1 Reply Latest reply on Feb 11, 2012 7:50 AM by kglad
    soft airbrush spray
    ryanjohnsond Level 1
      Any way to get a soft airbrush spray out of a vector paint brush in AI or Flash?  you know, like a regular photoshop airbrush that creates a long stroke with soft edges.  Can you do that in Flash or even AI, if you know the answer to that too.
        • 1. Re: soft airbrush spray
          create a graphic that contains a circle with radial fill.  the fill can be whatever color you want and have it fade to alpha=0 at its boundard.
          now click the spray brush tool and in the properties panel, change the symbol used by the tool to your graphic. spray.  now refine your graphic until you see the results you want.  there are also some spray brush options in the properties panel that may help you achieve the look you want.  but you have more flexibility editing the shape(s) in your graphic.
          you can even animate that graphic if you want to get exotic.
          2 people found this helpful
