4 Replies Latest reply on Apr 21, 2008 1:08 AM by Newsgroup_User
    Text Box
    damienmcogo
      Im trying to do something that i think is very simple to do, im just having one of those silly moments where i cant think straight.
      Assuming i have a 'text box' cast member called "display". I want the text for this box to be the name of the most recent cast member to be clicked.
      Can anyone help me with this?
        • 1. Re: Text Box
          Level 7
          I don't think Director normally tracks which sprite was last clicked,
          but you can achieve what you want fairly easily.
          You just need a behavior that on mouseUp uses the sendSprite function to
          send a custom message to the sprite that has the text box member. That
          sprite then needs a simpler handler to receive the message and set it's
          member's text property.
          Something like this (assuming the text box is in channel 1). If you have
          a later version of Director that supports sprite naming, that could be
          used instead of hard coding the sprite channel.
          Of course you have to attach the sender behavior to each and every
          sprite that you want to send the message. I included the pass command in
          case you have other mouseUp behaviors attached, but then this behavior
          has to be attached first so that the mouseUp event gets passed to other
          behaviors.
          ------------- SENDER CODE ----------------
          property spriteNum
          on mouseUp
          sendSprite(1, #updateName, sprite(spriteNum).member.name)
          pass
          end
          ------------- RECEIVER CODE ----------------
          property spriteNum
          on updateName me, LastClickedMemberName
          sprite(spriteNum).member.text = LastClickedMemberName
          end
          > Thanks
          • 2. Re: Text Box
            Wolfgang Herold Level 2
            Try this
            a =( castLib(1).selection[1][1])
            member("display").text = "member" && a && "of Castlib 1, NAME:" && member(a,1).name
            works only for a defined castlib, so you have to add a box for everx castlib you have
            Wolfgang
            • 3. Re: Text Box
              sorry the
              (a,1).name belongs to the same line member("........
              unexpected linebreack
              Wolfgang
              • 4. Re: Text Box
                Level 7
                > clicked.
                "the clickOn" gives you the number of the last sprite clicked on, so
                something like
                property lastSpriteNum
                on exitFrame
                if (the clickOn)<>lastSpriteNum then
                lastSpriteNum=the clickOn
                member("display").text=sprite(the clickOn).member.name
                end if
                end exitFrame
                But each sprite seems to need to have some sort of handler on it to register
                for the clickOn, even if it's only
                on mouseDown
                nothing
                end mouseDown
                HTH
                Andrew
