.4668 l
                11. 177.4961 307.4668 l
                12. 177.4961 387.4395 l
                13. 165.0918 387.4395 l
                14. 165.0918 387.4395 l
                f
                1. 234.2949 387.4395 m
                2. 220.3379 387.4395 l
                3. 211.1445 356.9785 l
                4. 210.9219 356.9785 l
                5. 201.2871 387.4395 l
                6. 187.3301 387.4395 l
                7. 203.9453 340.6982 l
                8. 203.9453 307.4668 l
                9. 217.6797 307.4668 l
                10. 217.6797 340.6982 l
                11. 234.2949 387.4395 l
                12. 234.2949 387.4395 l
                f
                1. 211.0371 402.4629 m
                2. 224.1069 402.4629 232.084 409.9941 232.084 423.728 c
                3. 232.084 483.541 l
                4. 218.3496 483.541 l
                5. 218.3496 423.1743 l
                6. 218.3496 417.3042 216.0234 414.4248 211.0371 414.4248 c
                7. 206.0527 414.4248 203.7266 417.3042 203.7266 423.1743 c
                8. 203.7266 483.541 l
                9. 189.9922 483.541 l
                10. 189.9922 423.728 l
                11. 189.9922 409.9941 197.9668 402.4629 211.0371 402.4629 c
                12. 211.0371 402.4629 l
                f
                0 0 0 1 k
                1. 310.4805 483.541 m
                2. 333.1299 483.541 l
                3. 333.1299 481.0654 l
                4. 323.3184 481.0654 l
                5. 323.3184 450.4375 l
                6. 320.292 450.4375 l
                7. 320.292 481.0654 l
                8. 310.4805 481.0654 l
                9. 310.4805 483.541 l
                10. 310.4805 483.541 l
                f
                1. 337.3936 450.4375 m
                2. 337.3936 483.541 l
                3. 340.1465 483.541 l
                4. 340.1465 470.5195 l
                5. 342.7119 473.1797 344.8223 474.7383 348.3057 474.7383 c
                6. 353.2588 474.7383 355.3672 471.8955 355.3672 466.7148 c
                7. 355.3672 450.4375 l
                8. 352.6172 450.4375 l
                9. 352.6172 466.4395 l
                10. 352.6172 470.3828 351.4248 472.5371 347.7568 472.5371 c
                11. 344.8223 472.5371 343.1709 470.749 340.1465 467.998 c
                12. 340.1465 450.4375 l
                13. 337.3936 450.4375 l
                14. 337.3936 450.4375 l
                f
                *u
                1 D
                1. 375.542 464.4683 m
                2. 374.9922 469.3745 372.8369 472.4917 368.666 472.5376 c
                3. 363.8037 472.5835 361.7422 467.6323 361.6953 464.4683 c
                4. 375.542 464.4683 l
                5. 375.542 464.4683 l
                f
                0 D
                1. 361.6953 462.2671 m
                2. 361.6953 456.8569 363.9434 452.1802 369.3525 452.1802 c
                3. 372.4248 452.1802 373.9375 453.2349 376.3223 456.9946 c
                4. 378.5684 455.8022 l
                5. 376.001 451.5845 373.6621 449.98 369.123 449.98 c
                6. 362.8877 449.98 358.9453 453.9683 358.9453 462.3589 c
                7. 358.9453 469.7407 362.7051 474.7388 368.7568 474.7388 c
                8. 375.2217 474.7388 378.292 469.6489 378.292 462.2671 c
                9. 361.6953 462.2671 l
                10. 361.6953 462.2671 l
                f
                *U
                1. 412.7256 473.8213 m
                2. 411.3037 478.6816 408.6465 481.5234 404.6563 481.5234 c
                3. 398.0986 481.5234 395.21 475.1045 395.21 466.9893 c
                4. 395.21 458.874 398.0986 452.4551 404.9775 452.4551 c
                5. 410.2959 452.4551 412.2217 456.2148 413.3223 460.5244 c
                6. 416.166 460.0205 l
                7. 414.9268 454.1055 411.8555 449.9795 404.9307 449.9795 c
                8. 396.9082 449.9795 392.1846 456.7646 392.1846 466.9893 c
                9. 392.1846 477.2139 396.9082 484 404.9307 484 c
                10. 410.8447 484 414.1006 479.8271 415.5234 474.417 c
                11. 412.7256 473.8213 l
                12. 412.7256 473.8213 l
                f
                *u
                1. 423.5459 450.4375 m
                2. 420.7959 450.4375 l
                3. 420.7959 474.2793 l
                4. 423.5459 474.2793 l
                5. 423.5459 450.4375 l
                6. 423.5459 450.4375 l
                f
                1. 420.7959 479.5068 m
                2. 420.7959 483.541 l
                3. 423.5459 483.541 l
