2 Replies Latest reply on Feb 10, 2012 1:05 PM by johnAdonaldson1
    Totaling subTotal fields
    johnAdonaldson1
      In my PDF I have areas where I am doing a Grand Total field. It is totalling two filled fields and a field that is a Total of two other fields. Such as
      Grand Total ( 1+2+3)
      1.  Item1                   - Filled In variable
      2.  Item2  (Total)      - Total of Sub Item 1 & 2
             Sub Item1       - Filled in variable
             Sub Item 2       - Filled in variable
      3.  Item3                   - Filled in variable
      Item 2 Total is correct
      Grand Total is not correct.
      // Custom Calculate script for text field
      (function () {
          // Get the field values
          var v1 = getField("Item1").value;
          var v2 = getField("Item2").value;
          var v3 = getField("Item3").value;
          // Set this field value
          event.value = ( 1 * v1) + ( 1 * v2) + ( 1 * v3);
        • 1. Re: Totaling subTotal fields
          Have you checked the calculation order of the fields?
          ''Edit fiields => Set Field Calculation Order"
          Order the fields in the order to calculate from the first at the top and the last at the bottom.
          • 2. Re: Totaling subTotal fields
            johnAdonaldson1 Level 1
            I fixed the problem by doing the following
            (function () {
                var v4 = getField("Item2a").value;
                var v5 = getField("Item2b").value;
                event.value = ( 1 * v1) + ( 1 * v4) + ( 1 * v5) + ( 1 * v3);
