0 Replies Latest reply on Feb 6, 2012 3:05 PM by uridicystar
    Saving a .rgb (SGI format) file in Extendscript
    uridicystar Level 1
      Hello everyone,
          I'm writing a script in javascript that saves out some .rgb files.  I tried using the
      script listener by selecting Save As in Photoshop.
      However, the resulting script would only save .sgi files:
      var idsave = charIDToTypeID( "save" );
          var desc17 = new ActionDescriptor();
          var idAs = charIDToTypeID( "As  " );
          desc17.putString( idAs, "SGI" );
          var idIn = charIDToTypeID( "In  " );
          desc17.putPath( idIn, new File( "Y:\\lak_temp\\output\\theCoolest.rgb" ) );
          var idCpy = charIDToTypeID( "Cpy " );
          desc17.putBoolean( idCpy, true );
      executeAction( idsave, desc17, DialogModes.NO );
      Is there an extra step to tell Photoshop that it needs to use a sub-type of the SGI format?
      I have a plugin from telegraphics that lets me save in the .rgb format.  I imagine this is why I'm having a hard time with it.
      I also tried using the saveAs() function as mentioned in the documentation,
      but I've had no luck with it on this format:
      var RGBOptions = new SGIRGBSaveOptions();
      RGBOptions.alphaChannels = false;
      RGBOptions.spotColors = false;
      app.activeDocument.saveAs(new File( "Y:\\lak_temp\\output\\theCoolest.rgb" ), RGBOptions , false);
      I did notice that the save options object didn't pop up any attributes in the Extendscript editor.
      I thought this was wierd, since it popped up suggestions when I use the JPEGSaveOptions object.
      I'd appreciate any help.  I'd also be willing to try a javascript library that will convert files to the .rgb format.  I just haven't found one.
      Thanks!
