10 Replies Latest reply on Jun 2, 2008 6:43 AM by Enterprise_Jim
    RoboHelp X5 Index Problems
    Enterprise_Jim
      I am using RoboHelp HTML X5.0.2 Build 801 and have created a summary project that includes about 10 individual merged projects. Everything works well and has for some time except I notice that index items are duplicating.
      For example, I may add an index reference in one of the projects that will refer to a single topic. After compiling, I note that this index reference with show three times, not in the individual project but rather in the overall summary project. Only one of these references, however, will be valid...the other two will display a "Page not found" error.
      Any help would be appreciated. Thanks.
        • 1. Re: RoboHelp X5 Index Problems
          Pete Lees Level 2
          Hi, Jim,
          Is this compiled HTML Help (.chm)? If so, you may need to check for any hyperlinks in your projects that point to topics that are above the "root" of the help project — in other words, in neither the help project folder nor any of its subfolders. When the help compiler encounters a hyperlink to a topic that is above the project root, it pulls the target topic into the .chm file but stores it in the wrong internal location, resulting in broken index entries and full-text search results.
          See this page for more information:
          http://helpware.net/FAR/far_faq.htm#Project_Setup
          You may also want to check for and delete any .chw files that are in the folder containing the .chm files. A .chw file is a binary representation of the complete index for a merged help collection. If for some reason the file has been corrupted, the index may not work properly.
          Pete
          • 2. Re: RoboHelp X5 Index Problems
            Enterprise_Jim Level 1
            Thanks, Pete, I will see if I can understand what is going on. Yes, it is a compiled .chm project. I have wondered about the purpose of the .chw file....but, I do delete it and it just keeps coming back after the project is accessed.
            I will take a look at your reference. Thanks again.
            Jim
            • 3. Re: RoboHelp X5 Index Problems
              Pete Lees Level 2
              Hi, again,
              That's right. When no.chw file exists, Windows automatically creates one when you click the Index tab of the master help file. If you've previously deleted the .chw file then it's unlikely that there is anything wrong with it, and you can probably discount this as an explanation for your problem.
              Pete
              • 4. Re: RoboHelp X5 Index Problems
                Pete,
                I read your reference and checked the "hhk" and "hhp" files with Notepad and they look OK to me. If you have time, I am including a part of an "hhk" file from one of the child projects with the hope that might spot something. Mean
                <html>
                <!-- Sitemap 1.0 -->
                <object type="text/site properties">
                <param name="SiteType" value="index">
                </object>
                <ul>
                <li><object type="text/sitemap">
                <param name="Name" value="Data Grid">
                <param name="Local" value="DataGrid.htm">
                </object>
                <param name="Name" value="Spine Thickness">
                <param name="Local" value="SpineThickness.htm">
                </object>
                <param name="Name" value="Quantity Table">
                <param name="Name" value="Component Quantity Table">
                <param name="Local" value="ComponentCommon\CompQtyTable.htm">
                </object>
                <param name="Name" value="Ink Coverage">
                <param name="Name" value="Sheetfed Inks">
                <param name="Local" value="ComponentCommon\Inks.htm">
                </object>
                <param name="Name" value="Press Comparison">
                <param name="Name" value="Press Compare Button">
                <param name="Local" value="ProcessesTab\PressCompareButton.htm">
                • 5. Re: RoboHelp X5 Index Problems
                  Pete,
                  <html>
                  </object>
                  <ul>
                  </object>
                  </object>
                  </object>
                  </object>
                  • 6. Re: RoboHelp X5 Index Problems
                    Pete,
                    <html>
                    </object>
                    <ul>
                    </object>
                    </object>
                    </object>
                    </object>
                    • 7. Re: RoboHelp X5 Index Problems
                      Pete,
                      <html>
                      </object>
                      <ul>
                      </object>
                      </object>
                      </object>
                      </object>
                      • 8. Re: RoboHelp X5 Index Problems
                        Pete Lees Level 2
                        Hi, Jim,
                        That all looks fine. Is it the case that the duplicated index keywords are embedded in the help topics instead of being stored in a separate index (.hhk) file? This is the only situation in which I can envisage the problem occurring.
                        What I would do is open each help file in turn and try to determine which of them contain the rogue keywords. From your description, it sounds like there may be two help files that are at fault. Having identified the problematic help files, you could use a third-party tool like KeyTools or FAR to peek inside each file and look for stray HTML files that shouldn't be there. KeyTools is free; FAR is shareware but free to use for two months.
                        http://www.keyworks.net/keytools.htm
                        http://helpware.net/FAR/index.html
                        In help files that exhibit these problems, one or more topics may contain hyperlinks to other topics that are outside the help project folder. When this is the case, the target topics are dragged into the root folder of the help file at compile time, resulting in broken links. So you'd then need to examine the hyperlinks in the help files and correct them if necessary.
                        If none of this helps, and you feel comfortable about sending your help files to me, I'd be very happy to take a look at them.
                        Pete
                        • 9. Re: RoboHelp X5 Index Problems
                          Hi Pete,
                          Thanks again for your time and help...I will see what I can do.
                          Jim
                          • 10. Re: RoboHelp X5 Index Problems
                            Pete,
                            Thanks again. Found bad hyperlinks and broken links. Created new parent project (with merge files) and all OK now. Can you recommend source where I could learn more about file structures?
                            Also, would you recommend upgrading to RH7?
                            Jim
