0 Replies Latest reply on Feb 9, 2012 11:47 AM by m_woot
    passing alphanumeric value in querystring in url does not work in flash
    m_woot
      I am having a flash application where I want to send paramters to it via the javascript from a defaul.aspx page.
      I have a paramter called Id where it can accept alphanumerica values.
      the query string in the url works fine if I enter just numbers for the Id, and takes me to the specific page relted to that id , but if I enter a combination of numbers and characters like 001A , it does not work.
      this is the code I used
      function getQueryVariable(variable)
      var query = window.location.search.substring(1);
      var vars = query.split("&");
      for (var i=0; i<vars.length; i++)
      var pair = vars[i].split("=");
      if (pair[0] == variable)
      return (pair[1]);
      </script>
      and then later I assigned the first page of flash application to it.
      flashvars.StartPage = getQueryVariable("Id");
      and then passed the flashvars into swfobject.embedSWF. I also don't want to change anything in my mxml files in flash side
      I appreciate if anyone could help me what the problem is
      thanks
