2 Replies Latest reply on Feb 26, 2012 5:31 AM by sergnew10082000
    connections is not always established
    sergnew10082000
      I m trying on my site flash player comunication. Connection synhronization is on my site.
      Connection between some IP s is established well and continue to the end of call. But between another IP s is not established at all.
      What it may be ?
      My site   TURDOS.RU (travel by byke or on foot) russian Moscow
      May be for some GURU in ActionScript all the code
            xmlns:mx="library://ns.adobe.com/flex/mx"
            width="624" height="532" minWidth="500" minHeight="500"
            viewSourceURL="srcview/index.html"
            creationComplete="p2p_1()">
      <fx:Declarations>
        <!-- Разместить невизуальные элементы (например, службы или объекты значений) -->
      </fx:Declarations>
      <fx:Script>
        <![CDATA[
         import mx.events.ListEvent;
         import mx.collections.ArrayCollection;
         private const CirrusAddress:String = "rtmfp://p2p.rtmfp.net";
         private const DeveloperKey:String = "a56230a18105f402da76990e-69964df27226";
         private var nc:NetConnection;
         private var myPeerID:String ;
         private var farPeerID:String = "";
         private var sendStream:NetStream;
         private var recvStream:NetStream;
         private var cam:Camera;
         private var mic:Microphone;
         private var loader:URLLoader;
         private var loader1:URLLoader;
         private var loader2:URLLoader;
         private var loader3:URLLoader;
         private var my_id:String;
         private var num:String;
         private var user1:String;
         private var adobeChatID:String;
         private var iam:String;
         private var adobeChatIDslave:String;
         private var tMaster:Timer;
         private var tSlave:Timer;
         private var tMaster1:Timer;
         private var tMasterLast:Timer;
         private var tRec:Timer;
         private var str10:String;
         private var request:URLRequest;
         private var request1:URLRequest;
         private var request2:URLRequest;
         private var request3:URLRequest;
         //private var path:String="http://localhost:1961/tur/";
         private var path:String="";
         private var timer_ind:int = 0;
         private var timer_ind1:int = 0;
         private var ok:int = 0;
         private var once:int = 0;
         private var once1:int = 0;
         private var camS:Camera;
         private var micS:Microphone;
         private var timerSeconds:int;
         private var timerSeconds1:int;
         private var file:FileReference;
         private var fileSendStream:NetStream;
         // A Dataprovider for the listitem (to display downloads)
                  private var dp:ArrayCollection = new ArrayCollection;
         private var fileRecievedStream:NetStream;
         public  function p2p_1():void{
          cam = Camera.getCamera();
          if(cam) {
           cam.setMode(280,240,15,true);
           var vid:Video = new Video(cam.width, cam.height);
           vid.x = 0;
           vid.y = 0;
           vid.attachCamera(cam);
           video1.width = cam.width;
           video1.height = cam.height;
           video1.addChild(vid);
          else{
           //wcam.visible = true;
          mic = Microphone.getMicrophone();
          if(mic){
           //mic.setLoopBack(true);
           //mic.setUseEchoSuppression(true);
          else{
           //wmic.visible = true;
          if(cam!=null || mic!=null){
           Security.showSettings();
          error1.visible = false;
          nc = new NetConnection();
          nc.addEventListener(NetStatusEvent.NET_STATUS, ncHandler);
          nc.connect(CirrusAddress, DeveloperKey);
          //begin.enabled = false;
          info1.visible = true;
          fileList.visible = false;
                   fileList.addEventListener(ListEvent.ITEM_CLICK, itemDownloadHandler);
          fl1.visible = false;
          fl2.visible = false;
          frec.visible = false;
          frec1.visible = false;
          close1.visible = false;
          load1.visible = false;
          fileSizeError.visible = false;
         private function ncHandler(event:NetStatusEvent):void {
          var myQueryStrings:Object=this.loaderInfo.parameters;
          my_id=myQueryStrings.id;
          num=myQueryStrings.num;
          user1=myQueryStrings.user1;
          iam=myQueryStrings.iam;
          info1.visible = false;
          if(event.info.code=='NetConnection.Connect.Closed')
           close1.visible = true;
          if(event.info.code!="NetConnection.Connect.Failed")
           if(iam=="slave"){
            if(once1 == 0){
             once1 = 1;//so that if some crazy thing think to call this stuff twice
             tSlave = new Timer(5000,0);
             myPeerID = nc.nearID;
             farPeerID = myQueryStrings.VideoChatID;
             labelBeginSlave.visible = true;
