1 Reply Latest reply on Feb 7, 2012 8:02 AM by Muppet Mark
    PDF file name in applescript
    aflitho
      I have created a applescript to export 2 PDF's from the same file at the same time. One with crop marks and the second with out. I would like the original file name to be used, but can not seem to get this right. Below is the script. Where it says 'No Crops' or 'Crops' I would like the Indesign file name to be placed.
      Can any one help with this please?
      Andy
      tell application "Adobe InDesign CS5"
                tell active document
                          export format PDF type to "/Users/username/Desktop/No Crops X.pdf" using "No Crops" without showing options
                          export format PDF type to "/Users/username/Desktop/Crops.pdf" using "Crops with Text" without showing options
                end tell
      end tell
        • 1. Re: PDF file name in applescript
          Muppet Mark Level 5
          I don't have your options so I just comment out those lines…
                              set docName to name
                              set ASTID to AppleScript's text item delimiters
                              set AppleScript's text item delimiters to "."
                              set baseName to text item 1 of docName
                              set AppleScript's text item delimiters to ASTID
            --log (path to desktop as text) & baseName & "_X.pdf"
            --export format PDF type to (path to desktop as text) & baseName & "_X.pdf" using "No Crops" without showing options
            --export format PDF type to (path to desktop as text) & baseName & ".pdf" using "Crops with Text" without showing options
                    end tell
          end tell
