I am not able to get Flash player to work since updating firefox.
OS:
openSUSE 11.4 (x86_64)
VERSION = 11.4
CODENAME = Celadon
Installed firefox 9.0.1
Installed flashplayer from install_flash_player_11_linux.x86_64.tar
When I run firefox, flash player is not detected.
Firefox says "For your safety, Firefox has disabled your outdated version of Flash."
./mozilla/firefox/plugins/pluginreg.dat shows:
[INVALID]
/usr/lib64/flash-plugin/libflashplayer.so:$
1328726850000:$
I realize this could be a problem with firefox, but can you confirm that the
OS/firefox/flash configuration described should work?
Any suggestions as to why flash is not being detected?
George
Afaik, this should work. Forwarded to our Linux/Mozilla expert for their review.
Chris
Thanks for your response.
Any word from the Linux/Mozilla expert?
George
Hi George,
He just got back into the office yesterday from a two week break. He let me know that he'd try this out shortly.
Chris
Hi
Has anyone had a chance to look into this one
yet?
thanks very much
can anyone point me to a repository than still has Open Suse 11.4 iso for download?
How about this one: http://software.opensuse.org/114/en
bah... thanks george492. i neglected to add /en to the path. downloading now.
i'm not able to reproduce that specific issue (see screenshot).
here's the steps i used: base suse 11.4 install included no flash and firefox 4beta 64-bit
I will try out this strategy.
Can you tell me the md5sum of the libflashplayer.so that you used?
thanks.
I am using:
d4d48f1ad3995a698025dcd33e471aff libflashplayer.so
Also, I reverted to firefox 4.0.1 and I have the same problem:
[INVALID]
~/.mozilla/plugins/libflashplayer.so:$
1330006985000:$
N.B. When I last had flash working with firefox 4.0.1 I think I was using the 32-bit version
and nspluginwrapper. Perhaps there are some residuals that are causing the problem.
i don't have access today to the machine i tested, but the checksum should be
0485791c89b04e73fe75f11c5d20dbc1 libflashplayer.so (64-bit)
flash player 11 is available in 64-bit which means you don't have to run nspluginwrapper (suggest to uninstall it). since you no longer need the wrapper it will be more stable running in the native 64-bit firefox browser.
ping me if you have any other questions. thanks...
I found the player with the checksum you indicate (must be a very recent update).
I had already uninstalled nspluginwrapper.
But no luck.
pluginreg.dat still shows:
[INVALID]
1329189939000:$
Any suggestions of things to look at/for?
Any idea why firefox determines the player to be Invalid?
if the checksums are the same for libflashplayer.so make sure your version of firefox is 64-bit. when i went to the firefox site, the default download is the 32-bit version. let me know...
This is what it is showing:
Mozilla/5.0 (X11; Linux i686 on x86_64; rv:9.0.1) Gecko/20100101 Firefox/9.0.1
where is that information coming from?
i usually verify in terminal... navigate to the firefox directory and type the following command:
input: file firefox
output: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.9, stripped
make sure there are no other instances of firefox running. you can launch firefox by typing the following command:
input: ./firefox
the importance of this is that you are not potentially launching another version of firefox which doesn't understand the 64-bit plugin in ~/.mozilla/plugins
i downloaded the 32-bit firefox and this is what i see which sounds what you are encountering. maybe? you can see in terminal when the plugin is attempting to load... it is the incorrect type because it's a 64-bit plugin.
I am beginning to see light ...
So, I got that information from the 'TroubleShooting Information' under 'Help' after launching firefox.
However, using your method - alas, it claims to be 32-bit!
I couldnt find the 9.0.1 64-bit to download, but I found a test version 13 which i downloaded just
to try out. Using file firefox it indicates it is 64-bit. ./firefox -version reports 13, but when
I run it ./firefox and look in About, it stills says 9.0.1.
So, I think the solution is to uninstall all versions of firefox, find the 9.0.1 64-bit and
try that. Do you have a link to the 9.0.1 64-bit?
i gave the link to the 64-bit firefox 9.0.1 earlier: ftp://ftp.mozilla.org/pub/firefox/releases/9.0.1/linux-x86_64/en-US/
it comes from the release branch, so it will probably update to 10.0.2 after the next launch. looking forward to hear this works for you...
Didnt work on first try, but worked after a system reboot.
Thanks very much for your help.
Not sure why the x86_64 tar file I first downloaded installed the 32 bit version though.
i am glad you are up and running!