             str10 = path + "VideoChatConnection.aspx?id="+my_id+"&num="+num+"&user1="+ user1  + "&iam=slave" + "&Init=no";
             request = new URLRequest(str10);
             loader = new URLLoader();
             try {loader.load(request); }
             catch (error:SecurityError) {trace("A SecurityError has occurred.");}
             loader.addEventListener(IOErrorEvent.IO_ERROR, errorHandler);
             loader.addEventListener(Event.COMPLETE, function (event:Event):void
              try {
               trace(loader.data);
               tSlave.addEventListener(TimerEvent.TIMER,function (event:Event):void
                tSlave.stop();
                str10 = path + "VideoChatConnection.aspx?id="+my_id+"&num="+num+"&user1="+ user1  + "&iam=slave" + "&Init=get";
                try {
                 try {
                  trace(loader.data);
                  if(loader.data=="init"){
                   timer_ind = 1; //that s the end of all timers
                   //master indicated initialization
                   tSlave.stop();
                   labelBeginSlave.text = "  Ответ получен.";
                   labelEndSlave.visible = true;
                   initRecvStream();
                   initSendStream();
                   str10 = path + "VideoChatConnection.aspx?id="+my_id+"&num="+num+"&user1="+ user1  + "&iam=slave" + "&Init=putEnd";
                   request1 = new URLRequest(str10);
                   loader1 = new URLLoader();
                   try {
                    loader1.load(request1);
                   loader1.addEventListener(IOErrorEvent.IO_ERROR, errorHandler);
                   loader1.addEventListener(Event.COMPLETE, function (event:Event):void
                    send.enabled = true;
                    labelBeginSlave.visible = false;
                    labelEndSlave.visible = false;
                 catch (e:TypeError) {
                  trace("Could not parse the XML file.");
                if(timer_ind!=1)
                 tSlave.start();
               if(timer_ind!=1)
                tSlave.start();
              } catch (e:TypeError) {
            //master______________________________________________________________________
            //_____________________________________________________________________________
           else{
            if(once==0){
             //that will be called twice because of when stream come from slave and so var ONCE indicate that
             once = 1;
             tMaster = new Timer(5000,0);
             tMaster1 = new Timer(5000,0);
             tMasterLast = new Timer(200,0);
             timerSeconds = 0;
             timerSeconds1 = 0;
             adobeChatID = nc.nearID;
             //call slave
             labelBeginMaster.visible = true;
             str10 = path + "VideoChatConnection.aspx?id="+my_id+"&num="+num+"&user1="+ user1 + "&adobeChatID=" + adobeChatID +
              "&masterInit=begin";
             try {loader.load(request);}
             labelSec.visible = true;
             labelSec.text = "время(сек):  " + timerSeconds.toString();
             loader.addEventListener(Event.COMPLETE, function(event:Event):void
                  try {
               tMaster.addEventListener(TimerEvent.TIMER,function (event:Event):void
                timerSeconds += 5;
                tMaster.stop();
                "&masterInit=get";
                try {
                 try {
                  if(loader.data=="Ok"){
                   //slave indicated that it is ready so master has to init
                   tMaster.stop();
                   labelBeginMaster.text = "   Ответ получен.";
                   labelInitSendMaster.visible = true;
                   initSendStream();
                   labelInitSendMaster.text = " Поток передачи иницилизирован.";
                   "&masterInit=init";
                   try {
                    trace(loader.data);
                    labelInitRecvMaster.visible = true;
                    //that s the end of game
                    tMaster1.addEventListener(TimerEvent.TIMER,function (event:Event):void
                     tMaster1.stop();
                     timerSeconds += 5;
                     "&masterInit=getEnd";
                     request2 = new URLRequest(str10);
                     loader2 = new URLLoader();
                     try {loader2.load(request2);}
                     loader2.addEventListener(IOErrorEvent.IO_ERROR, errorHandler);
                     loader2.addEventListener(Event.COMPLETE, function (event:Event):void
                      if(loader2.data=="End"){
                       timer_ind1 = 1;
                       //may be error
                       //make here delay
                       tMasterLast.addEventListener(TimerEvent.TIMER,function (event:Event):void
                        timerSeconds1 += 200;
                        labelRecfarpeerID.text = timerSeconds1.toString() + " farPeerID равно " + farPeerID;
                          if(farPeerID!="")
