I'm on RH8. If one adds a pdf file into a project as a baggage file, can a user search info within the pdf or would the search only point to the pdf document?
I am also interested in searching of PDF files. I recently purchased a few licenses of RoboHelp 2015 version, and am being asked to create PDFs for multiple topics. Each topic would probably have details or words that I would want searchable. I believe I could do that through PDF Properties and metadata, but wonder if there are other ways that I can perform deeper searches into the PDF.
Can anyone assist with this?
sharon27lily
Hi Sharon
Wow, you found a post from 2012 that was never answered!
I'm unsure exactly what you are asking here. The original post seems to ask if one adds a PDF document to RoboHelp if the RoboHelp search will find content inside the PDF. And the last few versions of RoboHelp DO allow for that.
But your question seems the opposite. I'm guessing you are using RoboHelp to create PDF documents and you want to know if you do that, will the PDF Reader find the text inside the produced PDF. Am I understanding that correctly?
I'm guessing it would work just fine. After all, the text exists as text inside RoboHelp.
Cheers... Rick
RoboHelp indexes PDF files so you can find them. Is that not what you are looking for?
Thank you both for responding.
I've just purchased RoboHelp 2015. It's beautiful.
I am being asked to create an Online Help system using PDFs and videos as links to content. This will initially be for use on desktop and tablets, and eventually will involve androids (BYOD: Bring Your Own Device), so I will be using the newer functionality of RoboHelp. Exciting!
I don't see a problem with creating the system, but I am concerned about the ability of the user to search content in the PDFs.
I have converted some Word docs into PDFs and tested them inside RoboHelp 2015, and have not yet seen the search function actually capture a word or phrase from the PDFs. Only the words in the title of the PDF appear searchable. Perhaps there is something specific I need to do in creating the PDF? .
Can you tell me what I should be doing to ensure the search functionality is as robust as possible? I am considering using Word documents instead, but I have concerns about security.
It will be very important to have the PDFs searchable, as it will be the source for most of the information about the portal we are creating.
I have also heard about indexing PDFs, to make searching faster--I wonder if that is something I should consider.
Any guidance you can provide would be greatly appreciated.
sharon27lily
Can someone address this issue for me? Is there something I am doing wrong that causes the PDF not to be searchable? Please advise.
Sharon
Hi there
When PDFs are created there are a lot of options that govern their creation. For example, I've encountered PDF documents that would appear to contain text, but that text was actually part of an image. Thus it wasn't searchable.
Have you verified this aspect first?
Cheers... Rick
Is the PDF tagged? I believe you need a tagged (accessible) PDF to make it searchable. I have tried a project with several PDF files and it seems to work fine.
Rick, a PDF is a strange thing--it's almost like it is both text and graphic. All the text will be converted from a Word document. William, I'm not sure what you mean by tagged--can you point me to an article that explains what you mean? I have every intention of bookmarking sections of the PDFs (and there will be many) to put into the HTML5 responsive layout, but if I am to use the approach that has been requested of me, the PDFs must either be fully searchable, or I have to create an index for each PDF, which I have never done.
Does this make sense?
sharon27lily
William, perhaps I just don't understand the terminology, but what do you mean by tagged?
sharon27lily
My understanding was that tagging was a kind of internal (admin) index within a PDF. I googled and found this page which says they are used for accessibility (screen readers etc), but I can imagine this information would also help with searching.
WebAIM: PDF Accessibility - Defining Acrobat PDF Accessibility
And instructions for creating tagged PDFs with a few different applications.
Thank you! I will test this out, but it seems like the answer to my problem. . .
It seems to be working, to tag PDFs based on the two articles you mentioned. Thank you!
Sharon
