4 Replies Latest reply on Feb 8, 2012 9:45 AM by John Hawkinson
    InDesign CS3 HELP!
    doug12b
      Recently whenever I try to open InDesign CS3 I get this message "Cannot load Assignment UI.InDesignPlugin because it requires Username. Please install Username plug-in and restart Adobe InDesign." I click ok then the program closes and asks if I want to submit a crash report. I'm not trying to open any particular file, just InDesign itself and it still wont work so I know its not an issue of a newer version file. Thanks to anyone who can help with this, it's a program i need pretty regurlarly. Is there a plugin i'm just can't find? Could someone post a link maybe?
        • 1. Re: InDesign CS3 HELP!
          Steve Werner Adobe Community Professional & MVP
          I think that plug-in might have been installed by InCopy. Did you once install it or a trial copy, and then throw it away?
          Look inside your InDesign folder in the Applications folder. There should be a folder of Plug-ins, and you might find it there. You could remove it if you find it.
          • 2. Re: InDesign CS3 HELP!
            John Hawkinson Level 5
            Assignment UI is used by InCopy, but ships with InDesign. The error here is that the plugin is missing, not that it is causing an error.
            Doug, did you maybe install an InCopy workflow solution that removes the Assignment UI plugin, and then uninstall that workflow solution? In our environment, with Woodwing SmartConnection, Assignment UI gets moved from Plug-Ins into "Plug-Outs." If that's the case for you, just move it back to Plug-Ins.
            But you could also just reinstall InDesign, that would fix it.
            • 3. Re: InDesign CS3 HELP!
              doug12b Level 1
              I've found the UsernameUI and AssignmentUI in the InCopy workflow folder but I cant find any plug-outs folder only plug-ins, any ideas?
              Thanks guys
              • 4. Re: InDesign CS3 HELP!
                Whoops. I'm sorry, I had misread your error. I thought InDesign was looking for the Assignment UI plugin, but that's not the case.
                There is no Username plugin, but there is a Username UI plugin.
                This is strange.
                Do you have any 3rd party extensions installed?
                Does it work with a different user account?
                If not, it's probably time to reinstall InDesign.