                          tMasterLast.stop();
                          initRecvStream();
                          labelInitRecvMaster.text = " Поток приёма инициализирован.";
                          labelBeginMaster.visible = false;
                          labelInitSendMaster.visible = false;
                          labelInitRecvMaster.visible = false;
                          labelRecfarpeerID.visible = false;
                          labelSec.visible = false;
                          tMaster1.stop();
                                 "&masterInit=delFile";
                             request3 = new URLRequest(str10);
                          loader3 = new URLLoader();
                          try {loader3.load(request3);}
                          loader3.addEventListener(IOErrorEvent.IO_ERROR, errorHandler);
                          loader3.addEventListener(Event.COMPLETE, function (event:Event):void
                       labelRecfarpeerID.visible = true;
                       labelRecfarpeerID.text = "farPeerID равно " + farPeerID;
                       tMaster.stop();
                       tMaster1.stop();
                       tMasterLast.start();
                     if(timer_ind1==0)
                      tMaster1.start();
                    if(timer_ind1==0)
                     tMaster1.start();
                if(timer_ind!=1)
                 tMaster.start();
               if(timer_ind!=1)
                tMaster.start();
          else{error1.visible = true;
           //begin.enabled = true;
         private function initSendStream(): void{
          sendStream = new NetStream(nc, NetStream.DIRECT_CONNECTIONS);
          sendStream.bufferTime = 0;//minimum delay
          sendStream.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
          sendStream.publish("media");
          //send video and audio if any
          camS = Camera.getCamera();
          if(camS) {
           camS.setMode(280,240,15,true);
           sendStream.attachCamera(camS);
          micS = Microphone.getMicrophone();
          if(micS){
           micS.setUseEchoSuppression(true);
           sendStream.attachAudio(micS);
          /*sendStream.attachAudio(Microphone.getMicrophone());
          cam.setMode(560,480,24,true);
          sendStream.attachCamera(cam);*/
          var sendStreamClient:Object = new Object();
          sendStreamClient.onPeerConnect = function(callerns:NetStream):Boolean {
           farPeerID = callerns.farID;
           trace("OnPeerConnect" + farPeerID);
           return true;
          sendStream.client = sendStreamClient;
          //init send stream for file exchange
          //so be that in any case that user will want to send file
          fileSendStream = new NetStream(nc, NetStream.DIRECT_CONNECTIONS);
          fileSendStream.addEventListener(NetStatusEvent.NET_STATUS, netStreamHandler);
          // Giving the stream a idName
          fileSendStream.bufferTime = 0;//minimum delay
          fileSendStream.publish("file");
         private function initRecvStream(): void{
          tRec = new Timer(5000,0);//5 sec delay before to begin receive
          tRec.start();
          tRec.addEventListener(TimerEvent.TIMER,function (event:Event):void
           tRec.stop();
              recvStream = new NetStream(nc, farPeerID);
              recvStream.bufferTime = 0;//minimum delay
              recvStream.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
              recvStream.play("media");
              recvStream.client = this;
             //receive video and audio if any
             var vid:Video = new Video(280, 240);
             vid.x = 0;
             vid.y = 0;
             vid.attachNetStream(recvStream);
             video0.addChild(vid);
            //init receive stream for file exchange
            //so be that in any case that user will want to receive file
            // This functions handles the incomming data
                        fileRecievedStream = new  NetStream(nc,farPeerID);
                        fileRecievedStream.client = this;
                        fileRecievedStream.addEventListener(NetStatusEvent.NET_STATUS, incomingStreamHandler);
                     // Using the "file" stream identification
               fileRecievedStream.bufferTime = 0;//minimum delay
            fileRecievedStream.play("file");
         public function incomingStreamHandler(e:NetStatusEvent):void
                       // If there was a connection between you and the  target
                     if(e.info.code == "NetStream.Play.Start")
                        // set the textBackgroundcolor to green
                        // connectLabel.text = "Your Are connected";
                         // show the fileBrowse/Send view
                          //fileField.visible = true;
         private function sendSomeData(): void{
          var date:Date = new Date();
          var x:String = "\r\n_____ " + date.getHours().toString() + ":" + date.getMinutes().toString() + " _____";
