4 Replies Latest reply on Feb 7, 2012 7:15 AM by kglad
      • 1. Re: Output to text file
        you can use the filereference class'es save() method.
        • 2. Re: Output to text file
          Anup-Flash-Help Level 1
          ok so i'm a bit new to flash, any help would be much appreciated as i've never used the save method.
          i've got the boolean variable: flag,
          and i want to output it's value to a text file when i press the taketheticket button:
          this is was i have so far
          function taketheticket(event:MouseEvent):void
                              trace("the change is " + flag);
                              gotoAndStop(8);
          • 3. Re: Output to text file
            Ok I've managed to do it:
            var file:FileReference = new FileReference(); //create a filereference object
            var flag:Boolean = false; // create the variable
                 trace("the change is" + flag); // prints the change value
                 file.save(flag, "result.text"); // saves the value of flag in a text file named result.text
                 gotoAndStop(8); // go to frame 8 and stop
            when the method above is exectuted it allows you to select a particular destination.
            • 4. Re: Output to text file
              do you know how to use the flash help files?  if not, you should learn.
