9 Replies Latest reply on Feb 15, 2012 6:15 AM by c_wolf
    Problem during installation
    c_wolf
      Hello!
      I always get the same error during installation (registered Version of Adobe InDesign CS5.5).
      my configuration:
      - Intel Pentium Dual CPU E2150 @ 1,8GHz
      - 2 GB RAM
      - Windows XP Prof. Service Pack 3
      I already tried on another machine with same configuration and there i also get the same error message.
      Hope, somebody can help me...
      Kind Regards,
      Christian
      +++ Error Message:
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 1 fatal error(s), 5 error(s), 7 warning(s)
      ERROR: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has required dependency on:
          Family: InDesign
          ProductName: Adobe InDesign CS5.5 Icon Handler x64
          MinVersion: 0.0.0.0
          This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
          Removing this dependency from list. Product may function improperly.
      WARNING: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has recommended dependency on:
          Family: Adobe Web Suite CS5.5
          ProductName: Adobe Media Encoder CS5.5 X64
          MinVersion: 0.0.0.0
          Removing this payload from the dependency list.
      WARNING: DW064: Memory requirements not met for {857CC5F0-040E-1016-A173-D55ADD80C260}
      WARNING: DW064: Memory requirements not met for {664473CD-276F-1016-B5CD-AEE1A2A589D0}
      WARNING: DW064: Memory requirements not met for {614EAB78-2A60-1016-B121-AFAD34340ACB}
      ----------- Payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 2.0.0.0 -----------
      WARNING: DF029: ARKServiceControl::StartService: Service not started/stopped SwitchBoard. Current State: 0 Exit Code: 0 Service Specific Exit Code: 0(Seq 1)
      ----------- Payload: {857CC5F0-040E-1016-A173-D55ADD80C260} Adobe InDesign CS5.5 Application Base Files 7.5.0.0 -----------
      FATAL: DS003: Cannot extract 'z:\Setup\InDesign_Setup\Adobe InDesign CS5.5\payloads\AdobeInDesign7xAppBase-mul\Assets1_1.zip' to 'C:\Programme\Gemeinsame Dateien\Adobe\Installers\adobeTemp\{857CC5F0-040E-1016-A173-D55ADD80C260}'. Error: Error 0
      WARNING: DW036: Payload cannot be installed due to dependent operation failure
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-de_DE: Install failed
      ERROR: DW050:  - Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-de_DE: Install failed
      ERROR: DW050:  - Adobe InDesign CS5.5 Application Base Files: Failed due to Language Pack installation failure
