2 Replies Latest reply on Feb 22, 2012 10:48 AM by kc_chaitu
    insert into DB using SQLservice: cannot take text with single quotes:
    kc_chaitu Level 2
      I'm using JDBC service Execute sql statement.
      I will explain with simple code:
      insert into mytable (id, desc) values (1, 'this is Client document');
      This works perfect.
      But if I have single quotes in the desc -
      insert into mytable (id, desc) values (1, 'this is Client's document');
      It's throwing error to stalled operation errors.
      I know that in Oracle, to escape single quotes we write
      insert into mytable (id, desc) values (1, 'this is Client''s document');
      But, we cant control here in Adobe as the desc is coming from a form's field where the user enters it.
      I'm guessing this could be a known problem & can anyone tell me the solution.
      kc
        • 1. Re: insert into DB using SQLservice: cannot take text with single quotes:
          $Nith$ Level 4
          Use parameterized query to avoid this issue.
          insert into mytable (id, desc) values (?, ?);
          The two parameters (? marks) can be replaced with actual values using XPATH Expression.
          If you do this, you query will execute without throwing any error.
          Nith
          • 2. Re: insert into DB using SQLservice: cannot take text with single quotes:
            kc_chaitu Level 2
            Hi Nith,
            Sorry for the delayed response.
            Thanks a lot for helping me on this. Earlier, I directly referred the process variables in the query which I didnt realize that cause my problem.
            For anyone's reference,
            Bad practice:
            INSERT INTO CREW_FEEDBACK_SENT
                      (JOB_SEGMENT,
                      JOB_COUNTRY  )
              VALUES
                      (GSI_GENERAL_S.NEXTVAL,
                      {$ /process_data/crew_feedback_input_form/object/data/xdp/datasets/data/form1/Details/jobseg ment $},
                      {$ /process_data/crew_feedback_input_form/object/data/xdp/datasets/data/form1/Details/jobreg ion $})
            Good practice:
              (JOB_SEGMENT,
              JOB_COUNTRY  )
              VALUES
            use them in Parametrized query & that helps.
            Regards,
            Krishna
