5 Replies Latest reply on Feb 12, 2012 5:15 AM by BKBK
    Onclick with checkboxes and add value to a string
    pmlink360 Level 1
      Hello, I have a search results page that has a checkbox next to each returned record. Is there a way to append its value to a string via an Onclick function? My search results page uses paging as well, that is why I was wondering if it can be done as they click the checkbox.
        • 1. Re: Onclick with checkboxes and add value to a string
          BKBK Adobe Community Professional & MVP
          Which variables hold the value of the search results? If one knows this, then answering the question will be easy.
          • 2. Re: Onclick with checkboxes and add value to a string
            pmlink360 Level 1
            The name of my form is "get_records" and the name of my checkbox is "f_selected_record".
            I was using this code but I was only getting the current id of the checkboxes on the current page I was on.....so if I did a search and clicked on a checkbox on page 1 and went to page 2 clicked 2 checboxes, I would only have the 2 ids from page 2.
            <cfif isdefined("form.get_records")>
                <cfloop index="i" list="#Form.f_selected_record#" delimiters=";">
                    <cfoutput><cfset session.get_all_records = ListAppend(session.get_all_records,'#i#')></cfoutput>
                </cfloop>
            </cfif>
            • 3. Re: Onclick with checkboxes and add value to a string
                  </cfloop>
              </cfif>
              If the name of your form is "get_records", then this statement is absurd: <cfif isdefined("form.get_records")>. The statement suggests that "get_records" is the name of a field in the form. Is it?
              You said you have a search results page that has a checkbox next to each returned record. My question is, which variables hold the values of the returned records? Do you have 2 forms, one posting to the results page and one on the results page(in which are the checkboxes)?
              • 4. Re: Onclick with checkboxes and add value to a string
                pmlink360 Level 1
                I typo'ed that....I meant f_selected_record which is the name of the checkbox.This way is not working so I'm trying to understand if anyone has an example of adding the value of a checkbox to a string via an onClick method. I do not have 2 forms, the information is just output to the results page.
                • 5. Re: Onclick with checkboxes and add value to a string
                  Put the following files in the same directory, and do the test. I hope it tells you things you wish to know.
                  form_page.cfm
                  <cfform action="results_page.cfm">
                  <!---Using same name for the fields means the form will submit a comma-delimited list (under one field name) --->
                  Checkbox 1: <cfinput name="f_selected_record" type="checkbox" value="value_of_checkbox_1"><br>
                  Checkbox 2: <cfinput name="f_selected_record" type="checkbox" value="value_of_checkbox_2"><br>
                  Checkbox 3: <cfinput name="f_selected_record" type="checkbox" value="value_of_checkbox_3"><br>
                  <cfinput name="sbmt" type="submit" value="Post to results page">
                  </cfform>
                  results_page.cfm
                  <!--- Variable session.get_all_records is initialized whenever a form is submitted --->
                  <cfset session.get_all_records = "">
                  <!--- Variable session.get_all_records collects and stores the submitted records cumulatively, including repeated submissions --->
                  <!---<cfparam name="session.get_all_records" type="string" default="">--->
                  <cfif isdefined("form.f_selected_record")>
                      <!--- Remember it is by default a comma-delimited list--->
                      <cfloop index="i" list="#Form.f_selected_record#">
                      </cfloop>
                  </cfif>
                  session.get_all_records: <cfoutput>#session.get_all_records#</cfoutput>
