1 Reply Latest reply on Feb 8, 2012 10:49 PM by Mylenium
    how to move a light that has an expression
    urglikl
      howdy all.
      i am watching a help video on using trapcode soundkeys and particular.
      anyway, it shows dragging a light to the center of the comp that already has a position expression from soundkeys
      a = thisComp.layer("soundkeys").effect("Sound Keys")("Output 1");
      b = thisComp.layer("soundkeys").effect("Sound Keys")("Output 2")*2;
      c = thisComp.layer("soundkeys").effect("Sound Keys")("Output 3")*3;
      y = a + b + c;
      value = +  [0,y]
      when i apply this expression the light moves to the left edge of the composition and up near the top and i cannot drag/reposition it
      in the usual ways as long as the expression is active.
      my impression is that this expression defines movement and not an origin position
      is there a key i must push when i try to drag a light or other object that has a position expression to reposition?
      using af 5.5
      thank you
        • 1. Re: how to move a light that has an expression
          Well, you are not adding the base values anywhere, hence your expression doesn't know about them:
          a = position[0]+ thisComp.layer("soundkeys").effect("Sound Keys")("Output 1");
          b = position[1]+ thisComp.layer("soundkeys").effect("Sound Keys")("Output 2")*2;
          c = position[2]+ thisComp.layer("soundkeys").effect("Sound Keys")("Output 3")*3;
          Mylenium
