7 Replies Latest reply on Feb 21, 2012 1:02 AM by DirtySnipe007
    Button to file url works in preview but not when published
    DirtySnipe007 Level 1
      I have a strange issue with flash.
      I have created a dynamic user interface which pulls urls from an xml file.
      Heres the structure
      Main movie
           care_btn movie
      action script for main movie is as follows
      links_xml = new XML();
      links_xml.ignoreWhite = true;
      links_xml.onLoad = function(success) {
          if (success) {
              trace("XML: " + links_xml);
              totalLinks = links_xml.firstChild.childNodes.length;
              trace("TOTAL LINKS: " + totalLinks + newline);
              //loop through XML to check values..
              for (i = 0; i < totalLinks; i++) {
              trace("LINK " + i + " DETAILS:");
              this[urlVar +i] = [links_xml.firstChild.childNodes[i].childNodes[0].firstChild.nodeValue];
              urlvar1 = links_xml.firstChild.childNodes[0].childNodes[0].firstChild.nodeValue;
              trace("URL: " + this[urlVar+i]);
              _root[altVar+i] = links_xml.firstChild.childNodes[i].childNodes[1].firstChild.nodeValue;
              trace("ALT: " + _root[altVar+i]);
              _root[titleVar+i] = links_xml.firstChild.childNodes[i].childNodes[2].firstChild.nodeValue;
              trace("TITLE: " + _root[titleVar+i]);
              trace("-------------------------------------");
              //assign URL values to variables
              urlVar1 = links_xml.firstChild.childNodes[0].childNodes[0].firstChild.nodeValue;
              trace("URL1 = " + urlVar1);
              urlVar2 = links_xml.firstChild.childNodes[1].childNodes[0].firstChild.nodeValue;
              trace("URL2 = " + urlVar2);
              urlVar3 = links_xml.firstChild.childNodes[2].childNodes[0].firstChild.nodeValue;
              trace("URL3 = " + urlVar3);
          }else {
              trace("error loading xml");
      links_xml.load("links.xml");
      action script for the button is as follows
      on(press){
      getURL(_root.urlVar1);
      The output when i preview displays the link ok
      URL1 = K:\Site Shared Student Data\
      and when i click on the button in the preview it opens the directory in windows explorer fine.
      But when i publish the movie and run the index.html file nothing happens when i click on the button.
      I have tried it in both ie8-9 and ff and nothing works.
      here is the index file
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
          <head>
              <title>flash</title>
              <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
              <style type="text/css" media="screen">
              html, body { height:100%; background-color: #ffffff;}
              body { margin:0; padding:0; overflow:hidden; }
              #flashContent { width:100%; height:100%; }
              </style>
          </head>
          <body>
              <div id="flashContent">
                  <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="800" height="600" id="flash" align="middle">
                      <param name="movie" value="flash.swf" />
                      <param name="quality" value="high" />
                      <param name="bgcolor" value="#ffffff" />
                      <param name="play" value="true" />
                      <param name="loop" value="true" />
                      <param name="wmode" value="window" />
                      <param name="scale" value="showall" />
                      <param name="menu" value="true" />
                      <param name="devicefont" value="false" />
                      <param name="salign" value="" />
                      <param name="allowScriptAccess" value="sameDomain" />
                      <!--[if !IE]>-->
                      <object type="application/x-shockwave-flash" data="flash.swf" width="800" height="600">
                      <!--<![endif]-->
                          <a href="http://www.adobe.com/go/getflash">
                              <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" />
                          </a>
                      <!--[if !IE]>-->
                      </object>
                      <!--<![endif]-->
                  </object>
              </div>
          </body>
      </html>
