3 Replies Latest reply on Feb 8, 2012 4:26 AM by Harm Millaard
    Premiere Pro errors
    Adrtghhjj Level 1
      When I try to save a projects, I get one of these 2 errors:
      - Premiere Pro encountered a problem and needs to close
      or
      - Premiere Pro was unable to save the project, please choose Save As.
      What happens?
        • 2. Re: Premiere Pro errors
          Adrtghhjj Level 1
          My computer's specs are:
          Windows XP SP3 32-bit or Windows 7 SP1 64-bit,
          Premiere Pro CS3 or Premiere Pro CS 5.5 (I get the same errors on both OS's, on both versions of Premiere with the same project)
          Intel Core 2 Quad Q8200
          2.00 GB.
          My project specs are:
          1080i project - video only - no effects added
          The footage is 55,000 JPG files at 1920x1080, no compression
          Render settings are: 1080x1920 Microsoft AVI; Compressor: none
          Other details:
          The footage is arranged into ~27 Bins each of 2000 JPG's
          The project file is ~270 MB
          What I did: After each 1-2 Bins dragged onto the Timeline, I would save the project just fine. All worked fine until I dragged the 6th Bin onto the Timeline and tried saving. Then I get one of the above errors.
          • 3. Re: Premiere Pro errors
            Harm Millaard Level 7
            The problem is that your system is woefully underspecced for such kind of editing.  It would already be hard to edit SD DV with that length on such a system, but with this footage your are killing it. Even if you did not have PR throw up an error, chances are that exporting with those settings would take about a whole pregnancy, around 9 months.
            The only solution I see is getting a new system that meets minimum requirements at least. Keep in mind that JPG's are pretty demanding, so your project will fall into the intermediate level at least. See Adobe Forums: System requirements for CS5 and Adobe Forums: What PC to build? An update...