                4. 423.5459 479.5068 l
                5. 420.7959 479.5068 l
                6. 420.7959 479.5068 l
                f
                *U
                1. 431.2939 474.2788 m
                2. 431.2939 482.0737 l
                3. 434.0459 482.0737 l
                4. 434.0459 474.2788 l
                5. 439.2734 474.2788 l
                6. 439.2734 472.0786 l
                7. 434.0459 472.0786 l
                8. 434.0459 454.6099 l
                9. 434.0459 453.0044 434.7793 452.1792 436.4756 452.1792 c
                10. 437.3916 452.1792 438.4023 452.4087 439.2734 452.6841 c
                11. 439.2734 450.3911 l
                12. 438.3555 450.2534 437.3916 449.979 436.4756 449.979 c
                13. 432.5781 449.979 431.2939 451.2622 431.2939 454.1509 c
                14. 431.2939 472.0786 l
                15. 427.7178 472.0786 l
                16. 427.7178 474.2788 l
                17. 431.2939 474.2788 l
                18. 431.2939 474.2788 l
                f
                1. 451.9717 454.8853 m
                2. 452.0645 454.8853 l
                3. 458.7119 474.2798 l
                4. 461.6465 474.2798 l
                5. 452.751 448.7417 l
                6. 451.1484 444.0649 449.4512 442.0015 445.1396 442.0015 c
                7. 443.9492 442.0015 443.2139 442.0933 442.5742 442.2769 c
                8. 442.5742 444.5239 l
                9. 443.3984 444.4321 444.2686 444.2026 445.3242 444.2026 c
                10. 447.25 444.2026 449.3594 445.8989 450.6895 450.8052 c
                11. 442.3896 474.2798 l
                12. 445.416 474.2798 l
                13. 451.9717 454.8853 l
                14. 451.9717 454.8853 l
                f
                1. 314.5059 435.6089 m
                2. 314.5059 413.0513 l
                3. 314.5059 406.7241 317.5791 404.5229 323.4482 404.5229 c
                4. 329.3174 404.5229 332.3867 406.7241 332.3867 413.0513 c
                5. 332.3867 435.6089 l
                6. 335.415 435.6089 l
                7. 335.415 413.3257 l
                8. 335.415 405.8071 331.4707 402.0474 323.4482 402.0474 c
                9. 315.4238 402.0474 311.4814 405.8071 311.4814 413.3257 c
                10. 311.4814 435.6089 l
                11. 314.5059 435.6089 l
                12. 314.5059 435.6089 l
                f
                1. 340.3193 402.5049 m
                2. 340.3193 426.3467 l
                3. 343.0713 426.3467 l
                4. 343.0713 422.5869 l
                5. 345.6367 425.2471 347.7471 426.8057 351.2314 426.8057 c
                6. 356.1836 426.8057 358.292 423.9629 358.292 418.7822 c
                7. 358.292 402.5049 l
                8. 355.542 402.5049 l
                9. 355.542 418.5068 l
                10. 355.542 422.4502 354.3496 424.6045 350.6816 424.6045 c
                11. 347.7471 424.6045 346.0957 422.8164 343.0713 420.0654 c
                12. 343.0713 402.5049 l
                13. 340.3193 402.5049 l
                14. 340.3193 402.5049 l
                f
                *u
                1. 366.2246 402.5054 m
                2. 363.4727 402.5054 l
                3. 363.4727 426.3472 l
                4. 366.2246 426.3472 l
                5. 366.2246 402.5054 l
                6. 366.2246 402.5054 l
                f
                1. 363.4727 431.5747 m
                2. 363.4727 435.6089 l
                3. 366.2246 435.6089 l
                4. 366.2246 431.5747 l
                5. 363.4727 431.5747 l
                6. 363.4727 431.5747 l
                f
                *U
                1. 370.1221 426.3467 m
                2. 373.0547 426.3467 l
                3. 379.5674 406.7236 l
                4. 379.6592 406.7236 l
                5. 386.2598 426.3467 l
                6. 389.1963 426.3467 l
                7. 380.9873 402.5049 l
                8. 378.2822 402.5049 l
                9. 370.1221 426.3467 l
                10. 370.1221 426.3467 l
                f
                *u
                1 D
                1. 406.9375 416.5352 m
                2. 406.3867 421.4414 404.2334 424.5586 400.0605 424.6045 c
                3. 395.2002 424.6504 393.1367 419.6992 393.0898 416.5352 c
                4. 406.9375 416.5352 l
                5. 406.9375 416.5352 l
                f
                0 D
                1. 393.0898 414.334 m
                2. 393.0898 408.9238 395.3379 404.2471 400.749 404.2471 c
                3. 403.8213 404.2471 405.333 405.3018 407.7168 409.0615 c
