2 Replies Latest reply on Feb 14, 2012 3:38 AM by johnrojo
    Increment dates
    johnrojo
      Working on a form that's sort of a timesheet.  How would I fill in other fields based on an initial date ??  IE: Field-A, a date/time field gets filled in.  I'd then like to automatically fill in another 13 fields for the time period with dates based off Field-A. In advance - many thanks.
        • 1. Re: Increment dates
          $Nith$ Level 4
          Presume that your Date field has the value pattern as DD/MM/YYYY
          You can convert it's rawvalue into number of days using the following script in FormCalc
          var firstDate = Date2Num(DateField1.rawValue,"DD/MM/YYYY")
          now firstDate will have the number of days since epoch.
          Next step you can add 1 to the firstDate and convert it back into Date Object using the following syntax
          secondDateField.rawValue =  Num2Date(firstDate,"DD/MM/YYYY")
          Similarly you can do it for all 13 date fields.
          Nith
          • 2. Re: Increment dates
            johnrojo Level 1
            Sweet.
            Thank you.
            John Rojowski
            DFAS/IND DJMS-AC SIT
            Phone:  317-212-7470
            "Simplify."
