6 Replies Latest reply on Mar 7, 2012 7:16 PM by sasientry
    I need to Save file add 3 digit sequence almost i finished but i need some help
    sasientry Level 1
      Hi all
      Almost i finished this script but i need three digit sequence only
      But now it saved single digit only
      When i run more than 100 file in one batch
      I need to save FileName_001.Extension
                            FileName_011.Extension
                            FileName_101.Extension
                            FileName_111.Extension
                            FileName_999.Extension
      Now it saved only single digit
      Please correct it
      // enable double clicking from the Macintosh Finder or the Windows Explorer
      #target photoshop
      gFilesToSkip = Array( "db", "xmp", "thm", "txt", "doc", "md0", "tb0", "adobebridgedb", "adobebridgedbt", "bc", "bct" );
      var inputFolder = Folder.selectDialog("Select a folder of documents to process");
      OpenFolder();
      function OpenFolder() {
              var filesOpened = 0;
              var fileList = inputFolder.getFiles();
              for ( var i = 0; i < fileList.length; i++ ) {
                      if ( fileList[i] instanceof File && ! fileList[i].hidden && ! IsFileOneOfThese( fileList[i], gFilesToSkip )) {
                              open( fileList[i] );
                              filesOpened++;
                             var docPath = createFolder("~/Desktop/EPS");
                              var suffix ="_";
                          var fileName =activeDocument.name.match(/(.*)\.[^\.]+$/)[1];
                          var epsFile = new File( docPath+"/"+fileName+suffix+[i]+'.eps');
                          var doc = app.activeDocument;
                  epsSaveOptions = new EPSSaveOptions()
                  epsSaveOptions.embedColorProfile = true
                  epsSaveOptions.encoding=SaveEncoding.JPEGMAXIMUM
                  app.activeDocument.saveAs(epsFile, EPSSaveOptions, true,Extension.LOWERCASE)
                  app.activeDocument.close( SaveOptions.DONOTSAVECHANGES );
              return filesOpened;
      function IsFileOneOfThese( inFileName, inArrayOfFileExtensions ) {
                var lastDot = inFileName.toString().lastIndexOf( "." );
                if ( lastDot == -1 ) {
                          return false;
                var strLength = inFileName.toString().length;
                var extension = inFileName.toString().substr( lastDot + 1, strLength - lastDot );
                extension = extension.toLowerCase();
                for (var i = 0; i < inArrayOfFileExtensions.length; i++ ) {
                          if ( extension == inArrayOfFileExtensions[i] ) {
                                    return true;
                return false;
      function createFolder (thePath) {
           var theFolder = Folder(thePath);
           if (theFolder.exists == false) {theFolder.create()};
           return(theFolder)
        • 1. Re: I need to Save file add 3 digit sequence almost i finished but i need some help
          yajiv_viki Level 2
          Hi Sasi,
          Here is the corrected code....
          -yajiv
          #target photoshop
          OpenFolder();
                  for ( var i = 1; i < fileList.length; i++ ) {
                                  filesOpened++;
                                  var suffix ="_";
                              if(i>0 && i<10){
                                  var epsFile = new File( docPath+"/"+fileName+suffix+"00"+[i]+'.eps');
                               if(i>9 && i<100){
                                  var epsFile = new File( docPath+"/"+fileName+suffix+"0"+[i]+'.eps');
                              if(i>99){
                  return filesOpened;
                              return false;
                                        return true;
                    return false;
               return(theFolder)
          • 2. Re: I need to Save file add 3 digit sequence almost i finished but i need some help
            sasientry Level 1
            Hi yajiv
            I need to alert box with all info under the tiff properties
            If there is no tiff properties i need to alert(" there is no metada")
            Please give me any idea
            • 3. Re: I need to Save file add 3 digit sequence almost i finished but i need some help
              yajiv_viki Level 2
              Hi Sasi,
              Sorry to say this, I can't able to understand what your need.
              Can you elaborate you procedure in step by step.
              I try to do my best....
              -yajiv
              • 4. Re: I need to Save file add 3 digit sequence almost i finished but i need some help
                sasientry Level 1
                sure yajiv
                I can explain clearly
                Every files have file info, In that file info there is lot of taps like Description,IPTC
                In Advanced taps i need all information in tiff properties details in  alert windowUntitled.jpg
                • 5. Re: I need to Save file add 3 digit sequence almost i finished but i need some help
                  yajiv_viki Level 2
                  Hi Sasi,
                  As per my understanding, you need to show all information (i.e. height, width & resolution....) about Tiff files.
                  Is it right...!
                  Test this code....
                  var xmpString = app.activeDocument.xmpMetadata.rawData;
                      if( xmpString !=null )
                          alert(xmpString);
                      else
                          alert("There is no Metadata.....!!!")
                  - yajiv
                  • 6. Re: I need to Save file add 3 digit sequence almost i finished but i need some help
                    sasientry Level 1
                    Hi yajiv
                    I dont need all raw data detail
                    In Raw data  "xmlns:tiff="http://ns.adobe.com/tiff/1.0/" this string is there i need to process image
                    If this properties is not there i need alert
                    There is to metadata