                4. 409.9629 407.8691 l
                5. 407.3965 403.6514 405.0566 402.0469 400.5176 402.0469 c
                6. 394.2842 402.0469 390.3398 406.0352 390.3398 414.4258 c
                7. 390.3398 421.8076 394.0996 426.8057 400.1533 426.8057 c
                8. 406.6182 426.8057 409.6875 421.7158 409.6875 414.334 c
                9. 393.0898 414.334 l
                10. 393.0898 414.334 l
                f
                *U
                1. 414.0449 402.5049 m
                2. 414.0449 426.3467 l
                3. 416.7949 426.3467 l
                4. 416.7949 421.8076 l
                5. 416.8867 421.8076 l
                6. 418.1719 424.7422 420.7393 426.8057 423.7656 426.8057 c
                7. 425.002 426.8057 l
                8. 425.002 424.1465 l
                9. 423.7656 424.1465 l
                10. 420.7393 424.1465 416.7949 420.5703 416.7949 415.9854 c
                11. 416.7949 402.5049 l
                12. 414.0449 402.5049 l
                13. 414.0449 402.5049 l
                f
                1. 428.6699 408.2822 m
                2. 430.917 405.0723 432.9336 404.2471 436.0527 404.2471 c
                3. 439.0791 404.2471 441.3721 406.2188 441.3721 408.7861 c
                4. 441.3721 415.71 427.3398 411.8125 427.3398 420.2949 c
                5. 427.3398 424.7881 430.8721 426.8057 434.9072 426.8057 c
                6. 438.8945 426.8057 441.417 425.2471 443.1143 422.4961 c
                7. 441.0039 421.0283 l
                8. 439.3994 423.2295 437.6572 424.6045 434.8154 424.6045 c
                9. 432.1553 424.6045 430.0918 423.3213 430.0918 420.4326 c
                10. 430.0918 414.6094 444.1221 418.0479 444.1221 408.7861 c
                11. 444.1221 404.5225 440.1777 402.0469 435.8701 402.0469 c
                12. 432.2021 402.0469 428.8994 403.5137 426.6533 406.8613 c
                13. 428.6699 408.2822 l
                14. 428.6699 408.2822 l
                f
                *u
                1. 451.4111 402.5054 m
                2. 448.6611 402.5054 l
                3. 448.6611 426.3472 l
                4. 451.4111 426.3472 l
                5. 451.4111 402.5054 l
                6. 451.4111 402.5054 l
                f
                1. 448.6611 431.5747 m
                2. 448.6611 435.6089 l
                3. 451.4111 435.6089 l
                4. 451.4111 431.5747 l
                5. 448.6611 431.5747 l
                6. 448.6611 431.5747 l
                f
                *U
                1. 458.7021 426.3467 m
                2. 458.7021 434.1416 l
                3. 461.4521 434.1416 l
                4. 461.4521 426.3467 l
                5. 466.6777 426.3467 l
                6. 466.6777 424.1465 l
                7. 461.4521 424.1465 l
                8. 461.4521 406.6777 l
                9. 461.4521 405.0723 462.1855 404.2471 463.8809 404.2471 c
                10. 464.7988 404.2471 465.8066 404.4766 466.6777 404.752 c
                11. 466.6777 402.459 l
                12. 465.7617 402.3213 464.7988 402.0469 463.8809 402.0469 c
                13. 459.9854 402.0469 458.7021 403.3301 458.7021 406.2188 c
                14. 458.7021 424.1465 l
                15. 455.124 424.1465 l
                16. 455.124 426.3467 l
                17. 458.7021 426.3467 l
                18. 458.7021 426.3467 l
                f
                1. 479.1494 406.9521 m
                2. 479.2412 406.9521 l
                3. 485.8887 426.3467 l
                4. 488.8232 426.3467 l
                5. 479.9277 400.8086 l
                6. 478.3252 396.1318 476.627 394.0684 472.3174 394.0684 c
                7. 471.125 394.0684 470.3906 394.1602 469.75 394.3438 c
                8. 469.75 396.5908 l
                9. 470.5752 396.499 471.4463 396.2695 472.5 396.2695 c
                10. 474.4258 396.2695 476.5361 397.9658 477.8662 402.8721 c
                11. 469.5674 426.3467 l
                12. 472.5918 426.3467 l
                13. 479.1494 406.9521 l
                14. 479.1494 406.9521 l
                f
                *u
                1 D
                1. 314.1494 367.0254 m
                2. 314.1494 360.5605 316.3047 356.8477 321.2109 356.8477 c
                3. 326.1162 356.8477 328.2715 360.5605 328.2715 367.0254 c
                4. 328.2715 373.4912 326.1162 377.2061 321.2109 377.2061 c
                5. 316.3047 377.2061 314.1494 373.4912 314.1494 367.0254 c
                6. 314.1494 367.0254 l
                f
