0 Replies Latest reply on Apr 20, 2008 3:52 PM by Julio Carneiro
    Custom Component Event not showing for code hinting
    Julio Carneiro
      I have a bunch of custom components in my application and I use events to communicate between them extensively.
      After I moved my code to Flex 3 none of my component events show up for code hinting. It all compiles and runs as expected, but none of the custom events show up in Flex Builder 3. Not in the component's properties palette or for code hinting in the source editor.
      Everything was nice and dandy with Flex 2.0.1.
      Has anything changed on the way one declares custom events? I looked at the documentation for Flex 3 and at the code in 3.0 SDK and I cannot see anything that I might be doing wrong. Specially because the app compiles and works as expected.
      Some components are mxml and the events are declared like:
      <mx:Metadata>
      [Event(name='gotoProjects', type='mx.events.DynamicEvent')]
      [Event(name='gotoGrants', type='mx.events.DynamicEvent')]
      </mx:Metadata>
      The only place I can see a difference in behaviour with FB3 is that I'm now using modules.
      The example above is inside a custom Canvas component whose entire code is:
      <mx:Metadata>
      </mx:Metadata>
      <AdminModules:AdminCompetitionModule x="0" y="0" id="thePage" />
      The events are in fact bubbled from the embedded module.
      It seems FB3 is not taking the Event metatag into account for some reason. is there any project setting to make that work? Or is that an already reported bug?
      As I said the code/project was converted from FB2. Maybe some project setting did not convert properly.
      thanks for any help
      julio carneiro