          txtRecvdData.text += x + "\r\n" + txtSendData.text + "\r\n" + "______________________________";
          sendStream.send("receiveSomeData", txtSendData.text);
          txtSendData.text = "";
          txtRecvdData.scrollToRange(int.MAX_VALUE);
         public function receiveSomeData(str:String): void{
          if(str=="***!!!***send")
           frec1.visible = true;//your peer sending you a file
          else if (str=="***!!!***re"){
           frec.visible = false;//file is received
          else
          txtRecvdData.text += x + "\r\n" + str + "\r\n" + "______________________________";
          //beep when message is received
          var myRequest10:URLRequest;
          var mySound10:Sound;
          myRequest10 = new URLRequest("click.mp3");
          mySound10 = new Sound();
          mySound10.load(myRequest10);
          mySound10.play();
         private function netStatusHandler(event:NetStatusEvent):void {
          trace(event.info.code);
         private function errorHandler(e:IOErrorEvent):void {
          trace("Had problem loading the  File.");
         private function browseHandler():void
                        // Creating a new FileReference to start choosing
                           file = new FileReference;
                           // Adding eventListeners
                           file.addEventListener(Event.SELECT, selectHandler);
                           file.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                                file.addEventListener(ProgressEvent.PROGRESS, progressHandler);
                                file.addEventListener(Event.COMPLETE, completeHandler);
                          // Open the browse-file dialogue
                                 file.browse();
         private function selectHandler(event:Event):void
                               // If you selected a file to send
                                      file =  FileReference(event.target);
                               // load the file
                                      file.load();
                              // Set the source textfield to the filename
              load1.visible = true;
         private function completeHandler(event:Event):void
                   //file lenght must be less than 14 000 000 byte
                   if(file.data.length < 14000000)
                   // The file was loaded succesfully
                               //trace("completeHandler: " + event);
                               // The send button will be enabled
             fileName.text = file.name;
                               btnSend.enabled= true;
             else{
              fileSizeError.visible = true;
         private function ioErrorHandler(event:IOErrorEvent):void
                                //trace("ioErrorHandler: " + event);
         private function progressHandler(event:ProgressEvent):void
                      // Process  loading the file
                       var file:FileReference =  FileReference(event.target);
                       //trace("progressHandler: name=" + file.name + "129 bytesLoaded=" + event.bytesLoaded + " bytesTotal=" + event.bytesTotal);
                       //connectLabel.text = "progressHandler: name=" + file.name + " bytesLoaded=" + event.bytesLoaded + " bytesTotal=" + event.bytesTotal;
                       load1.text = "Загрузка :  " + event.bytesTotal + " байт";
         public function onFileSend(e:Event):void
                       // Creating an object
                      var fileData:Object = new Object();
                      // Giving the object a property that container the  file data as a ByteArray
                     fileData.file = file.data
                       // Property of the name of the file
                     fileData.name = file.name;
                       // Sending the file to the target and it will be   received
                       // by the 'onFileReceived' function
             fileSendStream.send("onFileReceived",fileData);
            //fileSendStream.send("onFileReceived",file.data);
           btnSend.enabled= false;
           sendStream.send("receiveSomeData", "***!!!***send");//indicate sending file
           frec.visible = true;
         public function netStreamHandler(e:NetStatusEvent):void
                      trace(e.info.code);
         public function onFileReceived(info:Object):void
         //public function onFileReceived(ar:ByteArray):void
          frec1.visible = false;//your peer completes sending you a file
                       // We add the object to a dataprovider
                      // For displayin the files in a list
                      // Giving the name and file data as properties
           dp.addItem({label:info.name, file:info.file});
                     // If an item of the list was clicked
                      // Setting the dataprovider of the listcomponent
           fileList.dataProvider = dp;
           fileList.visible = true;