                0 D
                1. 331.0215 367.0254 m
                2. 331.0215 360.5605 328.6367 354.6465 321.2109 354.6465 c
                3. 313.7842 354.6465 311.3994 360.5605 311.3994 367.0254 c
                4. 311.3994 373.4912 313.7842 379.4072 321.2109 379.4072 c
                5. 328.6367 379.4072 331.0215 373.4912 331.0215 367.0254 c
                6. 331.0215 367.0254 l
                f
                *U
                1. 339.1367 376.7471 m
                2. 339.1367 355.1055 l
                3. 336.3867 355.1055 l
                4. 336.3867 376.7471 l
                5. 332.4443 376.7471 l
                6. 332.4443 378.9473 l
                7. 336.3867 378.9473 l
                8. 336.3867 382.3398 l
                9. 336.3867 386.4668 338.0381 388.668 342.1182 388.668 c
                10. 343.127 388.668 344.0898 388.4844 345.0977 388.3008 c
                11. 345.0977 386.0078 l
                12. 344.2266 386.2832 343.4033 386.4668 342.3926 386.4668 c
                13. 340.2393 386.4668 339.1367 385.4121 339.1367 382.6611 c
                14. 339.1367 378.9473 l
                15. 343.999 378.9473 l
                16. 343.999 376.7471 l
                17. 339.1367 376.7471 l
                18. 339.1367 376.7471 l
                f
                1. 311.4814 340.5703 m
                2. 316.5693 340.5703 l
                3. 332.2949 312.9688 l
                4. 332.3867 312.9688 l
                5. 332.3867 340.5703 l
                6. 335.415 340.5703 l
                7. 335.415 307.4668 l
                8. 332.2949 307.4668 l
                9. 314.5977 338.0957 l
                10. 314.5059 338.0957 l
                11. 314.5059 307.4668 l
                12. 311.4814 307.4668 l
                13. 311.4814 340.5703 l
                14. 311.4814 340.5703 l
                f
                *u
                1 D
                1. 356.4131 321.499 m
                2. 355.8623 326.4023 353.708 329.5215 349.5361 329.5664 c
                3. 344.6738 329.6143 342.6123 324.6611 342.5654 321.499 c
                4. 356.4131 321.499 l
                5. 356.4131 321.499 l
                f
                0 D
                1. 342.5654 319.2969 m
                2. 342.5654 313.8867 344.8125 309.209 350.2227 309.209 c
                3. 353.2949 309.209 354.8066 310.2637 357.1924 314.0234 c
                4. 359.4375 312.833 l
                5. 356.8721 308.6133 354.5322 307.0098 349.9932 307.0098 c
                6. 343.7578 307.0098 339.8154 310.999 339.8154 319.3887 c
                7. 339.8154 326.7695 343.5752 331.7676 349.627 331.7676 c
                8. 356.0918 331.7676 359.1631 326.6777 359.1631 319.2969 c
                9. 342.5654 319.2969 l
                10. 342.5654 319.2969 l
                f
                *U
                1. 361.4111 331.3086 m
                2. 364.208 331.3086 l
                3. 369.4336 312.1445 l
                4. 369.5264 312.1445 l
                5. 374.9834 331.3086 l
                6. 377.6875 331.3086 l
                7. 383.0059 312.1445 l
                8. 383.0977 312.1445 l
                9. 388.4609 331.3086 l
                10. 391.3047 331.3086 l
                11. 384.3809 307.4668 l
                12. 381.6758 307.4668 l
                13. 376.3105 326.6328 l
                14. 376.2207 326.6328 l
                15. 370.9014 307.4668 l
                16. 368.0586 307.4668 l
                17. 361.4111 331.3086 l
                18. 361.4111 331.3086 l
                f
                1. 410.8809 321.499 m
                2. 400.749 340.5703 l
                3. 404.1406 340.5703 l
                4. 412.3027 324.2041 l
                5. 421.0137 340.5703 l
                6. 424.4072 340.5703 l
                7. 413.9092 321.499 l
                8. 413.9092 307.4668 l
                9. 410.8809 307.4668 l
                10. 410.8809 321.499 l
                11. 410.8809 321.499 l
                f
                *u
                1 D
                1. 423.9951 319.3887 m
                2. 423.9951 312.9238 426.1514 309.209 431.0566 309.209 c
                3. 435.9609 309.209 438.1182 312.9238 438.1182 319.3887 c
                4. 438.1182 325.8535 435.9609 329.5664 431.0566 329.5664 c
                5. 426.1514 329.5664 423.9951 325.8535 423.9951 319.3887 c
                6. 423.9951 319.3887 l
                f
                0 D
                1. 440.8682 319.3887 m
                2. 440.8682 312.9238 438.4834 307.0098 431.0566 307.0098 c
