3 Replies Latest reply on Feb 8, 2012 1:07 PM by kglad
    Parsing out a string I need help
    aidensger Level 1
      Below is the actionscript that I am using... As of now I can hard code the string and it will parse those numbers out.  And work  perfectly.
      var myNum:String = "10-22-33-14-25-36-17-28-09-30";
      Ok so my question I replace the numbers in the string and I put in “root.loaderInfo.parameters.example”  it doesn’t work
      var myNum:String = " root.loaderInfo.parameters.example";
      how do I parse the information that is in "root.loaderInfo.parameters.example so  it will be dynamic instead of hard coded
      (that file has a string of numbers)
      What am I doing wrong?
      for (bo = 1; bo < 91; bo++)
                _root["b" + bo]._visible = false;
      amount = 11;
      contador = 0;
      k = 0;
      i = 0;
      j = 1;
      sig.sig2.next = "";
      output = "";
      var myNum:String = "10-22-33-14-25-36-17-28-9-30";
      var inputBalls:Array = myNum.split("-");
      var ball:Array = new Array;
      trace("Size of inputBalls: " + inputBalls.lenght);
      trace("Contents of inputBalls: " + inputBalls);
      for (i=0; i < 10; i++)
      ball[j] = Number(inputBalls[i]);
      trace("Show me the numbers: " + ball[j]);
      j++;
      var t:Number = setInterval(drawBall, 4000);
      function drawBall():Void
                contador++;
                if (contador >= 11)
                          gotoAndPlay(3);
                          clearInterval(t);
                else
                          k = random(amount);
                          while (ball[k] == "")
                                    k = random(amount);
                          sig.sig2.next = ball[k];
                          _root["b" + ball[k]]._visible = true;
                          sombra._x = _root["b" + ball[k]]._x;
                          sombra._y = _root["b" + ball[k]]._y;
                          sig.gotoAndPlay(2);
                          ball[k] = "";
        • 1. Re: Parsing out a string I need help
          that's as3 code using flashvars.
          with as2, you can access the variables directly from the main timeline, if you're defining them correctly.
          • 2. Re: Parsing out a string I need help
            aidensger Level 1
            Can you assist me with with " as2, you can access the variables directly from the main timeline, if you're defining them correctly."  This is what is on the main timeline?
            how do I define or what am I defining?
            • 3. Re: Parsing out a string I need help
              the top part of your code showed how to parse flashvars using as3 code.  flashvars variables are passed from the swf's embedding html so i can't tell if you're doing that correctly with seeing your html.
              but, even more important, it's not clear you should be using flashvars.  do you have a reason to define your variables in the embedding html?  is there some reason they're not defined on the timeline with the rest of your code?