           fl1.visible = true;
           fl2.visible = true;
                   private function itemDownloadHandler(event:ListEvent):void
                      // creating new FileReference
                      file= new FileReference();
                      // saving the clicked item to your computer
                      // brings out a savedialogue
                      file.save(event.itemRenderer.data.file, event.itemRenderer.data.label);
          dp.removeAll();
          file.addEventListener(Event.COMPLETE, completeHandler1);
          file.addEventListener(Event.CANCEL, cancelHandler1);
         private function completeHandler1(event:Event):void
          sendStream.send("receiveSomeData", "***!!!***re");
         private function cancelHandler1(event:Event):void
      </fx:Script>
      <mx:Application width="628" height="1500" horizontalAlign="left" layout="absolute"  >
        <s:Panel x="3" y="3" width="280" height="500" backgroundColor="#040000" chromeColor="#070000">
        </s:Panel>
        <s:VideoDisplay id="video1" x="3" y="253" width="280" height="240" chromeColor="#FFFFFF"/>
        <s:VideoDisplay id="video0" x="3" y="8" width="280" height="240" chromeColor="#FFFFFF"/>
        <s:TextArea x="293" y="424" width="323" height="48" id="txtSendData"/>
        <s:Button id="send" x="465" y="480" label="Отправить сообщение" click="sendSomeData()" enabled="false"/>
        <s:Label x="294" y="405" width="328" height="12" text="Если микрофон не работает,напишите текст.сообщение"/>
        <s:Label id="labelBeginMaster" visible="false" x="38" y="89" width="161" color="#F61010"
           fontSize="16" text="               Звоним ......."/>
        <s:Label id="labelInitSendMaster" visible="false" x="29" y="110" width="263" color="#F50E0E"
           fontSize="16" text="Иницилизация потока передачи...."/>
        <s:Label id="labelInitRecvMaster" visible="false" x="30" y="132" width="242" color="#F50E0E"
           fontSize="16" text="Иницилизация потока приёма...."/>
        <s:Label id="labelBeginSlave" visible="false" x="36" y="95" width="201" color="#F61010"
           fontSize="16" text="         Ожидание ответа ......."/>
        <s:Label id="labelEndSlave" visible="false" x="23" y="115" width="261" color="#F50E0E"
        <s:Label id="labelRecfarpeerID" visible="false" x="23" y="145" width="261" color="#F50E0E"
           fontSize="16" text="  Получение farePeerID...."/>
        <s:TextArea id="txtRecvdData" x="294" y="11" width="323" height="342" color="#8B8080"
           editable="false" verticalAlign="middle"/>
        <s:Label id="frec" x="335" y="163" width="253" height="44" color="#F00E0E" fontSize="24"
           fontStyle="italic" fontWeight="normal" text="Передача файла....."/>
        <s:Label id="frec1" x="335" y="188" width="306" height="44" color="#F00E0E" fontSize="24"
           fontStyle="italic" fontWeight="normal" text="Вам передают файл....."/>
        <s:Label id="close1" x="110" y="180" width="443" height="44" color="#F00E0E" fontSize="29"
           fontStyle="italic" fontWeight="bold" text="СОЕДИНЕНИЕ РАЗОРВАНО !"/>
        <s:Label  id="error1" visible="false" x="53" y="160" width="522" height="28" color="#F80B0B" fontSize="20" text="Нет связи с интернетом или Adobe сервер не отвечает"/>
        <s:Label  id="info1" visible="false" x="80" y="116" width="126" height="28" color="#F80B0B" fontSize="20" text="Ожидание...."/>
        <s:Label visible="false" id="qqq" x="75" y="176" width="140" height="24" text="Метка"/>
        <s:Label id="wcam" visible="false" x="69" y="335" width="180" height="29" color="#F50C0C" fontSize="21" text="веб камеры нет"/>
        <s:Label id="wmic" visible="false" x="71" y="369" width="180" height="29" color="#F50C0C" fontSize="21" text="микрофона нет"/>
        <s:Label id="labelSec" visible="false" x="94" y="65" width="100" height="21" color="#EB0D0D" fontSize="12"/>
        <s:TextInput id="fileName" x="294" y="375"/>
        <s:Button x="430" y="376" width="95" label="Обзор" click="browseHandler()"/>
        <s:Button id="btnSend" x="533" y="376" width="83" label="Загрузить" enabled="false" click="onFileSend(event)"/>
        <s:Label x="296" y="359" width="170" text="Загрузка файла"/>
           <mx:List id="fileList" x="305" y="129" width="298" height="24"/>
        <s:Label id="fl1" visible="true" x="305" y="117" width="299" backgroundColor="#F1EAEA"
           text="Кликните по названию файла,чтобы его сохранить"/>
        <s:Label id="fl2" visible="true" x="308" y="103" width="296" backgroundColor="#F6EFEF"
           fontWeight="bold" text="Получен файл"/>
        <s:Label id="load1" y="218" right="30" width="289" height="30" color="#F80F0F" fontSize="14"
           horizontalCenter="139" text="Загрузка :  0 байт" textAlign="center"
        <s:Label id="fileSizeError" x="309" y="261" width="309" height="34" color="#F51F0E"
           text="Размер файла не может быть более чем 14 Мбайт!!!"/>
      </mx:Application>
      </s:Application>