                3. 423.6289 307.0098 421.2451 312.9238 421.2451 319.3887 c
                4. 421.2451 325.8535 423.6289 331.7676 431.0566 331.7676 c
                5. 438.4834 331.7676 440.8682 325.8535 440.8682 319.3887 c
                6. 440.8682 319.3887 l
                f
                *U
                1. 444.7188 307.4668 m
                2. 444.7188 331.3086 l
                3. 447.4707 331.3086 l
                4. 447.4707 326.7695 l
                5. 447.5625 326.7695 l
                6. 448.8457 329.7061 451.415 331.7676 454.4404 331.7676 c
                7. 455.6777 331.7676 l
                8. 455.6777 329.1094 l
                9. 454.4404 329.1094 l
                10. 451.415 329.1094 447.4707 325.5322 447.4707 320.9482 c
                11. 447.4707 307.4668 l
                12. 444.7188 307.4668 l
                13. 444.7188 307.4668 l
                f
                1. 459.4834 307.4668 m
                2. 459.4834 340.5703 l
                3. 462.2334 340.5703 l
                4. 462.2334 318.6543 l
                5. 473.2842 331.3086 l
                6. 476.4463 331.3086 l
                7. 468.6982 322.415 l
                8. 477.6387 307.4668 l
                9. 474.5674 307.4668 l
                10. 466.9561 320.4883 l
                11. 462.2334 315.1699 l
                12. 462.2334 307.4668 l
                13. 459.4834 307.4668 l
                14. 459.4834 307.4668 l
                f
                U
                %%PageTrailer
                gsave annotatepage grestore showpage
                %%Trailer
                Adobe_IllustratorA_AI3 /terminate get exec
                Adobe_customcolor /terminate get exec
                Adobe_cshow /terminate get exec
                Adobe_packedarray /terminate get exec
                %%EOF
                • 5. Re: Extra Space printed with EPS file
                  I have attached an Acrobat window snippet showing the result I got after distilling your file with Distiller 9.
                  Note that in your post the hyphen definition was altered to a symbol and since it didn't translate into 7-bit text I substituted "/hyphen 0 def".
                  Please confirm that my results in Acrobat, on screen, are what you want on paper from an HP printer.
                  Also, It would seem that the file you posted only has the header in it, not the header and following text.
                  If that is the case you will need to send/post the combined file so I can see how they are joined.
                  Message was edited by: Mr. Horton
                  • 6. Re: Extra Space printed with EPS file
                    Mr. Horton firstly thanks for your quick response.
                    1- The code which was incorrectly copied over is:
                    /_hyphen (- ) def
                    Note i have added an extra space after the hypen so that the symbol does not appear.
                    2. Yes the snippet is the what is needed on the paper after being printed by the HP printer.
                    3. The code which is copied above is all what is in the eps file. The following/trailing text is generated by the SQR program right after the logo is printed. SQR prints the following text after 2 lines of logo. As far as header is concerned you mean the text which comes before the logo/image? If thats what you mean, that is also generated by SQR.
                    To confirm that the space issue is not due to my SQR program, i used one of few delievered EPS files by SQR and they got printed perfectly fine after running my program. So it proved that there is some issue when i create EPS using AI.
                    • 7. Re: Extra Space printed with EPS file
                      Is there any way you can provide an image of the printer output?
                      From you SQR program can you print to a file instead of an actual printer? If so, post or better yet email me a copy of that.
                      Also, briefly explain the purpose of the SQR program.
                      • 8. Re: Extra Space printed with EPS file
                        I can email it to you if possible the printer output. Yes i can print to file instead of printer directly and it generates a PDF but the EPS image doesnot work with PDFs.
                        • 9. Re: Extra Space printed with EPS file
                          What I would need to have is a file containing the same data as what would be sent to the printer.
