2 Replies Latest reply on Feb 7, 2012 7:46 PM by blessingsADL
    unable to edit html file
    blessingsADL
      I downloaded an html file from our server to edit the logo. However, I am unable to edit the logo part. It's like commented out. And once I opened the file on Dreamweaver CS5, I am getting this pop-up message:
      "This page contains some SWF objects that may not work properly in the most recent versions of Internet Explorer. Dreamweaver cannot convert them to the new SWF markups. Please delete each of them and insert again."
      I can't edit the html file and change the logo. Please help.
      Thank you and God bless!
      Dannie
        • 1. Re: unable to edit html file
          mitzy_kitty
          Dannie,
          Are you familiar with dreamweaver templates and editable regions? If the logo is in the template, then you need to modify the template file. The changes you make to the template will automatically be propogated to all of the files which use the template.  If your html file uses a template, the html code will look like its commented out.
          Also, you should not have to download the html fiile from your server because you should always keep a copy of all the html files on your computer.
          I don't know about the SWF error.
          Good luck.
          mitzy_kitty
          • 2. Re: unable to edit html file
            blessingsADL Level 1
            Hi Mitzy_kitty,
            Thanks for replying. But no, I am not familiar with dreamweaver templates and editable regions. Where can I find the template file?
            Thanks and God bless!
